hi flip, on enigma2 list, you removed the Fox News Channel but didnt add it with new freq, its missing from the "News" list, thanks.
(added it myself ok but just thought i let you know so you can re-add it next time, cheers)
SGTFlipFlop SKYUK Bouquets - Updated Regularly
cant get the sky sports interactive channels working on enigma 1 list i can see them in the menu but cant select them anyone know y i can select every other channel including bbc interactive also sky news channel interactive cant select that one either? stays on the last channel i was onHere is the latest update
DreamboxEdit 5.0.2.0 Used (Recommended) Guide Here
Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800
Updates: 15th June 2012
Bouquet Updates
BBC Olympic Interactive (16 Channels)
Crime & Investigation Network
Fox News Channel
Sky Box Office Channels Fixed (Except 734, 735, 736, 737, 738, 739)
SkyPoker.com
UMP Stars (International Bouquet)
Removed Channels
Fox News Channel
Picons
Updated newest channels
** Dumped Multi Bouquet, Don't Use My Dish No More Pointless Updating, Check Out Catseye settings, Excellent **
These bouquets are positioned identical to the Sky Box, All that is different is the numbering which I find to be very messy when done so I leave it how it is. Enjoy a neat up to date bouquet.
I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Please keep this thread clean, Use the Thanks button rather than posting on the threadCode:Also added Picons for Sky UK, All correctly mapped and a few obscure ones missing only Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required! Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
Leave a comment:
Leave a comment:
LOL, I think you're going to get busy with the Olympic channels M8, there's supposed to be 24 SD and 24 HD channels on their way. If they appear 1 transponder a day, it's going to be fun
Leave a comment:
Bouquet Updates
Fox News Channel
SkyPoker.com
Removed Channels
Fox News Channel
Picons
Leave a comment:
haha funny, actually Im not 100% sure it will work but if alternative channels are added, when people update the bouquet through TSPanel or dreamboxedit, their selected alternative channel will not change after update.Leave a comment:
that's a great idea , but can u bring the beers tho
Sent from my iPhone using TapatalkLeave a comment:
I just had an idea, can you add alternative channels to the the first 3 regional channels, BBC 1, BBC2 & ITV. It can be added using dreamedit, then people can easily & quicky select the the regional channel of your choice from their box and also makes it easier for people install it from TSPanel. people can select regional and HD channel as alternatives.
Want me to come down during half time of the football aswell and make your a cup of tea? Quick back rub? HeheLeave a comment:
SGTFlipflop, thanks for your great boquets
One thing though. I cant get the picons to show on my 7025. Does this box supports picons?
I copied the whole 'picon' folder to the root of my usb. Is this correct?
I have the latest openpli image and am using the 'Magic' skin, which is already in the imageLeave a comment:
I just had an idea, can you add alternative channels to the the first 3 regional channels, BBC 1, BBC2 & ITV. It can be added using dreamedit, then people can easily & quicky select the the regional channel of your choice from their box and also makes it easier for people install it from TSPanel. people can select regional and HD channel as alternatives.Leave a comment:
Ok, Just deleted box office from the lists, Causes me too much hassle to do
EDIT: Saying that just had a look should take me 2 minutes to fixLast edited by SGTFlipFlop; 12 June, 2012, 17:13.Leave a comment:
Adding box office channels is more complicated than I thought, A guide would be appreciated.Leave a comment:
Leave a comment:
