Got it, Thanks mate
i have downloaded your picons, how do i upload them to my VU+ as its not in your tutorial thread?
Do i also use dreambox edit for this?
Thanks again, really appreciate it
SGTFlipFlop SKYUK Bouquets - Updated Regularly
Guest replied -
In Entertainment bouquet, You would delete BBC1 BBC2 ITV1 and Channel 4 that is there present and swap with
RT? One
RT? Two
TV3
TG4
Save the files and send to your box
Or you could go down to the Irish variations folder and use the channels in thereLeave a comment:
Guest repliedHi SGTFlipFlop
Just came across this thread and wanted to say a huge thanks for all hard work you have done creating/maintaining this bouquet
I have a quick question
You said "If you are from Ireland, I've renamed all Irish channels so easy for you to find" but i cant see any irish named BBC/UTV channels in the screenshots in your dreamboxedit tutorial thread?
Can you please explain this and tell me how i do this? do i just delete all the english regional UTV/BBC channels from the left column or just drag the Irish channels into the middle column?
I'm not too clear on this
(im in Ireland by the way)
Thanks again mate
hope i made sense
AlanLeave a comment:
Here is the latest update
DreamboxEdit 5.0.0.3 Used (Recommended) Guide Here
Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800
Updates: 24th February 2012
Bouquet Updates
ITV1 +1 (New Channel)
Primetime (Fixed)
Sky Sports F1 ??? (2 SD Channels Appeared Guess This Is the F1 channels)
Sky Sports F1 HD ??? (2 HD Channels Appeared Guess This Is the F1 channels)
Both in Testing EPG Bouquet
New Positions for some Sky Channels in Entertainment bouquet all changes done, Sky Arts moved to that bouquet aswell
Removed Channels
100% Babes
Picons
Updated newest channels
These bouquets are positioned identical to the Sky Box, All that is different is the numbering which I find to be very messy when done so I leave it how it is. Enjoy a neat up to date bouquet.
I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Please keep this thread clean, Use the Thanks button rather than posting on the threadCode:Also added Picons for Sky UK, All correctly mapped and a few obscure ones missing only Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required! Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
Attached FilesLeave a comment:
Figured out what was the problem. Solved it by rescanning the sat then import your file.
Strangly it said that there was services missing. When I checked what channels where they I figure out that they were Box Office and Interactive...What did I miss? If that happened how can I retreve them?Leave a comment:
Just finished. No luck. I'm going to try a new image.Leave a comment:
Can you try 1 more thing for me, Send the bouquets as per my guide, But just click Reload settings button, Then go to your Dreambox and go to standby options and choose Restart Enigma 2
See if that makes any differenceLeave a comment:
I appreciate the help. Many people hold you in great esteem and now I know why. Thanks for helping. I might try a new image. I like the one I have so I'm not sure I want to remove it.Leave a comment:
You ain't being a nuisance mate. Never heard of the image not allowing new bouquets to the box, Maybe someone else has an idea?Leave a comment:
I have done that and more. I have been trying to install these bouquets for like a week. I'm starting to think it might be the image. I might need to reflash. Apologies for being a nuisance. I think I'm gonna reflash and then try again. Before I flash can an image cause my type of problem?Leave a comment:
You haven't done it to a T then
Send the Enigma2 files to your box, Reload the settings then reboot the box
See what happensLeave a comment:
You are viewing the list as All Channels, Look for Favourites.
What box are you using?Leave a comment:
I have got a problem. I have followed the instructions to a T but when I load the bouquet I get multiple channels. The services on the left are what appears on the dreambox. The channels in the middle which are edited are nowhere to be seen. I am at a loss here
Leave a comment:
the 2nd try worked mate. wish i was as clever as some of you guys. thank you.Leave a comment:
Leave a comment:
