SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • smirnoff_rules
    • 8603
    #91
    some movie ones can remember all because it says service removed
    • SGTFlipFlop
      • Sep 2009
      • 1002
      #92
      • smirnoff_rules
        • 8603
        #93
        cheers didnt see the date ..thanx
        • junger
          • 200
          #94
          Sorry to ask but are the files the same for both dm800hd and dm500?
          Junger
          If only I had more time that I could waste
          • SGTFlipFlop
            • Sep 2009
            • 1002
            #95
            Junger
            Enigma1 is the same without all the HD channels
            • geeuk
              • 18
              #96
              when i open the interactive channels such as the sky sports actives, the channel name automatically get renamed..
              What can i do to prevent this from happening?
              • SGTFlipFlop
                • Sep 2009
                • 1002
                #97
                You cant
                • wschofield
                  • Oct 2010
                  • 5
                  #98
                  Using you're excellent bouquet, but when i try to go on FX HD it says SID not found in PAT
                  Also ITV 3 and 4 HD both have there names changed to 4 digit numbers instead.
                  Any ideas on how to sort this please.
                  Cheers
                  • rossi2000
                    • 37
                    #99
                    fxhd doenst start till 7pm
                    give it a try then
                    • SGTFlipFlop
                      • Sep 2009
                      • 1002
                      #100
                      FX HD programmes don't start until 7pm
                      ITV 3 HD & ITV 4 HD are testing off the EPG at the moment they will change to numbers until the 15th November and they will stay as there there proper channel names
                      • SGTFlipFlop
                        • Sep 2009
                        • 1002
                        #101
                        Here is the latest update
                        DreamboxEdit 4.0.1.0 Used (Recommended) Guide Here
                        Updates: 10th November 2010
                        DM800 Bouquet Only
                        Climax3 Renamed To Extreme
                        Discovery Knowledge Renamed to Discovery History
                        Discovery Knowledge +1 Renamed to Discovery History +1
                        Max TV Renamed To Olive TV
                        Sky Box Office (Frequency Changes)
                        Removed Channels
                        None
                        Picons
                        Updated new channels
                        ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
                        Also added Picons for Sky UK (Base set from Picon4U) and the rest updated by myself
                        Use any FTP client, DCC for example, to transfer the picon directory
                        to one of the following paths on Flash, HDD, CF or USB respectively:
                        /usr/share/enigma2
                        NOT recommended, because of limited capacity of the flash memory
                        /media/hdd
                        HDD will keep running indefinitely and may affect image performance
                        /media/cf
                        Recommended if CF available and successfully mounted (8000/800)
                        /media/usb
                        Recommended if USB available and successfully mounted (8000/800)
                        Picon will display immediately on zapping, no further setup required!
                        Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
                        Please keep this thread clean, Use the Thanks button rather than posting on the thread
                        • golfshippy
                          • Nov 2010
                          #102
                          Ok i know there is a simple answer to this, but i have spent hours searching and i know its stareing me in the face and i cant see it,
                          How do i connect my dreambox to my mac to install these bouquets, ie what cables do i need ?
                          Thanks in advance
                          • smirnoff_rules
                            • 8603
                            #103
                            MEGAUPLOAD - The leading online storage and file delivery service THINK THIS is for mac users
                            • golfshippy
                              • Nov 2010
                              #104
                              Thanks for the reply, i have that program already,sorry i didnt make myself clear what i would like to know is how do i connect my dreambox to my pc so i can copy these bouquets to my dreambox, do i need a ehternet cable or a rs232 cable for example ?
                              • smirnoff_rules
                                • 8603
                                #105
                                ehternet m8 .. u are connected to your router anyway ,. go into options and put dreamox ip in and root and pass word dreambox and send
