SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • macbow
    • Oct 2010
    • 15
    #556
    hi there m8 looking for challenge and mgm hd etc havin no joy updated boquet 7/5/11 still not coming on, is there a way to change settings manually, thx in advance
    • tint2000
      • 21
      #557
      the enigma 2 bouquets work flawlessy just enigma 1 having problems
      • madmac1
        • 6
        #558
        Enigma 1 updated bouquet
        Ive noticed a problem with the enigma 1 bouquets. The path is wrong in userbouquets.tv.epl file. The path is /etc/enigma2/ and should be /var/tuxbox/config/enigma. Ive attached the enigma 1 bouquets with the correct path.
        Madmac
        • macbow
          • Oct 2010
          • 15
          #559
          thx, im using enigma 2 and still no mgm's challenge's etc, thought u could change freq settings manually mmmmmm thx
          • reddiamond
            • Jun 2009
            • 21
            #560
            Frequency has changed m8
            Eurobird 1, 28.2?E
            (21h00) Sky Digital: New frequency for Livingit +1: 11565.00MHz, pol.V (DVB-S SR:27500 FEC:2/3 SID:6025 PID:523/671 English,651 English- VideoGuard).
            (21h00) Sky Digital: New frequency for Challenge: 11565.00MHz, pol.V (DVB-S SR:27500 FEC:2/3 SID:6031 PID:522/670 English,650 English- VideoGuard).
            • macbow
              • Oct 2010
              • 15
              #561
              thx m8, the frequencies being shown are the updated ones but still no pictures
              • SGTFlipFlop
                • Sep 2009
                • 1002
                #562
                Originally posted by tint2000
                just asking on here whats ya problem?
                Maybe this
                Please keep this thread clean, Use the Thanks button rather than posting on the thread
                That is posted at the end of every one of my Bouquet posts, Because people don't think there are any updates because people keep posting and knocking the updates of the page
                • satsmo
                  • 6397
                  #563
                  Thread tidied up a bit, (it could do with more), to keep these gents happy http://www.digital-kaos.co.uk/forums...0/index40.html
                  • SGTFlipFlop
                    • Sep 2009
                    • 1002
                    #564
                    Here is the latest update
                    DreamboxEdit 4.0.1.2 Used (Recommended) Guide Here
                    Enigma 1 = Dreambox 500, 600, 7025
                    Enigma 2 = Dreambox 800, 8000, 500 HD
                    Updates: 15th May 2011
                    Bouquet Updates
                    Aastha TV (New Frequency)
                    Eurosport 3D (Not sure what this is yet??)
                    NHK World HD (New Channel)
                    Removed Channels
                    Aastha TV
                    Tease Me TV 1
                    Tease Me TV 2
                    Picons
                    Updated Few Old Picons to New Ones
                    I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
                    ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
                    Also added Picons for Sky UK,
                    All correctly mapped and a few obscure ones missing only
                    Use any FTP client, DCC for example, to transfer the picon directory to
                    one of the following paths on Flash, HDD, CF or USB respectively:
                    /usr/share/enigma2
                    NOT recommended, because of limited capacity of the flash memory
                    /media/hdd
                    HDD will keep running indefinitely and may affect image performance
                    /media/cf
                    Recommended if CF available and successfully mounted (8000/800)
                    /media/usb
                    Recommended if USB available and successfully mounted (8000/800)
                    Picon will display immediately on zapping, no further setup required!
                    Always remove old picons from Dreambox before uploading new ones,
                    Sometimes they don't overwrite correctly
                    • irsh12
                      • Oct 2010
                      • 108
                      #565
                      Is anyone using theses bouquets on an OPENBOX S9 HD?
                      I currently have a TM-500S and it works perfectly but I'm planning to buy an openbox s9 because of HD channels.
                      Thanks.
                      • johny48
                        • 50
                        #566
                        hi SGTFlipFlop
                        cant seem to get the celtic interactive channel in your bouquettes.
                        cheers johny48
                        • SGTFlipFlop
                          • Sep 2009
                          • 1002
                          #567
                          Originally posted by johny48
                          hi SGTFlipFlop
                          cheers johny48
                          Good
                          • cris808
                            • 133
                            #568
                            Hi mate. Not sure if its because I need to rescan but on your multi pack the 13.0E Sky Italy Sports/Calcio channels are not working. Last I heard they changed the frequencies?
                            • SGTFlipFlop
                              • Sep 2009
                              • 1002
                              #569
                              I'll do a scan on the next update mate, I only do these once in a while as they very rarely change, Would it be possible for everyone who needs these to scan Hotbird manually as it only takes 10 minutes
                              Please accept my apologies
                              • cris808
                                • 133
                                #570
                                No worries mate. Just thought I'd mention it. As you said it only takes 10minutes to scan it manually. Cheers for the continued updates though, best out there by far!
