I'm making a whole reset. Will let you know what I could do.
SGTFlipFlop SKYUK Bouquets - Updated Regularly
didnt have to read it.. we watched it
~~~~ me , ld be pissed if l paid for that then
.. wish l stayed in now instead of watchin in the pub and havin a hang over all the next day
any information provided is for educational/experimental purposes only.Comment
mines working , showing at ad
Sent from my iPhone using Tapatalkany information provided is for educational/experimental purposes only.Comment
yeah boxnation had the freeview up until 9.30 on saturday then was meant to encrypt, but it didnt. Showed the whole klitschko fight and half of the mageen fight before they caught on and it went into encryptionComment
boxnation is fine on my bouquet and my sealion takes care of encrption. primetime is not working in bouquet aswell as E! channel and i think tcm2 also does not work well these are the three that ive noticed although i have not had a proper ceck on all channels but have noticed these threeIf iv'e helped you then please click the THANKS / LIKE button !
Here is the latest update
DreamboxEdit 5.0.0.3 Used (Recommended) Guide Here
Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800
Updates: 23rd February 2012
Bouquet Updates
9XM (New Channel)
E! (New Frequency)
ITV1 +1 Tyne Tee's (New Channel)
The Debt Store (New Channel)
New Positions for some Sky Channels in Entertainment bouquet all changes done, Sky Arts moved to that bouquet aswell
Removed Channels
Gay Chat TV
Luxury Life
Sky Living Loves
Picons
Updated newest channels
These bouquets are positioned identical to the Sky Box, All that is different is the numbering which I find to be very messy when done so I leave it how it is. Enjoy a neat up to date bouquet.
I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Please keep this thread clean, Use the Thanks button rather than posting on the threadCode:Also added Picons for Sky UK, All correctly mapped and a few obscure ones missing only Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required! Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
Attached FilesLast edited by SGTFlipFlop; 23 February, 2012, 20:41.
ho no they removed Gay Chat TV ?
