Thaks for that bazinga, but the question was if I had uploaded the bouquets incorrextly taking up my stored Favourites I had previously done. Do you have any problems uploading and is this Bouquet under SGTFlipFlop ?
SGTFlipFlop SKYUK Bouquets - Updated Regularly
I use to have uploading issues for example I would upload a boquet it doesn't update properly, channel name, folder etc.
now its seems to work fine don't know what I done differently,
Hi bazinga. You will notice that the 3 check boxes at the ftp transfer stage were left unchecked as per the SGT's instruction, which should have retained the previously saved bouquets, so it was a surprise to see them gone. I did hit the 'Restart Enigma' button to reboot the box.Comment
the reason I don't keep the previously saved bouquets is because some times the channel frequency gets recycled for example if one channel closes down another new channel will take over the same frequency and the old channel name will stays on.Hi bazinga. You will notice that the 3 check boxes at the ftp transfer stage were left unchecked as per the SGT's instruction, which should have retained the previously saved bouquets, so it was a surprise to see them gone. I did hit the 'Restart Enigma' button to reboot the box.Comment
Just setting up a Technomate 500 for a mate. I've literally done this dozens of times with DM500 but for some reason after I send files and then when I click "Reload Settings on Dreambox" Dreambox Edit freezes and will not reload. Even if I reboot manually there are no changes to the bouquet. Anyone any ideas?Comment
Wurz, I have loaded this on and now the tuner is not being registered so something is wrong with my upload as well. I will have to request some info to the SGT.Just setting up a Technomate 500 for a mate. I've literally done this dozens of times with DM500 but for some reason after I send files and then when I click "Reload Settings on Dreambox" Dreambox Edit freezes and will not reload. Even if I reboot manually there are no changes to the bouquet. Anyone any ideas?Comment
I was wondering if SGTFlipFlop will ever produce an Openbox compatable channel list - I have 2 Dreamboxes and now also bought a Skybox S12 but have been finding it really hard to get decent channel lists for it. I have folled guides on this forum to convert SGT's bouquets into channel lists but its not worked - any pointers or links would be appreciatedComment
Probably a stupid question but when the Picon pack is installed, SGT's notes state:
/media/cf
Recommended if CF available and successfully mounted (8000/800)
/media/usb
Recommended if USB available and successfully mounted (8000/800)
Now does media/CF mean Compact Flash? If so is that an internal or external flash?
Does media/usb mean if a USB stick is in one of the USB ports?Comment
