SGTFlipFlop SKYUK Bouquets - Updated Regularly
  • SGTFlipFlop
    • Sep 2009
    • 1002
    #1666
    Here is the latest update
    DreamboxEdit 5.0.2.0 Used (Recommended) Guide Here
    Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
    Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800
    Updates: 15th June 2012
    Bouquet Updates
    BBC Olympic Interactive (16 Channels)
    Crime & Investigation Network
    Fox News Channel
    Sky Box Office Channels Fixed (Except 734, 735, 736, 737, 738, 739)
    SkyPoker.com
    UMP Stars (International Bouquet)
    Removed Channels
    Fox News Channel
    Picons
    Updated newest channels
    ** Dumped Multi Bouquet, Don't Use My Dish No More Pointless Updating, Check Out Catseye settings, Excellent **
    These bouquets are positioned identical to the Sky Box, All that is different is the numbering which I find to be very messy when done so I leave it how it is. Enjoy a neat up to date bouquet.
    I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
    ** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
    Also added Picons for Sky UK,
    All correctly mapped and a few obscure ones missing only
    Use any FTP client, DCC for example, to transfer the picon directory to
    one of the following paths on Flash, HDD, CF or USB respectively:
    /usr/share/enigma2
    NOT recommended, because of limited capacity of the flash memory
    /media/hdd
    HDD will keep running indefinitely and may affect image performance
    /media/cf
    Recommended if CF available and successfully mounted (8000/800)
    /media/usb
    Recommended if USB available and successfully mounted (8000/800)
    Picon will display immediately on zapping, no further setup required!
    Always remove old picons from Dreambox before uploading new ones,
    Sometimes they don't overwrite correctly
    Please keep this thread clean, Use the Thanks button rather than posting on the thread
    • lincsat
      • 1228
      #1667
      LOL, I think you're going to get busy with the Olympic channels M8, there's supposed to be 24 SD and 24 HD channels on their way. If they appear 1 transponder a day, it's going to be fun
      • SGTFlipFlop
        • Sep 2009
        • 1002
        #1668
        Yeah read that mate, I'll stick them in their own section, No hassles at all
        • bb5
          • Aug 2008
          • 13
          #1669
          Bouquet Updates
          Fox News Channel
          SkyPoker.com
          Removed Channels
          Fox News Channel
          Picons
          /usr/share/enigma2
          /media/hdd
          /media/cf
          /media/usb
          cant get the sky sports interactive channels working on enigma 1 list i can see them in the menu but cant select them anyone know y i can select every other channel including bbc interactive also sky news channel interactive cant select that one either? stays on the last channel i was on
          • neil0129
            • 50
            #1670
            hi flip, on enigma2 list, you removed the Fox News Channel but didnt add it with new freq, its missing from the "News" list, thanks.
            (added it myself ok but just thought i let you know so you can re-add it next time, cheers)
            • wingunners
              • May 2010
              • 42
              #1671
              can i upload these to a vu+ duo in the same way?
              • choakem
                • 14
                #1672
                Wingunner - You certainly can - choose the engima 2 bouquets - will work fine
                • choakem
                  • 14
                  #1673
                  Im having the exact same problems... Im using a dm500 and the pli image....
                  • choakem
                    • 14
                    #1674
                    Sorry - that last message was in response to BB5 problem with the Sky interactive channels.
                    • bazinga
                      • Feb 2012
                      • 27
                      #1675
                      some of the sky sports active channels are not working.
                      • choakem
                        • 14
                        #1676
                        Let me be more specific......
                        I used the enigma1 bouquets (DM500 - PLI image)
                        The latest Dreamset program does not recognise the Sky interactive channels and when I used Dreamboxedit then I am unable to goto any interactive channel.
                        They are clearly there but if I'm watching say BBC1 and select any interactive channel then I simply remain on BBC1. No attempt is made to switch to any of the interactive channels.
                        Its very strange...
                        • bb5
                          • Aug 2008
                          • 13
                          #1677
                          Its very strange...
                          yip same problem here enigma 1 bouquet
                          • freck
                            • 1076
                            #1678
                            Its very strange...
                            Yeah....same problem here on the E1 bouquets?????
                            Freck
                            • tariqz118
                              • Mar 2010
                              • 49
                              #1679
                              which channel is sky box office hd on the new boquet? cheers
                              • Dranny
                                #1680
                                Hi there.
                                Awesome bouquets as always Sarge....
                                Quick question regards the Box Office bouquet though.
                                They seem to be uploading fine but displaying as N/A both in the HD part and the dedicated Box Office bouquet.
                                Any idea why this may be? I've deleted my whole Enigma2 folder and put a fresh copy of the latest bouquet on before even modifying the regional BBC/ITV etc.
                                I'm running a Vu Duo + btw.
                                I've had them all named up properly before (sporadically) but usually they come up as N/A.
                                Any ideas?
                                Cheers!
