Hi I am a newbie to this so sorry if this is a basic question. I used dbedit to transfer the engima 2 file, then rescan, reboot. But when I go into my channels bouquet is not there. only the german one that came preloaded. When a open dbedit and press recieve it loads up the new bouquet and german no longer there. Any help would be great.
SGTFlipFlop SKYUK Bouquets - Updated Regularly
Make sure you follow this guide mateHi I am a newbie to this so sorry if this is a basic question. I used dbedit to transfer the engima 2 file, then rescan, reboot. But when I go into my channels bouquet is not there. only the german one that came preloaded. When a open dbedit and press recieve it loads up the new bouquet and german no longer there. Any help would be great.
sgtFlipplop allways on the case straight away and im glad you made a speedy recovery because alot off people would be lost without u on the scene.and i for one am allways regreatfull for all your help. And i know im not the only 1 here that thinks the same so good luck in the future we are all wishing u good luck and your in my prays mate ive a caddle burning from i heard you were ill too get well. again i cant thank u for evry thing you have done for all off usComment
hi, im a little new to all this and i would like to know wht is CCcam.channelinfo file is for and where to put it in the box,
thanks for the help and the bouquetsComment
Here is the latest update
DreamboxEdit 5.0.2.0 Used (Recommended) Guide Here
Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800
Updates: 27th August 2012
Bouquet Updates
British Eurosport 2 HD (New Channel)
C4 Paralympic Channels (3 HD & 3 SD) (New Channel)
eNews Renamed to eNCA Africa
Ideal & More Renamed to The Deal Channel
Nick Jr. (New Frequency)
Nick Replay (New Frequency)
Nickelodeon (New Frequency)
Nicktoons (New Frequency)
Sky Box Office 727, 729, 730, 731, 732 (Fixed)
Sky Movies Summer Renamed to Sky Movies Showcase
Sky Movies Summer HD Renamed to Sky Movies Showcase HD
TCM HD (New Channel)
The Africa Channel (New Frequency)
The Horror Channel (New Channel)
The Pub Channel (New Channel)
Removed Channels
Praise TV
Sumo TV
The Active Channel
The Africa Channel
Picons
Updated newest channels
** Dumped Multi Bouquet, Don't Use My Dish No More Pointless Updating, Check Out Catseye settings, Excellent **
These bouquets are positioned identical to the Sky Box, All that is different is the numbering which I find to be very messy when done so I leave it how it is. Enjoy a neat up to date bouquet.
I will be doing Enigma2 Multi Bouquet, But will not for Enigma1 as it takes too long to remove every HD channel from all satellites, Easily too do yourself if you have the time.
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Please keep this thread clean, Use the Thanks button rather than posting on the threadCode:Also added Picons for Sky UK, All correctly mapped and a few obscure ones missing only Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required! Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
Okay, Until next update do this to fix it
Open my Bouquets in DBE
Find Star Plus HD (Right click on it Edit Transponder Data)
Change System from DVB-S2 to DVB-S (Click Save)
Save Bouquet
Send to box, All fixed
Looking for a tester on an Enigma2 box to test a new Bouquet for me, Any takers post here and let me know
