SGTFlipFlop SKYUK Bouquets - Updated Regularly
Use this guide on how to load the action file
Photoshop Files - How to add an Action
After action file loaded find your logo from Here
I'll use the MTV logo for this guide.
Open Photoshop (File>Open Find your logo (Needs to be 132x99 pixels)
Once the file is loaded into Photoshop all you need to do is click the little Play button on the loaded action, Let it do its job then should save completed Picon to desktop then you can load it into DBE from there
SimplesAttached Files
it gives you info on cccam, the same sort of thing can be done by typing your receivers ip address into a browser followed by :16001, so for instance
192.168.1.55:16001Fave replies from various threads
Ahh, thanks for that reply....Would it be correct to assume that it doesnt really matter then if this isnt being updated ?Comment
Thanks plz update picon for sly ch number 792 prime tv . picon missing thankshere we are an update bouquets 18/11/12
115 - BBC Three [New Frequency]
116 - BBC Four [New Frequency]
151 - E! HD [New Channel]
168 - BBC ALBA [New Frequency]
193 - HiTV [Removed]
200 - Controversial TV [Removed]
200 - Loaded TV [New Channel]
233 - E! Entertainment [Moved]
234 - Diverse [New Channel]
303 - Sky Showcase HD [Renamed]
327 - Christmas 24 [Renamed]
328 - Christmas 24+ [Renamed]
330 - Sky Showcase [Renamed]
387 - Ramp'd [Removed]
387 - Heart TV [New Channel]
388 - Ramp'd +2 [Removed]
388 - Capital TV [New Channel]
503 - BBC News [New Frequency]
588 - Gospel Channel [New Frequency]
613 - CBBC Channel [New Frequency]
614 - Cbeebies [New Frequency]
700-761 - Complete overhall of Box Office [All working now]
814 - Channel S [New Frequency]
819 - Noor TV [New Frequency]
827 - ATN Bangla UK [New Frequency]
834 - Channel 9 UK [New Frequency]
838 - Madani Channel [New Frequency]
843 - UCTV [Removed]
843 - Samaa TV [New Channel]
844 - Channel i [New Frequency]
851 - 9XM [Removed]
852 - NTV [New Frequency]
976 - BBC 1 North East & Cumbria [New Frequency]
enjoyComment
attached is an updated version of e1 based on flip flop orig.
here is e2 versionLast edited by psats; 21 November, 2012, 23:50.Comment
Closed as relayed on my last post http://www.digital-kaos.co.uk/forums...ml#post1771836
So once again thanks to SGT FlipFlop and as said we will sticky any thread that will be updated as was this one on a regular basis.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
Here is the latest update
DreamboxEdit 5.3.0.0 Used (Recommended) Guide Here
Enigma 1 = Dreambox 500, 600, 7020 | TechnoMate 500, 500 Super, 600 | Blade Media 500
Enigma 2 = Dreambox 800(SE), 8000, 500HD, 7020HD | VU Uno, Solo, Duo, Ultimo | ET 5000, 6000, 9000, 9100, 9200 | TechnoMate 500HD, 800 and many more....
Updates: 19th October 2013
Bouquet Updates
Okay people I'm back, This update has been long time coming had to dust down an old box but finally got it working pfft forgot how
Too many updates to mention it has been nearly a year, ha
Before these Numbering bouquets work you need to make some changes to DBE and your Enigma2 box
For Regional changes you will now need to do these in SGTFlipFlop & Entertainment bouquets now.
in DBE options > advanced > make sure all boxes are ticked especially Allow Duplicate Entries
On Dreambox make sure Multi Bouquets are ticked (Menu>Setup>System>Customize>Expert>Enable Multi Bouquets-YES)
The text in bold needs to be done before you open the bouquets in DBE, Thanks
Updates
Too many to mention just enjoy, Any errors let me know
Removed Channels
Too many to mention
Picons
Updated newest channels
** Dumped Multi Bouquet, Don't Use My Dish No More Pointless Updating, Check Out Catseye settings, Excellent **
These bouquets are positioned nearly identical to the Sky Box, Enjoy a neat up to date bouquet.
** Edit your own BBC & ITV Regional channels to suit your needs in DreamboxEdit (If you are from Ireland, I've renamed all Irish channels so easy for you to find) **
Please keep this thread clean, Use the Thanks button rather than posting on the threadCode:Also added Picons for Sky UK, All correctly mapped and a few obscure ones missing only Use any FTP client, DCC for example, to transfer the picon directory to one of the following paths on Flash, HDD, CF or USB respectively: /usr/share/enigma2 NOT recommended, because of limited capacity of the flash memory /media/hdd HDD will keep running indefinitely and may affect image performance /media/cf Recommended if CF available and successfully mounted (8000/800) /media/usb Recommended if USB available and successfully mounted (8000/800) Picon will display immediately on zapping, no further setup required! Always remove old picons from Dreambox before uploading new ones, Sometimes they don't overwrite correctly
Welcome back mate top work, Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
