Commando 14.6 DM500 Release
This topic is closed.
  • jw2000uk
    • 37
    #211
    Is there any way of installing E1 plugins on this?
    Trying to install Satfind.. And C**am Info..
    Mainly after a way of showing the ECM?
    Unless im blind and have missed it ;-/
    • grizzlygaz
      • 21
      #212
      Transponder
      How can you add a transponder to include in a scan ? I cannot see any way to add one. The problem is that Primetime is not showing up, probably because the transponder is not in the transponder list but its eluding me as to how to add it.
      • athenrybhoy
        • Jul 2012
        • 76
        #213
        hi guys getting lots of freezing with c.14.6 - ccam 2.2.1 ,was using pli jade before this and was pretty good will have to go back if i cant sort this any ideas? thanks
        • pjmorie
          • Mar 2012
          • 45
          #214
          To see the ECM time (if that's what your talking about) press the BLUE button, then select Commando Exra Menu, then Softcam Menu followed by Camd Status
          • iain66
            • Dec 2010
            • 52
            #215
            How do I get to see locked and hidden bouquets please
            • pjmorie
              • Mar 2012
              • 45
              #216
              Press the following button sequence:
              BLUE -> BLUE -> YELLOW -> 2 -> RED
              or go through the following menu sequence:
              Blue Button -> EPG & Autobouquets Wizard -> Set My Location & Autobouquets -> Autobouquets Wizard -> Autobouquets Selection
              This should bring up a list of the bouquets where you can chnage their status.
              • gulcan
                • Jan 2013
                Thanksss. Perfect work.
                My question How to Hotbird 13 unlock channals?
                • psats
                  • 823
                  #218
                  as above or use the box bouqet editor
                  menu / services / bouqet editor
                  • spudorange
                    • 242
                    #219
                    looking for a reply to my thread regarding box being shagged once a new "setmylocation" or "rescan"
                    detailed in thread 199 + further info 203
                    To recap:
                    flashed, init copied location & get epg and is fine BUT:
                    After a while a rescan or setlocation is needed, OOPS, now epg is a no no, so only way back is complete reflash:
                    I ask anyone (with the time and patience) to try the above, (setmylocation for instance) and your epg scan will take 1 second max, as in NO epg and you will, I am certain have to reflash and start over.
                    I am an "it ain't broke" person but when channels are lost, tp's are moved etc, I do get lumbered with sorting it, so.....
                    Come on anyone that knows why, Just need to understand it.
                    • bob114
                      • 192
                      #220
                      To recap:
                      hi
                      you must reboot the reciver before downloading epg
                      a reboot is needed after auto bouquets update etc each time for epg to work again (you can load epg as meny times as you like after reboot just make sure to reboot again after rescan etc)
                      hope this may help
                      • spudorange
                        • 242
                        #221
                        Hope it does
                        as I do have time on my hands I will try it
                        thanks for the input
                        Originally posted by bob114
                        hi
                        hope this may help
                        • spudorange
                          • 242
                          #222
                          Just done a rescan and epg is shagged again so I have had no choice but to reflash.
                          No amount of switching box off and on worked, neither did re sending the "init" file.
                          No big issue if a box is here, BUT this means EVERY box has to come back here for a reflash
                          This has happened around 8 times now so I know there is an issue that needs resolving.
                          hi
                          hope this may help
                          • psats
                            • 823
                            #223
                            if you look at the home site you will see that itv has now cocked stuff up
                            aswell as the bbc for the epg.
                            the working epg is still 1000% better than any other image out there.
                            • spudorange
                              • 242
                              #224
                              That might be so if it was working, if you read my post it explains this:
                              after a setmylocation (which runs auto bouquets) and a reboot I get the following
                              rtgetepg, takes a whole second to get absolutely zero epg
                              getepg shows a glitching screen of satellite and the lraizer credits, when finished NO EPG
                              So there is an issue
                              5 boxes, 8 tries, the problem appears to be firmware related after BslyB screwed things up.
                              a workaround is as follows "BUT ON A NEW FLASH ONLY", not after re doing the setmylocation a week after for instance.
                              see below:
                              "Originally Posted by PaphosAL Earlier today, BskyB kindly went and busted LraiZer's GetEPG. How? By changing the special stream epg service "EPG Background Audio." from service_type="02" (radio) to service_type="82" (data)
                              The problem will become apparent after a run of AutoBouquets"
                              • psats
                                • 823
                                #225
                                see below:
                                if you install the init after you have done the set location and dont set daily run of set location or auto bouqets the epg wrks fine you only need run a standard scan IF channels have moved.
