enigma 2 keeps re-starting
  • patch
    • 69
    i have a dm500hd and am running open pli 1 which has been fine for ages but all of a sudden enigma 2 re-boots on its own every so often , ive looked in the crash log , but dont really know what to look for , have never used telnet , i just use dreambox edit and dcc to ftp channel list to box . can i have some advice on what to do ( will probably need step by step instructions if i have to use dcc or dreambox edit) or should i re-flash with the same image and see if that cures the problem . thanks
  • Wingnut
    • 376
    that was happening to me mte also, i just reflashed again and all is ok now
    • patch
      • 69
      @ wannelly , were you using pli 1 image and did you just reflash the same image . thanks
      • benny/9
        • 1964
        just remember to upload your chn list and write
        down your motor settings [long/lat] if you use
        the usuals motor settings before you re-flash any
        image as it will over write the previous image
        and clear all your settings just like a factory reset does
        to other types of sat receivers
        Please Read Carefully!
        • patch
          • 69
          i have satellites programmed in the vbox and i will just ftp latest channel list accross using dcc . thanks
          • benny/9
            • 1964
            i dont know about others with this model but i
            found it better to scan my own channels and sort them
            with the dreamboxedit. it saves a lot of clashing problems
