DreamboxEdit Guide
  • owen7
    • Aug 2009
    • 78
    #91
    Originally posted by andy91
    Might be able to do it with a cross over cable but doing it wirelessly is best with a laptop.
    Andy.
    Ok cheers.
    I've managed to connect the Dreambox to the router downstairs via Ethernet and the Pc is up stairs connected by wifi but when i go to send the files it just hangs, any ideas?
    • andy91
      • Aug 2010
      • 3583
      #92
      Originally posted by owen7
      Ok cheers.
      Have you gone into tools then options and put the ip address of the Dreambox in and done a test?
      Andy.
      • owen7
        • Aug 2009
        • 78
        #93
        Scrub that last comment, managed to transfer them ok wrong port number - had 80 instead of 21 doh!
        When i scan for channels however i still get none found any ideas?
        • 00360362878
          • Mar 2010
          • 488
          #94
          Are you sure the dish is looking at the satellite you are trying to scan.
          • highsocietyinfo
            • Jan 2012
            I have dreambox 600 pvr, i use dreamboxEDIT, I go Tools->Options->Profiles i click Test IP Connection it says Successfully connected...I click Test Username/Password it says Could not connect...(Before that i pressed blue button which is at remote control->Plugins->TuxBox Commander i went to var/etc/ i deleted passwd and i renamed passwd- to passwd and saved it. Normally the username has to be root and password has to be dreambox). I use username: root password: dreambox FTP port: 21 and doesn't work (I mentioned above) i don't know if FTP port: 21 is correct, how can i find the correct FTP port? Why username:root and password:dreambox are wrong? How can i find the correct username and password? Please help me
            • SGTFlipFlop
              • Sep 2009
              • 1002
              #96
              • billybremner
                • Sep 2012
                #97
                Regional channel problem
                Hi, I followed the instruction to edit the regional channels by dragging my BBC and ITV regions to the middle window and deleted the Scottish ones, but when I transfer the bouquet they havn't changed. I did save the changes and reboot by the way.
                Also the lettering type stays black, not green as the rest of the bouquet list does. Don't know if this is important.
                I'm probably missing something simple here so any ideas would be much appreciated.
                Billybremner
                UPDATE
                I've managed to suss this out. I realised That you have to drag your changed channels to the list in the right pane as well, then save your changes and send to VU box.
                • jhlogan
                  • Oct 2012
                  Looking forward to trying this although limited to hotbird access at the moment so not sure what i will get here in Turkey
                  • tennents
                    • Oct 2008
                    • 29
                    #99
                    piopat m8 when i extract this rar file all im getting is a file piopats enigma1 bouquets there dosent seem to be a channel list and when i try to load it in dreambox edit it cant see the file so how do i ftp the file using dreambox edit thanks in advance m8
                    • liam1982
                      • Nov 2012
                      • 37
                      #100
                      just downloaded dbedit it says i have to make some changes ie go to set up>system>customize>enable set up mode>export and set multiple bouquets to yes,the problem is i cant find the set up function..any info much appreciated got it they were refering to my box and not dbedit
                      changed the settings as above but still getting the same message and unable to transfer anything over to the box....anyone any ideas...thanks
                      • shabs100
                        • Dec 2012
                        • 6
                        #101
                        Can someone please guide me to the latest sky hd UK bouquet?
                        • 50pounds
                          • Oct 2008
                          • 36
                          #102
                          DM Bouquets & Skins
                          Would be a good start
                          Also thanks for the great guide
                          • garyoakley
                            • Feb 2013
                            Wow, what a great guide. I've been struggling to import bouquets to a dm600 for weeks now. Followed the guide & success !. Many thanks, it will stop me pulling more hair out.
                            • DMBoot
                              • Nov 2011
                              • 114
                              #104
                              I am currently using Catseye's and Autobouqets.
                              I first transfer Catseye over to the box, then go to say BBC1 and run autobouquets to generate the 28E lists. This gives me 28E twice, but I don't mind that really. I have then set up pin access for all the not so child friendly bouquets.
                              At the next release of Catseye, I will then transfer that over, but here's where my questions start. When I have done this in the past, it replaced everything that was there previously and I just ran Autobouquets again.
                              Does this also mean I will lose the pin locks on the previous bouquets too?
                              Is there a more efficient way to do what I am doing?
                              • Avf130
                                • Jan 2013
                                • 163
                                #105
                                If i decide to update my Bouqets, the new ones overwrite the old ones?
                                Or i get "kaos" in bouqets
