DM800 CLONE COBRA1423 IMAGES v00.4a sim2 oe2.0 ssl84d (setup for sly 28.2e)
  • mdt
    • 3034
    #31
    Originally posted by z11
    Hi Cobra,
    Great image with great features added.
    Tried updating tsmedia (tried through panel and ipk via telenet), both crashed locked up the box, is there anyway to update this?
    Thanks for the great work!
    check available space left on the box,regards mdt
    • z11
      • May 2010
      • 67
      #32
      Ah yes,
      Only 5mb space left.
      I tried putting in a 32gb usb stick & using skin mover ipk to move some things across(this shows working but didnt make any difference seemingly to the required space).
      • MW35
        • Feb 2012
        • 70
        #33
        what file do i download?
        • cobra1423
          • 119
          #34
          hi it's v00.4b to download
          • MW35
            • Feb 2012
            • 70
            #35
            Thanks... Just loaded it looks like a nice image, but can't restart my box it just hangs on the spinning cog wheels, anyone else having this problem? Also is it safe to update from this image or shall I wait for you to release the updates?
            • z11
              • May 2010
              • 67
              #36
              http://1drv.ms/1cEizmZ
              Hi Cobra,
              Is it possible to use the `skin mover` programme after your usb mount to shift packages across to run from the usb?
              Thanks.
              • MW35
                • Feb 2012
                • 70
                #37
                Box reboots after about a 10 to 15 minute wait, tryed updating TS media to the latest version when it says needs to reboot dream box started to reboot after a long wait but then gets stuck on the loading screen, so I got to reinstall, nice-looking but very very buggy. Will probably go back to my old image.
                • z11
                  • May 2010
                  • 67
                  #38
                  Its running out of memory, I had the same probelm.
                  I used a modified blackhole image in between which was lighter/had no large graphic and was able to get tsmedia 8 running.
                  This is a better image of cobras imo & why I am asking/looking for ways to move / run packages from the usb.
                  • MW35
                    • Feb 2012
                    • 70
                    #39
                    Thanks z11,, where can I find that modified blackhole image? As I would love to get TS media 8 working.
                    • z11
                      • May 2010
                      • 67
                      #40
                      Tried opening a new thread with the file for you, but it says file is too large.
                      Will try pm u a link. (its for sim2.01 & 84d)
                      • miau18
                        • Jan 2013
                        • 7
                        #41
                        can you please give me the modified blackhole image too thanks!!!!
                        • cobra1423
                          • 119
                          #42
                          Hi Cobra,
                          Hi can you send me your crash log file you will find it on your HDD or usb this way I can see what the problem is use DCC to get it from your box.
                          Cobra1423
                          ps. You could try formatting your usb and try again
                          • wobblyprop
                            • Jan 2015
                            • 6
                            #43
                            Hi Cobra, had the image for a few months & its been great, last few days though all Movie Streams stopped working, only ones working are some streams via IPTV & Film On via Net TV, is this just a temp problem? after Icefilm movies stopped, 1 channel movies (& series) worked great, but last few days no go
                            Many thanks for all the great work, best image around by far! EPG logo's are special!
                            • cobra1423
                              • 119
                              #44
                              hi try this workaround for tsmedia 1channel update tsmedia to 8.4 then startup 1channel then press the green button for settings change domain to true then change web address to http://primewire.unblocked.pw/ then just save and try it out see if it works.
                              Cobra1423
                              • wobblyprop
                                • Jan 2015
                                • 6
                                #45
                                Cheers, only available update via TSPanel is to version 7.99, tried to update to this numerous times over past few days, crashes every time, each time results in having to re-flash box
