DM800 CLONE COBRA1423 IMAGES v00.4a sim2 oe2.0 ssl84d (setup for sly 28.2e)
hi it's v00.4b to download
Hi Cobra,
Is it possible to use the `skin mover` programme after your usb mount to shift packages across to run from the usb?
Thanks.Comment
Box reboots after about a 10 to 15 minute wait, tryed updating TS media to the latest version when it says needs to reboot dream box started to reboot after a long wait but then gets stuck on the loading screen, so I got to reinstall, nice-looking but very very buggy. Will probably go back to my old image.Comment
Its running out of memory, I had the same probelm.Box reboots after about a 10 to 15 minute wait, tryed updating TS media to the latest version when it says needs to reboot dream box started to reboot after a long wait but then gets stuck on the loading screen, so I got to reinstall, nice-looking but very very buggy. Will probably go back to my old image.
I used a modified blackhole image in between which was lighter/had no large graphic and was able to get tsmedia 8 running.
This is a better image of cobras imo & why I am asking/looking for ways to move / run packages from the usb.Last edited by z11; 19 January, 2015, 09:23.Comment
Hi can you send me your crash log file you will find it on your HDD or usb this way I can see what the problem is use DCC to get it from your box.
Cobra1423
ps. You could try formatting your usb and try againComment
Hi Cobra, had the image for a few months & its been great, last few days though all Movie Streams stopped working, only ones working are some streams via IPTV & Film On via Net TV, is this just a temp problem? after Icefilm movies stopped, 1 channel movies (& series) worked great, but last few days no go
Many thanks for all the great work, best image around by far! EPG logo's are special!Comment
hi try this workaround for tsmedia 1channel update tsmedia to 8.4 then startup 1channel then press the green button for settings change domain to true then change web address to http://primewire.unblocked.pw/ then just save and try it out see if it works.Hi Cobra, had the image for a few months & its been great, last few days though all Movie Streams stopped working, only ones working are some streams via IPTV & Film On via Net TV, is this just a temp problem? after Icefilm movies stopped, 1 channel movies (& series) worked great, but last few days no go
Cobra1423Comment
Cheers, only available update via TSPanel is to version 7.99, tried to update to this numerous times over past few days, crashes every time, each time results in having to re-flash boxComment
