Hi all!
I flashed my dreambox dm500s with pli-Jade last night, and didnt worked fine.
now i got just blue screen on tv
My problem is that the box won't connect to DreamUp. lights at the front is on green, but it is strange I cannot connect from my pc to the box. When I click the connect and connect the AC, the box return the signal, and the connection stops where it says "upload completed,waiting for acknowledge It won't go any further than that.
I hope I haven't done anything wrong, but can anyone help with this , what i need to do
[IMG=http://lookpic.com/c1/t2/3447/q6HQ7AO5.png]
Thanks!
Thanks!
after sucess..connect to box just put in straight release original soft from dmm orig page...after flash I am restart box(unplug/plug power back)i had msg on display not ca found .... i am re-flash via other dream up vers.1.3.3.4 patched...first i am flash to box image witch was build for clone box...and last flash back bl/ssl witch was for that clone box ...and running ok to today... and same way i am fix dm witch had problem with green screen (usually problem with capacitors
