dreambox won't connect to DreamUp [help]
  • riadh2010
    • Apr 2011
    • 30
    Hi all!
    I flashed my dreambox dm500s with pli-Jade last night, and didnt worked fine.
    now i got just blue screen on tv
    My problem is that the box won't connect to DreamUp. lights at the front is on green, but it is strange I cannot connect from my pc to the box. When I click the connect and connect the AC, the box return the signal, and the connection stops where it says "upload completed,waiting for acknowledge It won't go any further than that.
    I hope I haven't done anything wrong, but can anyone help with this , what i need to do
    [IMG=http://lookpic.com/c1/t2/3447/q6HQ7AO5.png]
    Thanks!
  • smoggie
    • 863
    try a different version of dreamup
    • riadh2010
      • Apr 2011
      • 30
      i did tray 6 of them noon worked
      • mtv1
        The Stig PT
        • 4413
        you shure try mine m8 image and dreamup
        "My problem is that the box won't connect to DreamUp. lights at the front is on green, but it is strange I cannot connect from my pc to the box. When I click the connect and connect the AC, the box return the signal, and the connection stops where it says "upload completed,waiting for acknowledge It won't go any further than that. "
        • riadh2010
          • Apr 2011
          • 30
          i well try it and let you know if work it
          • riadh2010
            • Apr 2011
            • 30
            i try it yours do not work as well like the other
            • piopat
              • 708
              maybe it cant flash because the memory is full ,try a flash erase .flash erase is just above flash in dreamup ,all you do is click on it and it will erase the image in seconds . if you have used a few different images you will need to flash erase again for each image ,then try an flash again as normal.
              i love it when a dreambox comes together.
              • riadh2010
                • Apr 2011
                • 30
                have look at the pic were he stops
                • tw87
                  • Jun 2009
                  • 233
                  You need a new power supply mate, fixed mine
                  IF YOU THINK MY POST HAS BEEN HELPFUL PLEASE HIT
                  • andy91
                    • Aug 2010
                    • 3583
                    Try it with the network ticked or tick the network after if you get a ping and use ethernet with the null modem cable.
                    Trial and error im afraid.
                    Andy.
                    • stevko7738
                      may be help
                      hello. i had similar problem like first post.
                      i download last dream up from original web page dream multi media i am not sure was version 1.3.3.7 maybe and release soft....
                      connect with no problem but my box is clone after sucess..connect to box just put in straight release original soft from dmm orig page...after flash I am restart box(unplug/plug power back)i had msg on display not ca found .... i am re-flash via other dream up vers.1.3.3.4 patched...first i am flash to box image witch was build for clone box...and last flash back bl/ssl witch was for that clone box ...and running ok to today... and same way i am fix dm witch had problem with green screen (usually problem with capacitors exploded and flash stage broken ---mean green screen--- memory full just reflash with open pli image.you must be a sure witch bl is it) maybe help or no but try ....good luck
                      • daveshell
                        Try Power Supply m8.
                        • Mr S
                          • Feb 2010
                          • 52
                          Have you tried flashing via the web by any chance? (Altough if you have erased the previous image, it wont work now)
                          Also disable any programs, firewalls etc and ensure you rs232 cable is properly plugged in on the box and the pc. Other than that I would try diffferent versions.
                          • cjs5ub
                            • 46
                            you need the pached version of dream up for it to work if your 500 is a clone ...this should work for you
