i have flashed dreambox 500s with nabilosat darkstar2 i have set the time config for uk,but the transponder time is out by 1 hour behind,how do i adjust transponder time to coorospond with actuall time of day..thanks in advance
transponder time 28.2 east
press menu button /then choose setup (its number 6 on my box )/then choose system settings (thats number 3 on my box )/then choose time settings /you should then see timezone configuration and time correction . in time zone you will see the time zone highlighted in red (press the ok button ) then use the up and down button to choose your time zone and press the green button to save . or go into time correction and manually enter the time and date using the remote control ,use the up /down /left buttons to highlight the time press ok to edit and when you have finished editing press the green buton to save .i love it when a dreambox comes together.
i have done this several times,it is not the time zone or time setting thats not the problem,it is the transponder time that is not correctly set,it is 1 hour behind,i was under the impression that transponder time would set time automatically,in this case it is not..Comment
you could try a factory reset and start again and set the timezone that way ,if you get the same issue after that you may have a glitch in your image . or you could reflash your box ,in the last link of my signature area you can download a working nabilo image for a dm500s or use a different image .i love it when a dreambox comes together.
thanks for all your help,but every darstar image i try seems to either have a issue with transponder time or sat position being wrong 28.4 east mainly which shows no channels..Comment
i have 3 boxes that use darkstar plus my mates box and have never had the problem you have .darkstar is an older image and the yes the satellite.xml file is missing a few frequencies but these can be added manually with the remote control .
im aware of the 24.2/28.4 issue with the satellites.xml file and i just added the missing frequencies manually and used the same satellite .xml file in all 3 boxes plus my friends box with no issues at all . or simply when installing new bouquets before installing them delete the satellite.xml file that comes with them ,the bouquets will then be installed and the box will retain your satellite.xml file .i love it when a dreambox comes together.
