DMS500, CAN'T GET ANY TVCHANELS
  • boursaloum1
    • Aug 2011
    • 8
    Hi, everyone, I have a dms 500 but can't get any tv chnnels, when I scan all it says is all known transponders scaned but lock is not possible, do I really need to do any settings to get some tv channnels. Please help this newbie.
    Thanks in advance
  • dOOds
    • Oct 2010
    • 50
    You are clearly trying to scan the wrong satellite.What satellite is your dish lined up on and what satellite are you trying to scan? please provide a bit more info and peeps mabye able to help you..Cheers.
    • tony2803
      • 266
      Thanks in advance
      what image is box flashed with ?.
      • Jo-Jo
        • 511
        menu setup service searching auto transponder scan select your satellite then scan
        • boursaloum1
          • Aug 2011
          • 8
          Hi, thanks I am trying to get W3A Eutelsat 7E, infact I have not watched any tv programme from it yet.
          Do I need to set up bouquets or anything?
          Thanks again
          • boursaloum1
            • Aug 2011
            • 8
            HI, it has Pli jade
            • tony2803
              • 266
              Thanks again
              ok,where are you residing [country],and what size dish are you using..
              • boursaloum1
                • Aug 2011
                • 8
                I am in the U.K Wales. and I am using a 60cm dish, just like the sky dish
                • smoggie
                  • 863
                  Is you dish pointing to W3A Eutelsat 7E. try scanning astra 28.2 to see if its aligned for that sat
                  • moca9
                    • Oct 2011
                    make sure u r in the right sat position
                    • boursaloum1
                      • Aug 2011
                      • 8
                      I enen tried connecting my sky dish to it, and I had 13 scramled chanels forn BSKYB, I do not know BSKYB.
                      Please help
                      • piopat
                        • 708
                        your dish is to small ,a 60cm dish is designed for say the sky satellite in the uk and the sky satelliite is a group of very strong satellites in the one location . a 60cm dish is too small ,if your in the uk depending on where you live the dish size will vary (the further north you are the bigger the dish you need ) but i would say some where between 90cm and a meter dish size give or take a bit .
                        • boursaloum1
                          • Aug 2011
                          • 8
                          Thanks very much, I 'll try to get a bigger dish.
