Sorry if this is not the correct section.
I have a DM500s (clone) and a stab motor. I am having problems controlling the motor with the DM.
For example, if I swing round to 16e it reaches the sat, clears the picture for a split second then rotates back to 1w, back to 16e, back to 1w and so on.
I have the settings set to goto x with the correct Long and lat....
I have updated the sat.xml file but it is still doing it, in fact it is getting worse - now it is starting to do this on 13e and 19e. The only sat it will go to without real problems is 28e.
Occasionally when you try to move from 13e to 19e it does nothing - image says it is moving but the dish stays put.
Once on the sats the strength etc is high (90%) with no ber.
I have a Nabilo image with (i think) The Captains settings loaded.
Is it worth trying a different image? Any suggestions gratefully recieved...
Elbow
Elbow
