Have i bricked my dm 500s
  • DAVEG50
    • Nov 2011
    • 6
    Hi i think i may have bricked my 500s , i am a bit of a newbie so obviously not too sure but when i used dreamset to try to transfer a bouquet to my box it said it had completed so i tried to reboot my box and all that happens now is the darkstar 2 image comes on for a couple of seconds on the screen and goes off again and thats all it does. any help much appreciated. cheers
  • smoggie
    • 863
    try leaving it switched off for awhile. can you connect to the boxes last known ip addy?
    • DAVEG50
      • Nov 2011
      • 6
      hi i have tried connecting through dreambox control centre and all seems ok there
      • j1mgg
        • Feb 2011
        • 61
        Best to re flash and use dream box edit to transfer over a bouquet.
        • total newby
          • Feb 2011
          • 183
          id go for a reflash
          • Elric
            V.I.P. soft lad
            • 853
            before going for a reflash..is there any services in
            • DAVEG50
              • Nov 2011
              • 6
              thanks for the replies looks like i will have to reflash my box then ,as i have left it off for about 4 hours now and nothing has changed.i paid somebody before to flash it so will have to purchase a null modem cable and do it myself this time,i think i know how to do it and i will let you know how get on. thanks again cheers
              • mark8393
                • 2305
                get cable for future use, but in meantime use flashwizard pro. i use this all the time, only use dreamup for major issues. worth a shot
                • DAVEG50
                  • Nov 2011
                  • 6
                  hi many thanks for all the replies and have finally reflashed and all seems ok now except when i do a transponder scan on the satellites i only get a small amount of channels for example on 13e i get about 113 channels as before it was about 1500 and on 28.2 about 50 channels and not even any sly channels even though the signal strengh is good on both. cheers
                  • ebmitie
                    • 94
                    snap, i have the same problem and its driving me nuts!! what image are you using?
                    • ebmitie
                      • 94
                      and i just found out how to do it correctly but will i remember what i did? its scaning now an taking 24 mins!! oncxe i figure it i'll post back
                      eb-
                      • DAVEG50
                        • Nov 2011
                        • 6
                        hi mate i am using darkstar 2 image hope you sorted yours and would be good to know how you did it cheers
                        • ebmitie
                          • 94
                          ok, this is it, menu, 6, 2, 4, ok, select astra28, ok, then put ticks on network search, and the next 2, save, then go back out and select automatic transponder scan, gets the lot.
                          i have same image but experimenting and mucking up, i cant recall having to do this first time round|||
                          • DAVEG50
                            • Nov 2011
                            • 6
                            thanks ebmitie just tried this but still no joy for me so looks like as dish problem cheers
