null modem help
  • john1111
    • 11
    null modem help
    can someone show me on ebay which cable i need to flash my dreambox with dream up my computer has female connector port so needs a male to fit in it and the dreambox has a male port so needs a female end to fit it i think either way i think i need a male to female null modem cable to flash my dreambox any links to items on ebay would be great thanks in advanced for your help and support im a complete newbie.
  • john1111
    • 11
    on ebay search type in this number 250939827238 or 200682869360 which one will be ok for me thanks am i on the right line.
    • Grizz
      • 1598
      how many pins in the port on your pc? are you sure you are not looking at a vga port? like below
      far as i know null modems are supposed to be female both sides of cable
      either way this one should do you, you can plug it into a usb port computer side
      250939827238
      • john1111
        • 11
        15 like you picture its not a desktop so only that port in your picture and the opposite port on the dreambox
        • john1111
          • 11
          i once used a adaptor i have not it was usb to male and connect that to null modem male to male and it used to work because i did a technomate with dark loader but ive lost the driver cd and it wont work with dream up now
          • benny/9
            • 1964
            a null modem cable has 9 pin female plugs on both ends
            and if your computer does'nt have a 9 pin serial port
            you also need a usb to serial convertor cable to use the
            null modem cable from a usb port on the computer
            Please Read Carefully!
            • john1111
              • 11
              ok which one should i buy on ebay then USB TO SERIAL NULL MODEM CABLE UPGRADE LEAD VISTA XP UK | eBay or Serial DB9 Female Null Modem to USB Eurovox DreamBox Echostar Upgrade Cable Lead | eBay
              • Grizz
                • 1598
                the port you are looking at is for an external monitor.
                buy this one for the usb
                • john1111
                  • 11
                  hi.
                  thanks ive got that but ive lost the drivers and downloaded someoff the internet but it wont find/connect to my dreambox the problem with my dreambox is that it just reboots after you set the timezone and press save what can i do now is there anyway to reset the box or something to its factory settings
                  • Grizz
                    • 1598
                    what image are you using?
                    there should be a "restore to factory settings" in the settings section
                    • john1111
                      • 11
                      hi
                      i cant access the settings menu i only get to the set timezone and when i press save it reboots the image has a gp image background if that helps i dont know much about the box
                      • john1111
                        • 11
                        new problem now i have loaded the software with the driver suggested and im stuck this is what ive been doing step by step
                        1 plug in adaptor to dreambox off
                        2 load dreamup via dmloader 1.14
                        3 com 4, connect, it says connection prepered now switch on the dreambox when i switch the dreambox on plug the power adaptor in,the message stays the same and nothing happens im stuck now.
                        im trying to reflash my dreambox got it from a friend and it boots to the menu where you choose tv pal and what timezone your in press save and just reboots everytime it has a logo behind it saying gp or something this must be the image any help would be great im at a loss now.cheers.
