can someone show me on ebay which cable i need to flash my dreambox with dream up my computer has female connector port so needs a male to fit in it and the dreambox has a male port so needs a female end to fit it i think either way i think i need a male to female null modem cable to flash my dreambox any links to items on ebay would be great thanks in advanced for your help and support im a complete newbie.
null modem help
how many pins in the port on your pc? are you sure you are not looking at a vga port? like below
far as i know null modems are supposed to be female both sides of cable
either way this one should do you, you can plug it into a usb port computer side
250939827238Last edited by Grizz; 11 January, 2012, 20:17.Comment
a null modem cable has 9 pin female plugs on both ends
and if your computer does'nt have a 9 pin serial port
you also need a usb to serial convertor cable to use the
null modem cable from a usb port on the computerLast edited by benny/9; 26 September, 2012, 20:32.Please Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
ok which one should i buy on ebay then USB TO SERIAL NULL MODEM CABLE UPGRADE LEAD VISTA XP UK | eBay or Serial DB9 Female Null Modem to USB Eurovox DreamBox Echostar Upgrade Cable Lead | eBayComment
the port you are looking at is for an external monitor.
buy this one for the usb
Serial DB9 Female Null Modem to USB Eurovox DreamBox Echostar Upgrade Cable Lead | eBayLast edited by Grizz; 11 January, 2012, 22:11.Comment
hi.
thanks ive got that but ive lost the drivers and downloaded someoff the internet but it wont find/connect to my dreambox the problem with my dreambox is that it just reboots after you set the timezone and press save what can i do now is there anyway to reset the box or something to its factory settingsComment
new problem now i have loaded the software with the driver suggested and im stuck this is what ive been doing step by step
1 plug in adaptor to dreambox off
2 load dreamup via dmloader 1.14
3 com 4, connect, it says connection prepered now switch on the dreambox when i switch the dreambox on plug the power adaptor in,the message stays the same and nothing happens im stuck now.
im trying to reflash my dreambox got it from a friend and it boots to the menu where you choose tv pal and what timezone your in press save and just reboots everytime it has a logo behind it saying gp or something this must be the image any help would be great im at a loss now.cheers.Comment
