Channel 5 not working on dm500s
  • mrblue
    • 568
    Channel 5 is not working on my dm500s. Either is 5usa/+1 and 5*/+1...
    Ive went into all services and there are five different channels for channel 5, Ive tried them all but just a black screen.
    I remember I had the same prob with espn and I just went to all services and used a different channel and added it to my bouquet.
    Not as simple as that this time, any ideas why, all other channels are working, and channel 5 is working on my sky plus box in the next room...
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    rescan and check again on all satellites...
    • mrblue
      • 568
      Will I loose bouquets or any settings by rescanning sat...?
      • delly007
        • May 2011
        • 54
        no u wont when the scan is done exit out of every thing, then press ok to bring up the channels list, then press the green button and go to new found then add the ones that are not working to where ever u had them in the first place then delete the ones that are not working.
        • smirnoff_rules
          • 8603
          no need to rescan its there in all channels (red button) theres 4 channel 5's the first one is open . menu and move mode and add to your channel list
          • potrobber
            • Mar 2010
            • 493
            hi
            doing a scan will only update the all sats list then check in there for channel five it will be updated
            then move it to entertainment group and do the same for your other missing channels
            or check and see if sgt flipflop has a updated channel list for enigma1 download it and load onto your box with dreamboxedit
            • AfyB
              • 144
              Potrobber nice to see you on here mate, can you give me a hand with my thread "cccam clients disconnecting", in fact any help would be much appreciated.
              • mrblue
                • 568
                I have done a scan and getting 566 567 568 569 and 848 as channel 5 but none are working. 5usa and 5* are also not working...
                • briangoo
                  • 284
                  channel 5
                  hi i had the same bother with ch5 last week. so i did a scan of 28east & found 2 of them working. i guess its a bit like the old eurovox which used to do the same & needed a update of channels that start play up
