dm500s blank screen
  • cmfable
    • Dec 2011
    • 106
    #16
    ok tried 3 versions and just get this in log
    23:05:47 box type: DM500
    goes no further....
    • mast
      • Nov 2010
      • 1027
      #17
      Have you got a dedicated com port.
      Regards
      • cmfable
        • Dec 2011
        • 106
        #18
        on my pc, only got 1 com port, and dreamup just shows com 1... im using a standard null modem cable, which works perfect on my other dreambox
        • mast
          • Nov 2010
          • 1027
          #19
          Ive attached a few different versions of dreamup with a couple of patched ones, try the dm500 one think thats the one that kick started the one I did.
          If and once connected erase the corrupted image a few times before flashing fresh image. After that any version of dreamup should connect in future should you need to.
          Regards
          • cmfable
            • Dec 2011
            • 106
            #20
            ill give that a try now
            • mast
              • Nov 2010
              • 1027
              #21
              goes no further....
              I was getting that before the one Ive attached managed to connect. Think thats the standard message while dreamup is waiting for response from box.
              Regards
              • cmfable
                • Dec 2011
                • 106
                #22
                nope none work, that dreamup dm500 just says in progress got startsequence, stating upload.... but its not doing anything
                • mast
                  • Nov 2010
                  • 1027
                  #23
                  Does the patched dm500 show a progress bar preparing the box. Are you powering box up after you press connect (Im sure you are but just making sure).
                  • cmfable
                    • Dec 2011
                    • 106
                    #24
                    in the progress bar it says startsequence, stating upload... but the bar is not moving and yes click connect then power up the box, is it totally dead?
                    • mast
                      • Nov 2010
                      • 1027
                      #25
                      Well stumped here not sure what else to suggest except in device manager is your comport com1.
                      • cmfable
                        • Dec 2011
                        • 106
                        #26
                        yeah, think its ebay and a new board for this box then?
                        • mast
                          • Nov 2010
                          • 1027
                          #27
                          Also you say youve used this comp before to flash your other box, is that a 500s too.
                          Just a long shot turn off firewall.
                          • cmfable
                            • Dec 2011
                            • 106
                            #28
                            yeah i used this comp to flash my other box, and why turn firewall off when im using null modem?
                            • cmfable
                              • Dec 2011
                              • 106
                              #29
                              i allways flash via cable
                              • mast
                                • Nov 2010
                                • 1027
                                #30
                                Yeh it was a longshot its just that thats only thing I could think of cos I remembered that my firewall was off so maybe was clutching at straws really, was kinda anxious to get your box going .
                                Aah well no other ideas im out now time to go to land of nod.
                                Regards
