dm500s locked up
  • potter36
    • 19
    dm500s locked up
    Hi all, ive just set up a dm500s new image and all is working. Came to show a friend and it locked up on me going through the channels. I've tried a reflash but still locked up remote not working and you can not switch off the dm500s on front panel so can't go through the menu as normal. i have had it woking once. Its definately the box, not the remote. would be greatful of any help as i'm stuck. I know how to set up cos of other boxes I've done previously.
  • pudzy
    • 206
    reflash with dreamup
    • potter36
      • 19
      I've already reflashed with dream up twice and still the same
      • smoggie
        • 863
        have a look for the erase flash in download section, flash that to box and then reflash your preferred image
        • potter36
          • 19
          ok will let you know results when tried. Might not be tonight though, had enough of it!
          • mast
            • Nov 2010
            • 1027
            Sounds like the power supply. If you got another psu then give it a try as even slightest drop in voltage on these psu make the box do wierd things.
            Regards
            • potter36
              • 19
              Tried the erase flash no joy. as for the power supply ive got two dm500s so ive tried the two types and still no joy. driving me me mad now.
              • smirnoff_rules
                • 8603
                try a different image ? have u tried commando 14.6
                • potter36
                  • 19
                  Tried diffrent image no joy in process of refund or replacement that the site as offered .
