I want to be able to use mt digital card in dm500. What files do i need to put there? i have cccam already inside but it seems i need more as the card is not being picked up. thanks
How do i make DM500S Accept sky digital card?
might be a silly question but are you putting the card in the correct way??
chip should be facing downPS3= krazylegz120282
if you like what people say please use the reputation or thanks button, dont just make a post to say thanksComment
Using White SKY Card with CCCam
You need to configure the card to use CCCam
NewCS 1.66-CCcam2.1.1 works just fine with a config change.
I understand CCCam is all you need but the install i select on sifteam does both!
Install attached files to their dirs and reboot, ensure the cam is running too !
/var/tuxbox/config/newcs.xml
/var/etc/CCcam.cfg
I cant take any credit as i picked this up an another forum sometime ago !Attached FilesComment
