just purchased a 500s
  • gigsy
    • Apr 2009
    • 15
    Hiya
    Would really appreciated some help
    I purchased it from dvbmonkey. Switched it on and it appears with the digital-kaos logo. I did a simple search for all the channels and it only found a handfull (uk). If i flash the thing with gemini 2.0 will it sort the problem out and find all the channels that are available
    your help would be most appreciated
  • mtv1
    The Stig PT
    • 4413
    http://www.digital-kaos.co.uk/forums...-28-2-a-41015/ have a look here m8 good luck
    • gigsy
      • Apr 2009
      • 15
      thanx matey for the swift response. I for some reason pointed it to 19.2E and so it came back with majority of the freebie channel and the odd disney channel. during the inital setup i chose the basic setup with 1 lnb, is that where i may have gone in the wrong direction?
      • DavyT1
        • Jun 2009
        Dreambox 500s
        Gigsy, i have the same prob as you, how did you get on wi ur prob? Did u have to flash a new image. I thot i'd just bought an expensive freeview box when i kicked mine up. i was told it was just a plug and play and u get all channels. Maybe i mis-heard and i was told here ya mug away and play.
        • firestorm
          • 1550
          if you are after sky on 28e you will only get free channels as sky is not hacked in fact not a lot is these day only digi on 1west opens with keys but that going to change soon
          • gigsy
            • Apr 2009
            • 15
            hi
            im going to flash mine with gemeni 4.2 and take it from there, as u say at teh moment its just a free view box. The guys on the this site are awesome, they provide so much information. Much appreciated
            • cauliflower69
              • 261
              M8 use the latest PLi Jade image very stable and one of the best for dreambox streaming etc
              • kirit
                • Oct 2008
                • 68
                the post that you were referred to was 1 that i made a few days ago- im still trying to sort out the problem.
                firstly you need to be going for Astra 28.2.
                also you should not reflash your box with any gemini images- i would use jade PLi as my image of choice- it has access to updated channel lists especially for astra 28.2
