which two power pins do i use to power a PC fan to help keep my dreambox cool as it des seem to get extremely hot..
dm500 PC fan install
have you read this..???
also how is it hot..?? have you something on top of the box, blocking the air slots..??
the fan has a blue LED.. right up your street
There is nothing on top of the receiver but the case is really hot So i removed the case..cheers for the link..i had seen it before but couldnt find the thread again..cheers
___________________
In the good old days, I hadDM800s HDOpenbox S10
TM500
DM500s
90cm FortecStar dish
Maxx 110cm Dish
Technomate 2300 Motors
sigpicComment
all done using a fan from my PC..it had three wires[red/black/white] but i only used the red and black! whats the white one for?
___________________
TM500
DM500s
Maxx 110cm Dish
sigpicComment
this is probably a real dumb question but which way should the fan face? towards the IBM chip or away from it? so like this |> or like |<...the line is the chip..arrow is direction of wind being pushed
___________________
TM500
DM500s
Maxx 110cm Dish
sigpicComment
.. yes it is..
unless you just want a cold case then make sure the direction of the wind is over the circuitry..
its the motherboard and components getting hot that will cause you a problem..
Well, i didnt use dm 500 for one year now, beacuse of hight temp isnide it, which caused freezing of picture. Now I would like to add fan from pc inside, where should I solder the red wire, and where to solder black one?
well i did tell u im stupid
