goto to start then run then cmd the ipconfig. Get you ip address ie 192.168.0.69. When you use dream up you give the dreambox a higher ip address ie 192.168.0.75
Are you not using a null modem cable and dreamup for the flash? You can then set up an IP on the dreambox and flash it in future over your network with flashxp.
