No image on DM500 clone
  • unsuported
    • Aug 2009
    cheking the the ip address on my DM by mistake i disconneted from the power,turn back on & no image,what can i do? any suggestion
  • rapscallion
    • 141
    Use dream up to put image on
    • unsuported
      • Aug 2009
      the problem is how i know what's the ip on the DM
      • rapscallion
        • 141
        goto to start then run then cmd the ipconfig. Get you ip address ie 192.168.0.69. When you use dream up you give the dreambox a higher ip address ie 192.168.0.75
        • socktug
          • Jun 2009
          • 38
          Are you not using a null modem cable and dreamup for the flash? You can then set up an IP on the dreambox and flash it in future over your network with flashxp.
          • unsuported
            • Aug 2009
            flashed already & no image any tips
            • lone
              • Aug 2009
              • 18
              You may have to reflash with dreamup using null modem cable. then try other image
