Flashing a DM600-PVR without null modem cable
  • ianmac
    • Oct 2008
    • 922
    Is there a way that I can flash my DM600-PVR without using a null modem cable?
    Via the Dreams hard drive or something, or like I can with my Dbox2 by Ftp the image into the box's temp directory.
    I cannot believe that I have got 3 Pc's & 3 laptops, but not one of them has got a bl**dy serial port.
    I went & got a (Usb to serial) from Maplin & found out that the serial end of it was a female socket (not male) + also reading the other threads on here about the usb/serial leads, it seems there's a lot of problems with the drivers to make it work.
    Any other suggestions would be helpful.
    Ian
  • Saltire
    • 1361
    Ian
    mate, i had same problem as you, i had several of them stupid serial to usb converters and none worked for me, i hear they work better on windows xp though, might be true.
    in the end i just bought an old shiot second hand lappy for a few quid and it had a serial port, and thats what i use now, it has xp on it, sorry i couldnt help more,
    • smirnoff_rules
      • 8603
      it u connect to the internet ( router ) and u have vista it will show in networks and u can open up the files and add an image into tmp and or backup and rename to root.cramfs.img and go into update image and click on manully on the dreambox and it will install that image ,, if l remember right
      • ianmac
        • Oct 2008
        • 922
        Thanks for the quick reply Thomson. (in under mins)
        But sadly not what I wanted to know :-(
        When I dug out my old 8 yr old laptop out the loft, I was hoping that it had a serial: but no..
        Oh well back to the drawing board...
        Ian
        • ianmac
          • Oct 2008
          • 922
          Hi Smirnoff
          Sorry crosspost.
          I did ftp the image to the temp & thought there would be a way to flash it from there, but could not see 1.
          You mean just rename the .nfi to img?
          • smirnoff_rules
            • 8603
            Hi Smirnoff
            Sorry crosspost.
            lm sure its image m8
            • Curious123
              • 2591
              What about usin g the telnet option?
              1. In the telnet window, type the following, pressing <return> at the end of each line.
              mount /boot -o remount,rw
              rm /boot/*
              reboot
              2. You should now get a message saying that the Dreambox is rebooting.
              3. Wait a few seconds and then run Explorer (Firefox or whatever) and enter the ip address of the Dreambox in the address bar.
              4. On the screen that appears, choose the 'Upgrade firmware' option, find the .nfi file and click the 'Flash' button.
              5. Once the progress bar reaches 100%, reboot the box
              Done
              • smirnoff_rules
                • 8603
                my harddrive back was this m8
                http://rapidshare.com/files/120358838/backup_image.600.fix_20080413.rar
                but in temp im sure this img
                • ianmac
                  • Oct 2008
                  • 922
                  Did not see any .img images for the DM600, only .nfi.
                  I am trying to flash with this: "pli-jade3-dm600pvr-20090627-6494.nfi".
                  Will have another look 2morow for a .img..
                  Ian
                  • smirnoff_rules
                    • 8603
                    Ian
                    just rename the file m8
                    • ianmac
                      • Oct 2008
                      • 922
                      rm /boot/*
                      reboot
                      Done
                      Thank Curious.
                      That looks a good way, can I use "Dreambox Control Center v2.95" and the telnet in there?
                      Ian
                      • Curious123
                        • 2591
                        Thank Curious.
                        Ian
                        I have never used DCC but I assume you could use DCC, I prefer to use the windows telnet.
                        • ianmac
                          • Oct 2008
                          • 922
                          Got that file thanks Smirnoff..
                          • smirnoff_rules
                            • 8603
                            thats mr dudes image and the most stable one l have ever used m8
                            • ianmac
                              • Oct 2008
                              • 922
                              Have not used telnet since the old Dos days,
                              would not know how to now, could not even see the program in my windows 7,
                              or is it through the windows command prompt?
                              But I did it see in the DCC program.
