Dreambox DM500S Black Screen!!! :(
  • tariqz118
    • Mar 2010
    • 49
    Hi there everyone i was just watching a channel on my dreambox dm500s when the box completley froze. so i turned it off from the back and turned it back on and now all i get is a black screen, the standby light is green? someone please help me fix this thanks
  • opsmonkey
    • 5379
    hi mate.. i had this when i returned home tonight.. dead easy fix..
    unplug box from wall and remove all cables, SCART, Ethernet, Audio etc.. Connect Null Modem cable, run DreamUP on your PC / Laptop then go through the process of flashing an Erase.img (zipped file below).. takes about 13 minutes, then re-flash your backup.img ( i take it you made one..??)
    If you dont have a backup.img then you will need to re-flash an image like Gemini 4.2 or Pli..
    That will fix it
    • tariqz118
      • Mar 2010
      • 49
      ok mate i will give it a try thanks for your speed reply btw
      • tariqz118
        • Mar 2010
        • 49
        Thanks opsmonkey worked a treat
        • pepe17
          • Mar 2010
          • 5
          I have the same problem.
          I tried to flash my dm 500s with pli-jade using flash wizard but it stacked on 84%.so i close it and restart but now doesn't detect the box.I tried to flash using dreamup and the following msg comes:
          "connection prepared,now switch on the dreambox!"
          I switch on the box
          "upload complete,waiting for acknowledge.."
          then after a while another msg comes
          "Box does not answer,attach aborted!"
          Fro here I cant do any thing.
          Pls help on that!
          many thx
          • dank76
            • 745
            I can't get in the work where do u put erase on dream up??
            • dundee64
              • Dec 2011
              • 5
              only getting fta channels
              i had to reflash my dreambox after someone factory reset mine now i only get fta channels dont get any other been at it all week its its open-pli with mgcamd thnx if you can help im climbing up the walls here
              Last edited by dundee64; 17 December, 2011, 05:55. Reason: never said model its a 500-s
              • Elric
                V.I.P. soft lad
                • 853
                you might need to contact the server provider,and get server details
                • pokey2929
                  • Jun 2012
                  same problem
                  i can upload some images but i can't other i will try the erase
                  • siki1
                    Have had the same problem, hopefully this will work.
                    • edone4972
                      • Nov 2012
                      Dream box 500 flash
                      Any advice on how i can flash my dreambox and how i can obtain all channels
                      • sticky1980
                        • Aug 2013
                        I also have problems with black screen on dm500s, hope this post will help
