Does someone has this TP-LINK MODEL TL-WN821N VER2.6 usb stick working with a dreambox? Thanks
Thanks for the reply. I have a db 800 hd clone. When i go to the network section in my db i do not have the wifi option. So if the same usb stick works for u i think my problem is the image i am using. Can u pls tell me how u installed it, what model of db u have, if clone or not and what image u have installed.
CheersComment
I have just bought the 2.8 version of this adapter from amazon but i can not get it to work either on my clone dm box.
The adapter is detected and i can configure it from the network settings with all the correct parameters but when i go to test the network, it appears the dm box is only testing the lan cable and not the wlan.
I noticed that 'the rock' has an original dm and not a clone. Perhaps that is why the adapter works on his dm and not on our clones...?
Perhaps we need to download and install the linux drivers onto our dm machines, if they exist.Comment
I have received a reply from tech support at tp-link. This is a link to the linux drivers for the adapter:
ar9170 - Linux Wireless
Does anybody know how to proceed from here?
You have to disable the lan conection, then your wireless will work. You don't need to download the tp-link drivers.I have just bought the 2.8 version of this adapter from amazon but i can not get it to work either on my clone dm box.
Hi Gosee,
What image are you running for this to work?
My 54g adapter with gemini 5.1 works okay but i get no joy with my 300n adapter.
In the gemini 5.1 image the drivers are there only for the 54g adapters.Comment
dongle
hi people i have had (many)....dm800hd running on wireless via the tplink dongle, in order to enable this function you will need to buy the compatible dongle with right chipset (search forum...) and then enable this in kernal module and then plug dongle in and reboot box you will then need to go into network setup and enable wireless lan,enter wireeless security and there you are.
I've been trying to setup one of these for someone on a clone box running Blackhole V12 without success. In Kernel modules, it shows that RT73 is running, but there is no option for wireless in network settings either with wired LAN active or disabled. I've tried the dongle in both USB sockets.
Does anyone have a dongle working with v12 or are you using a different version?Comment
Same here, ive tried everything. It just wont show up in the network menu.Comment
@12qw - you mentioned it is working with gemini 5.1...do you have an original or clone dm800? do you have "kernel modules" listed in your blue panel -> settings? ....
I have a clone dm with gemini 5.1 but not able to enable wlan bc i dont have "kernel mdules"...Comment
it works fine for me on v12
when you go to network, what do you get?Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cable
screw you nag3
