DM 500S DEAD
  • zaf786
    • 327
    DM 500S DEAD
    Hi if some one can assist i have dm500s running edg nemesis image it has just gone of the power led comes on green after few minutes goes of can not connect with dreamup either is the bootloader gone any help will be preciated
  • trent1579
    • Oct 2010
    • 68
    hi,
    check all connections,check your emu settings are correct
    do you have a blue screen?,you most probably need to do a forced flash with dream up if so.
    if you have a desktop pc use a null modem cable
    if you have a laptop you will need a usb to serial adapter (which is compliant with your operating system i.e xp vista windows7) and a null modem cable
    if your pc can still get a ip address from your dreambox use flash wizard 6.3
    • opsmonkey
      • 5379
      the 500S doesn't have a bootloader..
      Reflash with DCC it should be fine
      • gonewild
        • Dec 2010
        I have faced the same problem and it was solved using updated drivers
        • opsmonkey
          • 5379
          drivers..? what are you on about
