Hi if some one can assist i have dm500s running edg nemesis image it has just gone of the power led comes on green after few minutes goes of can not connect with dreamup either is the bootloader gone any help will be preciated
DM 500S DEAD
hi,
check all connections,check your emu settings are correct
do you have a blue screen?,you most probably need to do a forced flash with dream up if so.
if you have a desktop pc use a null modem cable
if you have a laptop you will need a usb to serial adapter (which is compliant with your operating system i.e xp vista windows7) and a null modem cable
if your pc can still get a ip address from your dreambox use flash wizard 6.3
