Trouble flashing 500s with dreamup
  • garry1312
    • Oct 2010
    • 2178
    #16
    i bought the null from cabling4less.com and god i cant mind were the adaptor was from but it said it was compatable for sat recievers including dreamboxes.
    any links would be great guys. thanks
    Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
    • garry1312
      • Oct 2010
      • 2178
      #17
      is this the right null cable guys:
      1.8m DB9 Null Modem Cable (F-F)
      • garry1312
        • Oct 2010
        • 2178
        #18
        right guys i tried using Iport instead of dreamup and after a few attempts i got this far:
        Opening COM port
        Connecting to receiver....
        Receiver found!
        Model Illuminati I-1
        Sending flash loader
        Waiting for flashloader
        Then it didnt go anywhere. If i get this again is it just a case that maybe you have to wait for awhile?
        • andy91
          • Aug 2010
          • 3583
          #19
          Thats what you need below,try it with ethernet lead as well.
          2M NULL MODEM CABLE DB9 FEMALE to DB9 FEMALE on eBay (end time 31-Dec-10 08:14:16 GMT)
          • garry1312
            • Oct 2010
            • 2178
            #20
            Thanks but whats the difference between the cable been a 1.8M or a 2M surely that doesnt make any difference?
            • andy91
              • Aug 2010
              • 3583
              #21
              No difference at all mate,if you can just try it on a desktop pc rather than a laptop and you should be fine.
              Andy.
              • garry1312
                • Oct 2010
                • 2178
                #22
                its a desktop im using mate with no joy im using a usb-serial adaptor but as i dont have a serial port :/
                • andy91
                  • Aug 2010
                  • 3583
                  #23
                  That will be your problem,what you need is an older desktop pc with the correct com1 port.I tried an adapter and it didnt work for me either.
                  Either that or ask the forum for an adapter that def works.
                  Andy,
                  • garry1312
                    • Oct 2010
                    • 2178
                    #24
                    Up and running again guys thanks for all your help.
                    Got a old PC out from the back of a full cuboard wasnt even sure that it worked anymore but it did runs like crap the PC but did the job with Dreamup so it has a purpose now.
                    Thanks again.
                    • cgscott
                      • 3513
                      #25
                      BAckup your image when all setup then its a simple repeat process for a full backup. Lot easier than starting from scratch.
                      Serial ports take longer but i find it the much better way to do things. More reliable and less conflict when it comes to drivers updating etc.
                      Patience is a virtue.
                      • garry1312
                        • Oct 2010
                        • 2178
                        #26
                        have to agree mate the usb serial adaptor never worked for me i tried on xp and vista with no luck also tried so many versions or dreamup with the adaptor and iport. also tried different drivers. once i got the old desktop out worked first time on the serial port.
                        also created a back up
                        dont think ill be flashing anytime soon im happy with pli jade 3 should have just stuck to what im happy with but no doubt ill fancy a change again. but now ill be using dreamup
                        • the man
                          • 1660
                          #27
                          well done buddy,
                          • andy91
                            • Aug 2010
                            • 3583
                            #28
                            I thought that was your problem,i had exactly the same thing with mine.I thought buying an adapter for a laptop would be easier but i never got mine to work either yet my old 10 year desktop pc does it every time.
                            Glad you sorted it mate.
                            Andy.
                            • opsmonkey
                              • 5379
                              #29
                              my adapter works a treat on an old XP laptop (Toshiba Satellite)
                              bought it off eBay years ago.. (Jul 07)
                              Just checked the exact spec from my feedback and searched the same sellers shop..
                              This is the exact item i have and it works for me
                              USB to RS232 Serial Cable COM DB 9 Pin Male New Lead on eBay (end time 01-Jan-11 09:30:06 GMT)
                              I use it with this exact lead from the same supplier
                              http://cgi.ebay.co.uk/DB9-Female-DB9...item5196df0830
                              • paskolino
                                #30
                                I am looking for program called Iport.exe.
                                I got a cloned 600c but dream up wont work and have been told to get this .
                                If anyone has i would be gratefull if they could post.
