DM500s Hell Aborted by User upload
  • xeroxuk
    • Feb 2010
    • 4
    Hi Guys,
    I have read through the forum with regards to this issue that I am having with my DM500s box and tried everthing suggested still to no avail.
    I am trying to reflash my DM500s which was using a PLIjade image working fine until last week the box froze, so I decided to reflash it.
    When trying to reflash I get the same error over and over again with the following:
    PLIjade image
    NabiloSat Max Var image
    and I keep getting aborted by user about 10% of the way through.
    I tried to Flash erase and get the same error. Although when I leave the box for about 30Mins and then try to flash erase the erase does work.
    But the flasing of the image does not work at all keeps aborting no matter which version of dreamup I use.
    PC Setup:
    I am on win xp which was used to flash the same box many times before without any issues.
    Tried changing to a different PC same problem. Tried changing the Null Cable still the same problem.
    Versions of Dreamup used:
    2.1.8A
    1.3.2.1
    1.2.2.0
    1.3.2.1
    1.3.3.0
    1.3.3.1
    1.3.3.4
    1.3.3.5
    1.3.3.6
    All of them so far no Joy. The box always responds when serial and power are plugged in. But just unable to complete flash.
    Any help on this would be really appreciated.
  • Curious123
    • 2591
    Originally posted by xeroxuk
    Hi Guys,
    PLIjade image
    PC Setup:
    2.1.8A
    1.3.2.1
    1.2.2.0
    1.3.2.1
    1.3.3.0
    1.3.3.1
    1.3.3.4
    1.3.3.5
    1.3.3.6
    Try flashing this erase image first and then retrying the pli image.
    • zaf786
      • 327
      [QUOTE=xeroxuk;891408]Hi Guys,
      PLIjade image
      PC Setup:
      2.1.8A
      1.3.2.1
      1.2.2.0
      1.3.2.1
      1.3.3.0
      1.3.3.1
      1.3.3.4
      1.3.3.5
      1.3.3.6
      Thanks[/QUOTE
      try this version os dreamup
      • xeroxuk
        • Feb 2010
        • 4
        thanks for that mate, did try the erase file before but forgot to mention it.
        Tried it again same problem aborted by user!
        Any other ideas guys
        • xeroxuk
          • Feb 2010
          • 4
          tried the DreamUp version attached as well same problem.
          Flash Erase Works but same with image aborted.
          Log
          15:05:59 box type: DM500
          15:06:08 Ping result: OK, box is alive and speaking to us ;-)
          15:06:14 erasing complete flash (without bmon stage of course)...
          15:06:55 OK, flash erased
          15:07:04 Uploading file to box...
          15:07:15 ERROR , upload aborted!
          cant think of what else it could be?
          • plasterer
            • 1631
            Wot OP system you useing
            Is it a 232 cable your using or adaptor
            Try a diff PC
            Hope this helps ..............Paul
            PAUL
            • Mjolinor
              V.I.P. VIC
              • 1093
              I thought PLI updated it self from the menus, assuming it does boot that is.
              • xeroxuk
                • Feb 2010
                • 4
                Thanks for all the replies, appreciate it.
                OS - Windows XP SP3, also tried Windows XP SP2
                Using Null Modem straight to COM1 on two different PC's
                Also tried using Null Modem with Prolific USB on a Laptop. Same results on all 3 machines.
                I can flash erase on all 3 machines but cannot upload any image to the box without the dreaded Abort message.
                Any other ideas before i throw this in the snow! !
                • pudzy
                  • 206
                  hi, i reflashed a box b4 and got similiar problem to your.. same error came up all right.. now before i try to reflash it. i had noticed in setup menu. under service organising, service searching was missing. so i guess my problem was tuner... anyway i binned the box. but it looks to be a common problem now, clones again ?
                  • es33753
                    • Oct 2010
                    Im ES here.
                    Can i download the attached file as i also had problem about(Aborted BY User).
                    • es33753
                      • Oct 2010
                      Can anyone help
                      Tks....
                      • theet
                        Download zip file
                        [quote=zaf786;891550]
                        Hi Guys,
                        PLIjade image
                        PC Setup:
                        2.1.8A
                        1.3.2.1
                        1.2.2.0
                        1.3.2.1
                        1.3.3.0
                        1.3.3.1
                        1.3.3.4
                        1.3.3.5
                        1.3.3.6
                        Thanks[/QUOTE
                        I will try this zip file, because I have the same problem
                        • kbob
                          • 13
                          Have you tried a different null modem cable ? . Its worth a try , it happend to me and this turned out to be the reason.
                          • Shady
                            Shite Link King
                            • Dec 2010
                            • 6404
                            hes tried a different null cable..
                            maybe try telnet? can you connect to the box over ethernet?
                            • gsmtech
                              • 264
                              Try with a known good Null Modem cable andf DreamUp 1.3.3.4, this is the last version which works with clone boxes, I found any later versions had this issue "aborted by user" I recently built a new PC with Windows 7 ultimate x64 and while downloading different versions of dreamup I had this issue.
                              Works fine though with Dreamup 1.3.3.4. There is also a patched version dreamup which is reported to work.
