Bouquets & Picons
  • Danian
    • 35
    Bouquets & Picons
    All,
    I have found the latest Bouquets & Picons:
    for sly and I wanted to put them on my DM500S which is running Gemini_420_DM500_17122007...
    But there are 2 files, so:
    1.) Do i need to download both files?
    2.) How do i upload/install these on my DM500S
    3.) What directory do i need to upload/install them to?
    Thanks for your help...
    D
  • RuberDuck
    • 1724
    if you just want the channel settings then you only need the bouquets, to load them use dreamboxedit.
    • Danian
      • 35
      What are the picons then? what do they do? Sorry, very new to this...
      D
      • deffc0n
        • Aug 2009
        • 894
        Originally posted by Danian
        All,
        D
        Picon install folder box by ftp TC.
        • RuberDuck
          • 1724
          D
          a picon is a small programme icon of the channel. so when you change channel etc you will see a small picture in the info bar on your screen, depending on the skin your using.
          • Danian
            • 35
            Thanks for all you replies,
            However i have now managed to get the bouquet onto the DM500S, however if i press 101 on the remote, it doesn't take me to BBC one like it does on my sly box. How can i change the channel numbers so they are the same as sly, or am i doing something wrong?
            ALso still unable to work out how to get the picons onto the DM500S...
            D
            • Danian
              • 35
              OK,
              Just downloaded the lastest Silverfox0786 E1 SD 28.2E 20.01.2011 and opened it in DreamBoxEdit and got the attached error... What am i doing wrong...
              D
              • smok3y666
                • Sep 2009
                • 18
                I had that and just ignored it. My channels are setup okay like Sly.
                • Danian
                  • 35
                  OK, so if you press 101 on the control it takes you to BBC1, Like wise 103 it takes you to ITV?
                  For me to get BBC1 i have to press 1, and 3 to get ITV....
                  Would like to have the same as Sly, so 101 BBC1, 102 BBC2, 103 ITV, 104 Channel 4, 105 Five etc...
                  • Danian
                    • 35
                    OK, so if you press 101 on my sky control it takes you to BBC1, Like wise 103 it takes you to ITV?
                    For me to get BBC1 ON THE DreamBox I have to press 1, and 3 to get ITV....
                    Is that possible?
                    I still get loads of errors when uploading the bouquet... See attached images...
                    [/QUOTE]
                    • Danian
                      • 35
                      Is that possible?
                      These errors are caused by me ticking the picons box, if i uncheck that box it work fine...
                      So how do i get the picons on the DM500S
                      • RuberDuck
                        • 1724
                        i would transfer them manually. what image are you using ?. i use the openpli image and just replaced the picons i downloaded from their server with the ones by silverfox and they look truly great.
