Can Someone tell me how much time it takes to bringup dreambox using dreamup... I am trying to follwo the instruction:
Required
Note: I am using USB to RS232 with Db9 Gender changer as I dont have PC with Null port.
Any comments or suggestion welcome !!!!!!
Required
- Null Modem Cable (this is NOT the same as a serial or rs232 cable, although it looks the same)
- Image File (.img)
- DreamUp Program
- Disconnect all cables from your dreambox, including the power
- Connect the null modem cable to the dreambox and to your PC
- Load Dreamup.exe
- Click Connect and you will see a message like this
- Connect the power and the bootloader should be copied to the box
