Oscam + CCcam 2.1.3
  • davvo
    • Apr 2009
    • 666
    #46
    8888 admin mypass works for me for [webif]
    but some peeps have reported
    that to get into [webif]
    they used there
    dreambox name and password
    httpport = 16002
    httpuser = root
    httppwd = yourdreamboxpass
    try that
    • thered
      • Aug 2008
      • 4915
      #47
      Originally posted by davvo
      @thered
      you need to edit your configs
      ln var/tuxbox/config
      unzip the file below
      put these 3 files ln var/tuxbox/config
      - oscam.conf
      - oscam.user
      - oscam.server
      put your boxkey in oscam server file
      looks like this
      boxid = yourboxid
      ( boxkey is like this 12345678 and not like this 12 34 56 78 )
      put this N line in cccam cfg
      N: 127.0.0.1 12000 test1 test2 01 02 03 04 05 06 07 08 09 10 11 12 13 14 256
      restart oscam
      thats it
      you can log in to oscam via browser
      DM IP http://192.168.X.X:8888
      [webif]
      httpport = 8888
      httpuser = admin { you can change to what u like in config }
      httppwd = admin { restart oscam for change to take }
      i have added the files to oscam i have added the n line to cccam
      config files for both e1 and e2
      i have added the files to oscam i have added the n line to cccam but im not sure about box key my sky card is old and pick tv does not clear
      when i insert my DM IP 192.168.xx.xxx:8888 i also get a blank screen if i just insert my DM IP i get the dm web control panel
      am i barking up the wrong tree here as it seems this is for people with a new card that are sharing that card or will this sort out my shares i recieve as well
      if so how do i get my boxkey from my old card
      cheers
      • davvo
        • Apr 2009
        • 666
        #48
        what card have you got white or old blue card
        to get the boxkey for your white card
        look on bottom of sly box for serial number 17 digits
        input the 17 digits into Dreambox Config Creator
        this will generate a boxkey which is 8 digits
        then put the boxkey in oscam server file
        like this 12345678
        • u.s
          • 1011
          #49
          you don't need to enter the boxkey and you need to add the following under the [webif] section:
          httpallowed = 192.168.0.0-192.168.255.255
          assuming your internal network ip is 192.168.x.x
          • thered
            • Aug 2008
            • 4915
            #50
            like this 12345678
            i havent got my sky+ box i got shot of it my card is old now too its blue
            • thered
              • Aug 2008
              • 4915
              #51
              do i change the 2 x's to my dreambox ip or router
              cheers
              • davvo
                • Apr 2009
                • 666
                #52
                hows oscam reading the sly card with no boxkey
                if i remove my boxkey the picture goes
                im no expert on oscam only been using it a few days myself
                just passing on what i know
                • thered
                  • Aug 2008
                  • 4915
                  #53
                  just to verify i have change this in my oscam config
                  i entered my dreambox ip and restarted cam no joy at all
                  it goes green as if its cleared but it isnt a i think all others are ok just pick tv
                  • thered
                    • Aug 2008
                    • 4915
                    #54
                    hows the oscam reading the sly card with no boxkey
                    do i need the boxkey then even if i am viewing someone elses card or is this something they need to do at their end to share it
                    • davvo
                      • Apr 2009
                      • 666
                      #55
                      you only need the boxkey for your sly card
                      you dont need a boxkey if your viewing someone elses card
                      and you dont need a boxkey if your viewing redlight/stc card
                      cccam takes care of the receiving bit
                      • u.s
                        • 1011
                        #56
                        upgrade to the latest oscam.ppc
                        i can confirm that you do not need boxkey for your sly card
                        to test the webif add the following:
                        httpallowed = ip address of p.c
                        the httpallowed setting defines which i.p address can access the oscam webif, it can be a single ip (e.g 192.168.0.3) or a range of ips (e.g 192.168.0.3-192.168.0.50)
                        • thered
                          • Aug 2008
                          • 4915
                          #57
                          ahh so im wasting my time then it is my server who needs to update to oscam and change their configuration not me
                          i was just wondering also the password bit (it may come in handy in the future) do i need to change that in oscam config to my dreambox password or leave it as admin admin (which used to be the router password) or do i change it to my router password
                          ty
                          • davvo
                            • Apr 2009
                            • 666
                            #58
                            leave it to admin
                            mine is user admin
                            and i changed the pass to something different
                            and i left the port as 8888
                            i log in ok
                            • thered
                              • Aug 2008
                              • 4915
                              #59
                              leave it to admin
                              cheers m8 just to confirm it is the server not myself who needs to change it then?
                              • thered
                                • Aug 2008
                                • 4915
                                #60
                                duplicate please dlete
