Oscam + CCcam 2.1.3
  • zakdk
    • Jul 2010
    • 131
    #256
    Hi Davvo ,i transfer with dcc ftp file above to tmp folder on to my dreambox tranfer s ok but
    when done i press the green button on remote then the yellow button i get a pop up message :nothimg to install. You have to upload a del.tgz package in the /tmp directory before to install addons- what am i doing wrong??
    • davvo
      • Apr 2009
      • 666
      #257
      dont unzip it ftp it as it is
      shut down dcc and try again
      make sure it copies over
      • zakdk
        • Jul 2010
        • 131
        #258
        Hi davvo , transfered the unzipped file and instal was succesful then i exit but when i press the blue button on remote i can only select common interface and cccam 2.1.4 i can not see oscam ,am i doing something wrong again??
        • davvo
          • Apr 2009
          • 666
          #259
          reboot the box
          ftp into box
          usr/bin do you see oscam in there
          usr/camscript do you see oscam/cccam script
          • zakdk
            • Jul 2010
            • 131
            #260
            ...no oscam in usr/bin
            ...no oscam/cccam script in usr/camscript
            • davvo
              • Apr 2009
              • 666
              #261
              it did not install then
              try again
              or
              try manual install
              ftp the files one at a time to the right directorys
              unrar the file you downloaded to your pc
              start dcc
              ftp oscam and cccam to usr/bin 755
              ftp RemoveOscam2901+CCcam213.del to usr/uninstall 644
              ftp Ncam_Oscam2901_CCcam213.sh to usr/camscript 755
              ftp the whole folder config to var/tuxbox
              oscam conf/server/user attributes 644
              put this line in cccam cfg
              N: 127.0.0.1 12000 test1 test2 01 02 03 04 05 06 07 08 09 10 11 12 13 14
              • zakdk
                • Jul 2010
                • 131
                #262
                ..ill try again
                • zakdk
                  • Jul 2010
                  • 131
                  #263
                  ...great stuff i can see oscam now .
                  i cahanged default cam to oscam then went to pick tv but still not unscrambled ..does it nedd time to update__
                  • davvo
                    • Apr 2009
                    • 666
                    #264
                    have you select this Oscam2901/CCcam213
                    press ok on remote to restart oscam/cccam
                    do you have the files oscam conf/server/user
                    in var/tuxbox/config
                    is the n line in cccam cfg
                    press green on remote then red then servers
                    how many cards showing on 127.0.0.1 should say 1 card
                    • zakdk
                      • Jul 2010
                      • 131
                      #265
                      ...connected servers 0 online.
                      ..the rest is ..as above that you mention.
                      • davvo
                        • Apr 2009
                        • 666
                        #266
                        heres the very basic configs to get pick tv working
                        with your card
                        look in var/tubox/config
                        at the files below make them match
                        right click edit save and exit
                        reboot the box
                        oscam.conf
                        [global]
                        nice = -1
                        WaitForCards = 1
                        logfile = stdout
                        preferlocalcards = 1
                        saveinithistory = 1
                        [webif]
                        httpport = 8888
                        httpuser = admin
                        httppwd = admin
                        httpallowed = 127.0.0.1,192.168.0.2-192.168.0.100,192.168.1.2-192.168.1.100,192.168.2.2-192.168.2.100
                        # protocols
                        [newcamd]
                        key = 0102030405060708091011121314
                        port = 12000@0963:000000;12001@0963:000000
                        oscam.server
                        [reader]
                        label = slot1
                        protocol = internal
                        device = /dev/sci0
                        blockemm-u = 0
                        blockemm-s = 0
                        blockemm-g = 1
                        blockemm-unknown = 1
                        emmcache = 1,3,2
                        group = 1
                        caid = 0963
                        oscam.user
                        [account]
                        user = test1
                        pwd = test2
                        monlevel = 0
                        uniq = 0
                        group = 1,2
                        au = 1
                        caid = 0963
                        • zakdk
                          • Jul 2010
                          • 131
                          #267
                          ....all above are exactly the same.
                          ..should i uninstall oscam and start again???
                          • davvo
                            • Apr 2009
                            • 666
                            #268
                            did you set the attributes for each file
                            right click each file select attributes
                            set oscam and cccam to 755
                            RemoveOscam2901+CCcam213.del 644
                            Ncam_Oscam2901_CCcam213.sh to 755
                            oscam conf 644
                            server oscam 644
                            user oscam 644
                            reboot
                            • zakdk
                              • Jul 2010
                              • 131
                              #269
                              ...forgot too put the attributes for each one will do now...
                              • davvo
                                • Apr 2009
                                • 666
                                #270
                                also make sure you have installed the cccam that came with oscam
                                cuz the
                                camscript is setup for that
                                the
                                camscript is looking for cccam not cccam_ 2.1.4
                                like this
                                /usr/bin/oscam &
                                sleep 10
                                /usr/bin/CCcam &
                                if all the files are in the right place and you have selected
                                oscam/cccam it should work
                                i just put this same setup back on mine and worked straight away so you need to check your files
                                normally
                                i dont use cccam with oscam i use oscam on its own
                                with
                                dvbapi
