Oscam + CCcam 2.1.3
  • garry1312
    • Oct 2010
    • 2178
    #346
    well is there a way to set it to restart say every 24 hours when away from home on holiday. As if anything happens theres not a chance I would be able to even have someone else restart it as we do not stay close to friends or family.
    been running fine the last couple of days then as I said this morning got up and channels were not clearing on our receiver. Theres nothing up with the configuration of the files as I have had people check them over and over again and each time get told there fine.
    Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
    • Rodbouy
      • Jul 2010
      • 1320
      #347
      What did the log file say?
      The problem you have is, if OScam is stopping then you will not be able to log in to the WebIF so you would still have a problem and would be unable to restart it remotely.
      My setup I have my port 80 fwd to the router for remote access. I can then restart my box or restart the cardserver which solves most if not all problems.
      • braindead
        • 103
        #348
        I restart my server every day at 5am and it works perfect. Put the following lines in the crontab,
        00 05 * * * /sbin/shutdown -r now
        i.e . use putty to telnet into the server and type crontab -e then copy and paste the above line into the crontab and save. This will start the server every day @ 5 am
        • garry1312
          • Oct 2010
          • 2178
          #349
          I didnt have time to check I was heading out the door for work as the mrs said to me and just told her to restart oscam.
          • davvo
            • Apr 2009
            • 666
            #350
            a guy over at satpimps made a script to check if oscam was running every few mins
            and if not restart it
            i wiill look for it
            • garry1312
              • Oct 2010
              • 2178
              #351
              So I take it if I go on holiday I could add a cron manager plugin to my receiver. for that time so that if it did go down it would restart within a set time anyway.
              I just dont like the idea of being away, it goes down and theres nothing I can do about it. Least with a cron manager plugin running while away it should give me piece of mind?
              • garry1312
                • Oct 2010
                • 2178
                #352
                Originally posted by davvo
                ian over at satpimps made a script to check if oscam was running every few mins
                i wiill look for it
                Thanks mate much appreciated.
                Not to sure how scripts works and will this one work on receiver as the one sats gave me was more for a larger server I think.
                • davvo
                  • Apr 2009
                  • 666
                  #353
                  Found it on another forum. Haven't tested it myself yet
                  How to "Oscam check script"
                  here is a simple script which will check to see if oscam is running. If oscam has stopped running it will restart it automatically.
                  #!/bin/sh
                  process=`ps auxwww | grep oscam | grep -v grep | awk '{print $1}'`
                  if [ -z "$process" ]; then
                  echo "Couldn't find oscam running. Restarting server-binary" >> /var/log/oscam.check
                  nohup /usr/local/bin/oscam >> /var/log/oscam.log &
                  else
                  echo "oscam is still OK!" >> /var/log/oscam.check
                  fi
                  You must ensure that your oscam binary is indeed located in /usr/local/bin. If it isnt amend the script accordingly. Just configure cron to run the script say every 5 minutes & voila
                  • garry1312
                    • Oct 2010
                    • 2178
                    #354
                    Thanks Davvo.
                    So I will still need to install a cron manager on to the receiver?
                    • davvo
                      • Apr 2009
                      • 666
                      #355
                      which image you using
                      • Rodbouy
                        • Jul 2010
                        • 1320
                        #356
                        Garry just out of curiosity, why dont you use one of your 3 500s as the server?
                        • garry1312
                          • Oct 2010
                          • 2178
                          #357
                          There packed away mate no longer in use. THought I would give it a try on the SE as heard others saying there Oscam is running well on it, also gives me the option along the lines to add another card if I wish.
                          Also told that the server could run faster on the SE. Didn't totally agree with this as for aslong as I have looked in to servers on receivers I have heard the 500 does it well.
                          If I have anymore problems I will convert to a 500 but in the meantime it is still early days so I was expecting some teething problems.
                          Davvo I am using ramiMAHER-rm-dm800se-2011-11-01 #ssl84a
                          Nice image very stable cannot fault it, I am using Oscam 1.10 with it.
                          • faridbou
                            • Nov 2011
                            • 24
                            #358
                            salut: can some one cheque this for me i have find it in my usb dm image peterpan log file :
                            >> OSCam << cardserver started at Mon Nov 7 22:56:00 2011
                            2011/11/07 22:56:00 300162A0 s version=1.00-unstable_svn, build #4066, system=powerpc-tuxbox-linux, nice=-10
                            2011/11/07 22:56:00 300162A0 s client max. idle=120 sec, debug level=0
                            2011/11/07 22:56:00 300162A0 s max. logsize=unlimited
                            2011/11/07 22:56:00 300162A0 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=120 ms
                            2011/11/07 22:56:00 300162A0 s auth size=4800
                            2011/11/07 22:56:00 300162A0 s services reloaded: 0 services freed, 15 services loaded
                            2011/11/07 22:56:00 300162A0 s AES key length error .. not adding
                            2011/11/07 22:56:00 300162A0 s 0 AES key(s) added on reader cardreader-tntsat for 0500:030b00
                            2011/11/07 22:56:00 300162A0 s userdb reloaded: 0 accounts freed, 2 accounts loaded, 0 expired, 0 disabled
                            2011/11/07 22:56:00 300162A0 s signal handling initialized (type=sysv)
                            2011/11/07 22:56:00 300162A0 s can't open file "/var/tuxbox/config/oscam.srvid" (err=2), no service-id's loaded
                            2011/11/07 22:56:00 300162A0 s can't open file "/var/tuxbox/config/oscam.tiers" (err=2), no tier-id's loaded
                            2011/11/07 22:56:00 300162A0 s can't open file "/var/tuxbox/config/oscam.provid" (err=2), no provids's loaded
                            2011/11/07 22:56:00 300162A0 s can't open file "/var/tuxbox/config/oscam.ird" (errno=2) irdeto guessing not loaded
                            2011/11/07 22:56:00 300162A0 s monitor: disabled
                            2011/11/07 22:56:00 300162A0 s camd33: disabled
                            2011/11/07 22:56:00 300162A0 s camd35: disabled
                            2011/11/07 22:56:00 300162A0 s cs378x: disabled
                            2011/11/07 22:56:00 300162A0 s newcamd: initialized (fd=6, port=34001, crypted)
                            2011/11/07 22:56:00 300162A0 s CAID: 0500
                            2011/11/07 22:56:00 300162A0 s provid #0: 030B00
                            2011/11/07 22:56:00 300162A0 s cccam: initialized (fd=7, port=34000, crypted)
                            2011/11/07 22:56:00 300162A0 s radegast: disabled
                            2011/11/07 22:56:00 300162A0 s http thread started
                            2011/11/07 22:56:00 300162A0 s creating thread for device xabix...e.net slot 0
                            2011/11/07 22:56:00 300162A0 s creating thread for device /dev/sci0 slot 0
                            2011/11/07 22:56:00 300162A0 s waiting for local card init
                            2011/11/07 22:56:00 30859B50 h HTTP Server listening on port 8888
                            2011/11/07 22:56:00 31059B50 p proxy thread started (thread=31059B50, label=xabi....tme.net, server=xabix...e.net)
                            2011/11/07 22:56:00 31859B50 r reader thread started (thread=31859B50, label=cardreader-tntsat, device=/dev/sci0, detect=cd, mhz=357, cardmhz=357)
                            2011/11/07 22:56:00 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:56:00 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:56:00 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:56:03 300162A0 s init for all local cards done
                            2011/11/07 22:56:03 300162A0 s anti cascading disabled
                            2011/11/07 22:56:03 32059B50 c plain dvbapi-client granted (localuser, au=cardreader-tntsat)
                            2011/11/07 22:56:03 32059B50 c dvbapi: 8 entries read from oscam.dvbapi
                            2011/11/07 22:56:03 32059B50 c dvbapi: found pmt file /tmp/pmt.tmp
                            2011/11/07 22:56:03 32059B50 c dvbapi: [ADD PID 0] CAID: 090F ECM_PID: 0743 PROVID: 000000
                            2011/11/07 22:56:03 32059B50 c dvbapi: [ADD PID 1] CAID: 093E ECM_PID: 0195 PROVID: 000000
                            2011/11/07 22:56:03 32059B50 c dvbapi: new program number: 073A (090F:073A unknown)
                            2011/11/07 22:56:03 32059B50 c dvbapi: try pids again #1
                            2011/11/07 22:56:03 32059B50 c dvbapi: try pids again #2
                            2011/11/07 22:56:03 32059B50 c dvbapi: try pids again #3
                            2011/11/07 22:56:03 32059B50 c dvbapi: can't decode channel
                            2011/11/07 22:56:05 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:56:05 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:56:05 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:56:05 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:56:06 32059B50 c dvbapi: [ADD PID 0] CAID: 090F ECM_PID: 0743 PROVID: 000000
                            2011/11/07 22:56:06 32059B50 c dvbapi: [ADD PID 1] CAID: 093E ECM_PID: 0195 PROVID: 000000
                            2011/11/07 22:56:06 32059B50 c dvbapi: new program number: 073A (090F:073A unknown)
                            2011/11/07 22:56:06 32059B50 c dvbapi: try pids again #1
                            2011/11/07 22:56:06 32059B50 c dvbapi: try pids again #2
                            2011/11/07 22:56:06 32059B50 c dvbapi: try pids again #3
                            2011/11/07 22:56:06 32059B50 c dvbapi: can't decode channel
                            2011/11/07 22:56:10 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:56:10 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:56:10 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:56:10 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:56:15 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:56:15 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:56:15 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:56:15 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:56:15 32059B50 c dvbapi: stoping demux for pmt file /tmp/pmt.tmp
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1A74 PROVID: 030B00
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1A76 PROVID: 022610
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 168A PROVID: 023311
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 168B PROVID: 023315
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 168D PROVID: 023317
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A72 PROVID: 032920
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A75 PROVID: 032940
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A77 PROVID: 032830
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A78 PROVID: 043300
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A79 PROVID: 043330
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 168E PROVID: 023342
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A7A PROVID: 030B00
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 168D PROVID: 003317
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 168B PROVID: 003315
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 168A PROVID: 003311
                            2011/11/07 22:56:15 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 168C PROVID: 00A821
                            2011/11/07 22:56:15 32059B50 c dvbapi: new program number: 20AE (0500:20AE unknown)
                            2011/11/07 22:56:15 32059B50 c dvbapi: try pids again #1
                            2011/11/07 22:56:15 32059B50 c dvbapi: try pids again #2
                            2011/11/07 22:56:15 32059B50 c dvbapi: try pids again #3
                            2011/11/07 22:56:15 32059B50 c dvbapi: can't decode channel
                            2011/11/07 22:56:20 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:56:20 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:56:20 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:56:20 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:56:22 32059B50 c dvbapi: new program number: 1FDF (0000:1FDF unknown)
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1ABA PROVID: 030B00
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1ABC PROVID: 022610
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 16D0 PROVID: 023311
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 16D1 PROVID: 023315
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 16D3 PROVID: 023317
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1AB8 PROVID: 032920
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1ABB PROVID: 032940
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1ABD PROVID: 032830
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1ABE PROVID: 043300
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1ABF PROVID: 043330
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 16D4 PROVID: 023342
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1AC0 PROVID: 030B00
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 16D3 PROVID: 003317
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 16D1 PROVID: 003315
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 16D0 PROVID: 003311
                            2011/11/07 22:56:23 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 16D2 PROVID: 00A821
                            2011/11/07 22:56:23 32059B50 c dvbapi: new program number: 20AF (0500:20AF unknown)
                            2011/11/07 22:56:23 32059B50 c dvbapi: try pids again #1
                            2011/11/07 22:56:23 32059B50 c dvbapi: try pids again #2
                            2011/11/07 22:56:23 32059B50 c dvbapi: try pids again #3
                            2011/11/07 22:56:23 32059B50 c dvbapi: can't decode channel
                            2011/11/07 22:56:25 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:56:25 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:56:25 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:56:25 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:56:26 32059B50 c dvbapi: new program number: 1FDF (0000:1FDF unknown)
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1A74 PROVID: 030B00
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1A76 PROVID: 022610
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 168A PROVID: 023311
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 168B PROVID: 023315
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 168D PROVID: 023317
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A72 PROVID: 032920
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A75 PROVID: 032940
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A77 PROVID: 032830
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A78 PROVID: 043300
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A79 PROVID: 043330
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 168E PROVID: 023342
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A7A PROVID: 030B00
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 168D PROVID: 003317
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 168B PROVID: 003315
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 168A PROVID: 003311
                            2011/11/07 22:56:27 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 168C PROVID: 00A821
                            2011/11/07 22:56:27 32059B50 c dvbapi: new program number: 20AE (0500:20AE unknown)
                            2011/11/07 22:56:27 32059B50 c dvbapi: try pids again #1
                            2011/11/07 22:56:27 32059B50 c dvbapi: try pids again #2
                            2011/11/07 22:56:27 32059B50 c dvbapi: try pids again #3
                            2011/11/07 22:56:27 32059B50 c dvbapi: can't decode channel
                            2011/11/07 22:56:30 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:56:30 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:56:30 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:56:30 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:56:35 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:56:35 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:56:35 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:56:35 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:56:40 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:56:40 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:56:40 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:56:40 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:56:45 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:56:45 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:56:45 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:56:45 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:56:50 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:56:50 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:56:50 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:56:50 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:56:55 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:56:55 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:56:55 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:56:55 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:57:00 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:57:00 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:57:00 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:57:00 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:57:05 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:57:05 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:57:05 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:57:05 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:57:10 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:57:10 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:57:10 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:57:10 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:57:15 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:57:15 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:57:15 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:57:15 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:57:20 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:57:20 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:57:20 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:57:20 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:57:25 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:57:25 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:57:25 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:57:25 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:57:30 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:57:30 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:57:30 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:57:30 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:57:35 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:57:35 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:57:35 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:57:35 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:57:40 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:57:40 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:57:40 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:57:40 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:57:45 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:57:45 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:57:45 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:57:45 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:57:50 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:57:50 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:57:50 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:57:50 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:57:55 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:57:55 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:57:55 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:57:55 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:58:00 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:58:00 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:58:00 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:58:00 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:58:05 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:58:05 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:58:05 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:58:05 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:58:10 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:58:10 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:58:10 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:58:10 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:58:15 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:58:15 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:58:15 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:58:15 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:58:20 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:58:20 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:58:20 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:58:20 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:58:25 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:58:25 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:58:25 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:58:25 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:58:30 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:58:30 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:58:30 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:58:30 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:58:35 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:58:35 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:58:35 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:58:35 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:58:40 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:58:40 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:58:40 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:58:40 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:58:45 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:58:45 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:58:45 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:58:45 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:58:50 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:58:50 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:58:50 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:58:50 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:58:55 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:58:55 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:58:55 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:58:55 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:59:00 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:59:00 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:59:00 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:59:00 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:59:05 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:59:05 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:59:05 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:59:05 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:59:10 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:59:10 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:59:10 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:59:10 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:59:15 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:59:15 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:59:15 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:59:15 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:59:20 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:59:20 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:59:20 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:59:20 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:59:25 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:59:25 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:59:25 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:59:25 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:59:30 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:59:30 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:59:30 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:59:30 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:59:35 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:59:35 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:59:35 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:59:35 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:59:40 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:59:40 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:59:41 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:59:41 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:59:46 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:59:46 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:59:46 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:59:46 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:59:51 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:59:51 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:59:51 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:59:51 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 22:59:56 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 22:59:56 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 22:59:56 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 22:59:56 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:00:01 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:00:01 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:00:01 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:00:01 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:00:06 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:00:06 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:00:06 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:00:06 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:00:11 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:00:11 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:00:11 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:00:11 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:00:16 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:00:16 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:00:16 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:00:16 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:00:21 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:00:21 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:00:21 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:00:21 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:00:26 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:00:26 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:00:26 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:00:26 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:00:31 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:00:31 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:00:31 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:00:31 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:00:36 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:00:36 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:00:36 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:00:36 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:00:41 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:00:41 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:00:41 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:00:41 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:00:46 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:00:46 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:00:46 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:00:46 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:00:51 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:00:51 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:00:51 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:00:51 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:00:56 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:00:56 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:00:56 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:00:56 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:01:01 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:01:01 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:01:01 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:01:01 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:01:06 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:01:06 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:01:06 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:01:06 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:01:11 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:01:11 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:01:11 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:01:11 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:01:16 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:01:16 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:01:16 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:01:16 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:01:21 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:01:21 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:01:21 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:01:21 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:01:26 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:01:26 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:01:26 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:01:26 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:01:31 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:01:31 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:01:31 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:01:31 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:01:36 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:01:36 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:01:36 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:01:36 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:01:41 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:01:41 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:01:41 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:01:41 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:01:46 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:01:46 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:01:46 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:01:46 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:01:51 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:01:51 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:01:51 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:01:51 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:01:56 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:01:56 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:01:56 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:01:56 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:02:01 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:02:01 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:02:01 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:02:01 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:02:06 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:02:06 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:02:06 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:02:06 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:02:11 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:02:11 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:02:11 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:02:11 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:02:16 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:02:16 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:02:16 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:02:16 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:02:21 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:02:21 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:02:21 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:02:21 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:02:26 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:02:26 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:02:26 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:02:26 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:02:31 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:02:31 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:02:31 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:02:31 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:02:36 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:02:36 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:02:36 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:02:36 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:02:41 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:02:41 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:02:41 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:02:41 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:02:46 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:02:46 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:02:46 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:02:46 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:02:51 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:02:51 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:02:51 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:02:51 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:02:56 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:02:56 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:02:56 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:02:56 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:03:01 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:03:01 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:03:01 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:03:01 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:03:06 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:03:06 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:03:06 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:03:06 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:03:11 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:03:11 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:03:11 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:03:11 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:03:16 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:03:16 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:03:16 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:03:16 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:03:21 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:03:21 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:03:21 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:03:21 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:03:26 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:03:26 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:03:26 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:03:26 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:03:31 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:03:31 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:03:31 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:03:31 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:03:36 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:03:36 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:03:36 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:03:36 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:03:41 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:03:41 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:03:41 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:03:41 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:03:46 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:03:46 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:03:46 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:03:46 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:03:51 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:03:51 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:03:51 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:03:51 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:03:56 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:03:56 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:03:56 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:03:56 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:04:01 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:04:01 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:04:01 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:04:01 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:04:06 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:04:06 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:04:06 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:04:06 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:04:11 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:04:11 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:04:11 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:04:11 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:04:16 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:04:16 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:04:16 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:04:16 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:04:21 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:04:21 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:04:21 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:04:21 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:04:26 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:04:26 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:04:26 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:04:26 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:04:31 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:04:31 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:04:31 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:04:31 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:04:36 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:04:36 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:04:36 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:04:36 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:04:41 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:04:41 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:04:41 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:04:41 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:04:46 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:04:46 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:04:46 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:04:46 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:04:51 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:04:51 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:04:51 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:04:51 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:04:56 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:04:56 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:04:56 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:04:56 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:05:01 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:05:01 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:05:01 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:05:01 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:05:06 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:05:06 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:05:06 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:05:06 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:05:11 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:05:11 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:05:11 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:05:11 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:05:16 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:05:16 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:05:16 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:05:16 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:05:21 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:05:22 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:05:22 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:05:22 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:05:27 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:05:27 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:05:27 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:05:27 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:05:32 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:05:32 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:05:32 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:05:32 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:05:37 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:05:37 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:05:37 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:05:37 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:05:42 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:05:42 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:05:42 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:05:42 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:05:47 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:05:47 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:05:47 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:05:47 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:05:52 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:05:52 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:05:52 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:05:52 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:05:57 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:05:57 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:05:57 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:05:57 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:06:02 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:06:02 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:06:02 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:06:02 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:06:07 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:06:07 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:06:07 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:06:07 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:06:12 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:06:12 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:06:12 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:06:12 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:06:17 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:06:17 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:06:17 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:06:17 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:06:22 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:06:22 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:06:22 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:06:22 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:06:27 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:06:27 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:06:27 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:06:27 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:06:32 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:06:32 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:06:32 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:06:32 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:06:36 300162A0 s exit with signal 15
                            2011/11/07 23:06:36 300162A0 s cardserver down
                            >> OSCam << cardserver started at Mon Nov 7 23:06:39 2011
                            2011/11/07 23:06:39 300162A0 s version=1.00-unstable_svn, build #4066, system=powerpc-tuxbox-linux, nice=-10
                            2011/11/07 23:06:39 300162A0 s client max. idle=120 sec, debug level=0
                            2011/11/07 23:06:39 300162A0 s max. logsize=unlimited
                            2011/11/07 23:06:39 300162A0 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=120 ms
                            2011/11/07 23:06:39 300162A0 s auth size=4800
                            2011/11/07 23:06:39 300162A0 s services reloaded: 0 services freed, 4 services loaded
                            2011/11/07 23:06:39 300162A0 s AES key length error .. not adding
                            2011/11/07 23:06:39 300162A0 s 0 AES key(s) added on reader cardreader-tntsat for 0500:030b00
                            2011/11/07 23:06:39 300162A0 s userdb reloaded: 0 accounts freed, 2 accounts loaded, 0 expired, 0 disabled
                            2011/11/07 23:06:39 300162A0 s signal handling initialized (type=sysv)
                            2011/11/07 23:06:39 300162A0 s can't open file "/var/tuxbox/config/oscam.srvid" (err=2), no service-id's loaded
                            2011/11/07 23:06:39 300162A0 s can't open file "/var/tuxbox/config/oscam.tiers" (err=2), no tier-id's loaded
                            2011/11/07 23:06:39 300162A0 s can't open file "/var/tuxbox/config/oscam.provid" (err=2), no provids's loaded
                            2011/11/07 23:06:39 300162A0 s can't open file "/var/tuxbox/config/oscam.ird" (errno=2) irdeto guessing not loaded
                            2011/11/07 23:06:39 300162A0 s monitor: disabled
                            2011/11/07 23:06:39 300162A0 s camd33: disabled
                            2011/11/07 23:06:39 300162A0 s camd35: disabled
                            2011/11/07 23:06:39 300162A0 s cs378x: disabled
                            2011/11/07 23:06:39 300162A0 s newcamd: initialized (fd=6, port=34001, crypted)
                            2011/11/07 23:06:39 300162A0 s CAID: 0500
                            2011/11/07 23:06:39 300162A0 s provid #0: 030B00
                            2011/11/07 23:06:39 300162A0 s cccam: disabled
                            2011/11/07 23:06:39 300162A0 s radegast: disabled
                            2011/11/07 23:06:39 300162A0 s http thread started
                            2011/11/07 23:06:39 300162A0 s creating thread for device xabix...e.net slot 0
                            2011/11/07 23:06:39 300162A0 s creating thread for device /dev/sci0 slot 0
                            2011/11/07 23:06:39 300162A0 s waiting for local card init
                            2011/11/07 23:06:39 30859B50 h HTTP Server listening on port 8888
                            2011/11/07 23:06:39 31059B50 p proxy thread started (thread=31059B50, label=xabi....tme.net, server=xabix...e.net)
                            2011/11/07 23:06:39 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:06:39 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:06:39 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:06:39 31859B50 r reader thread started (thread=31859B50, label=cardreader-tntsat, device=/dev/sci0, detect=cd, mhz=357, cardmhz=357)
                            2011/11/07 23:06:42 300162A0 s init for all local cards done
                            2011/11/07 23:06:42 300162A0 s anti cascading disabled
                            2011/11/07 23:06:42 32059B50 c plain dvbapi-client granted (localuser, au=cardreader-tntsat)
                            2011/11/07 23:06:42 32059B50 c dvbapi: 8 entries read from oscam.dvbapi
                            2011/11/07 23:06:42 32059B50 c dvbapi: found pmt file /tmp/pmt.tmp
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1A74 PROVID: 030B00
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1A76 PROVID: 022610
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 168A PROVID: 023311
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 168B PROVID: 023315
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 168D PROVID: 023317
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A72 PROVID: 032920
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A75 PROVID: 032940
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A77 PROVID: 032830
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A78 PROVID: 043300
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A79 PROVID: 043330
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 168E PROVID: 023342
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A7A PROVID: 030B00
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 168D PROVID: 003317
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 168B PROVID: 003315
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 168A PROVID: 003311
                            2011/11/07 23:06:43 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 168C PROVID: 00A821
                            2011/11/07 23:06:43 32059B50 c dvbapi: new program number: 20AE (0500:20AE unknown)
                            2011/11/07 23:06:43 32059B50 c dvbapi: try pids again #1
                            2011/11/07 23:06:43 32059B50 c dvbapi: try pids again #2
                            2011/11/07 23:06:43 32059B50 c dvbapi: try pids again #3
                            2011/11/07 23:06:43 32059B50 c dvbapi: can't decode channel
                            2011/11/07 23:06:44 32059B50 c dvbapi: stoping demux for pmt file /tmp/pmt.tmp
                            2011/11/07 23:06:44 32059B50 c dvbapi: new program number: 1FDF (0000:1FDF unknown)
                            2011/11/07 23:06:44 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:06:44 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:06:44 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:06:44 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1A74 PROVID: 030B00
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1A76 PROVID: 022610
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 168A PROVID: 023311
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 168B PROVID: 023315
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 168D PROVID: 023317
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A72 PROVID: 032920
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A75 PROVID: 032940
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A77 PROVID: 032830
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A78 PROVID: 043300
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A79 PROVID: 043330
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 168E PROVID: 023342
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A7A PROVID: 030B00
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 168D PROVID: 003317
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 168B PROVID: 003315
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 168A PROVID: 003311
                            2011/11/07 23:06:46 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 168C PROVID: 00A821
                            2011/11/07 23:06:46 32059B50 c dvbapi: new program number: 20AE (0500:20AE unknown)
                            2011/11/07 23:06:46 32059B50 c dvbapi: try pids again #1
                            2011/11/07 23:06:46 32059B50 c dvbapi: try pids again #2
                            2011/11/07 23:06:46 32059B50 c dvbapi: try pids again #3
                            2011/11/07 23:06:46 32059B50 c dvbapi: can't decode channel
                            2011/11/07 23:06:48 32059B50 c dvbapi: new program number: 1FDF (0000:1FDF unknown)
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1ABA PROVID: 030B00
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1ABC PROVID: 022610
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 16D0 PROVID: 023311
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 16D1 PROVID: 023315
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 16D3 PROVID: 023317
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1AB8 PROVID: 032920
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1ABB PROVID: 032940
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1ABD PROVID: 032830
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1ABE PROVID: 043300
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1ABF PROVID: 043330
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 16D4 PROVID: 023342
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1AC0 PROVID: 030B00
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 16D3 PROVID: 003317
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 16D1 PROVID: 003315
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 16D0 PROVID: 003311
                            2011/11/07 23:06:49 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 16D2 PROVID: 00A821
                            2011/11/07 23:06:49 32059B50 c dvbapi: new program number: 20AF (0500:20AF unknown)
                            2011/11/07 23:06:49 32059B50 c dvbapi: try pids again #1
                            2011/11/07 23:06:49 32059B50 c dvbapi: try pids again #2
                            2011/11/07 23:06:49 32059B50 c dvbapi: try pids again #3
                            2011/11/07 23:06:49 32059B50 c dvbapi: can't decode channel
                            2011/11/07 23:06:49 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:06:49 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:06:49 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:06:49 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 0] CAID: 1811 ECM_PID: 1630 PROVID: 023311
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 1] CAID: 1811 ECM_PID: 1631 PROVID: 023315
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 1632 PROVID: 023317
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 3] CAID: 0500 ECM_PID: 1A18 PROVID: 030B00
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 4] CAID: 0500 ECM_PID: 1A19 PROVID: 022610
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A1B PROVID: 032920
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A1C PROVID: 032940
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A1D PROVID: 032830
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A1E PROVID: 043300
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A1F PROVID: 043330
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 1635 PROVID: 023342
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A20 PROVID: 030B00
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 1633 PROVID: 00A821
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 1632 PROVID: 003317
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 1631 PROVID: 003315
                            2011/11/07 23:06:51 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 1630 PROVID: 003311
                            2011/11/07 23:06:51 32059B50 c dvbapi: new program number: 20A4 (1811:20A4 unknown)
                            2011/11/07 23:06:51 32059B50 c dvbapi: try pids again #1
                            2011/11/07 23:06:51 32059B50 c dvbapi: try pids again #2
                            2011/11/07 23:06:51 32059B50 c dvbapi: try pids again #3
                            2011/11/07 23:06:51 32059B50 c dvbapi: can't decode channel
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 19C0 PROVID: 030B00
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 19BD PROVID: 022610
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 15D8 PROVID: 023311
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 15DA PROVID: 023315
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 15DB PROVID: 023317
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 19BF PROVID: 032940
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 19C1 PROVID: 032920
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 19C4 PROVID: 032830
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 19C5 PROVID: 043330
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 19C3 PROVID: 043300
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 15DC PROVID: 023342
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 19C7 PROVID: 030B00
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 15DB PROVID: 003317
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 15DA PROVID: 003315
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 15D8 PROVID: 003311
                            2011/11/07 23:06:53 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 15D9 PROVID: 00A821
                            2011/11/07 23:06:53 32059B50 c dvbapi: new program number: 1FD8 (0500:1FD8 unknown)
                            2011/11/07 23:06:53 32059B50 c dvbapi: try pids again #1
                            2011/11/07 23:06:53 32059B50 c dvbapi: try pids again #2
                            2011/11/07 23:06:53 32059B50 c dvbapi: try pids again #3
                            2011/11/07 23:06:53 32059B50 c dvbapi: can't decode channel
                            2011/11/07 23:06:54 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:06:54 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:06:54 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:06:54 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 0] CAID: 1811 ECM_PID: 1828 PROVID: 023311
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 1] CAID: 1811 ECM_PID: 1868 PROVID: 023315
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 2] CAID: 1863 ECM_PID: 18C8 PROVID: 023342
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 1848 PROVID: 023317
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 4] CAID: 0500 ECM_PID: 1728 PROVID: 032920
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1748 PROVID: 022610
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1688 PROVID: 032940
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1788 PROVID: 030B00
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 17A7 PROVID: 032830
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 17C7 PROVID: 042800
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 10] CAID: 0500 ECM_PID: 18A8 PROVID: 043330
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1888 PROVID: 043300
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 12] CAID: 0500 ECM_PID: 1789 PROVID: 030B00
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 1828 PROVID: 003311
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 1848 PROVID: 003317
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 1868 PROVID: 003315
                            2011/11/07 23:06:54 32059B50 c dvbapi: [ADD PID 16] CAID: 0100 ECM_PID: 1808 PROVID: 00A821
                            2011/11/07 23:06:54 32059B50 c dvbapi: new program number: 4284 (1811:4284 unknown)
                            2011/11/07 23:06:54 32059B50 c dvbapi: try pids again #1
                            2011/11/07 23:06:54 32059B50 c dvbapi: try pids again #2
                            2011/11/07 23:06:54 32059B50 c dvbapi: try pids again #3
                            2011/11/07 23:06:54 32059B50 c dvbapi: can't decode channel
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 0] CAID: 1811 ECM_PID: 163A PROVID: 023311
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 1] CAID: 1811 ECM_PID: 163B PROVID: 023315
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 163C PROVID: 023317
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 3] CAID: 0500 ECM_PID: 1A22 PROVID: 030B00
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 4] CAID: 0500 ECM_PID: 1A23 PROVID: 022610
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A25 PROVID: 032920
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A26 PROVID: 032940
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A27 PROVID: 032830
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A24 PROVID: 043300
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A28 PROVID: 043330
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 163E PROVID: 023342
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A29 PROVID: 030B00
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 163D PROVID: 00A821
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 163C PROVID: 003317
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 163B PROVID: 003315
                            2011/11/07 23:06:57 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 163A PROVID: 003311
                            2011/11/07 23:06:57 32059B50 c dvbapi: new program number: 1F44 (1811:1F44 unknown)
                            2011/11/07 23:06:57 32059B50 c dvbapi: try pids again #1
                            2011/11/07 23:06:57 32059B50 c dvbapi: try pids again #2
                            2011/11/07 23:06:57 32059B50 c dvbapi: try pids again #3
                            2011/11/07 23:06:57 32059B50 c dvbapi: can't decode channel
                            2011/11/07 23:06:59 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:06:59 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:06:59 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:06:59 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:07:04 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:07:04 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:07:04 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:07:04 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:07:09 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:07:09 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:07:09 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:07:09 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:07:14 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:07:14 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:07:14 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:07:14 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:07:19 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:07:19 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:07:19 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:07:19 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:07:21 32059B50 c dvbapi: [ADD PID 0] CAID: 090F ECM_PID: 1B6A PROVID: 000000
                            2011/11/07 23:07:21 32059B50 c dvbapi: [ADD PID 1] CAID: 093E ECM_PID: 0068 PROVID: 000000
                            2011/11/07 23:07:21 32059B50 c dvbapi: new program number: 1B62 (090F:1B62 unknown)
                            2011/11/07 23:07:21 32059B50 c dvbapi: try pids again #1
                            2011/11/07 23:07:21 32059B50 c dvbapi: try pids again #2
                            2011/11/07 23:07:21 32059B50 c dvbapi: try pids again #3
                            2011/11/07 23:07:21 32059B50 c dvbapi: can't decode channel
                            2011/11/07 23:07:24 31059B50 p xabi....tme.net restarting reader...
                            2011/11/07 23:07:24 31059B50 p xabi....tme.net configuration error!
                            2011/11/07 23:07:24 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/07 23:07:24 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/07 23:07:29 300162A0 s exit with signal 15
                            2011/11/07 23:07:29 300162A0 s cardserver down
                            >> OSCam << cardserver started at Tue Nov 8 10:07:48 2011
                            2011/11/08 10:07:48 300162A0 s version=1.00-unstable_svn, build #4066, system=powerpc-tuxbox-linux, nice=-10
                            2011/11/08 10:07:48 300162A0 s client max. idle=120 sec, debug level=0
                            2011/11/08 10:07:48 300162A0 s max. logsize=unlimited
                            2011/11/08 10:07:48 300162A0 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=120 ms
                            2011/11/08 10:07:48 300162A0 s auth size=4800
                            2011/11/08 10:07:48 300162A0 s services reloaded: 0 services freed, 4 services loaded
                            2011/11/08 10:07:48 300162A0 s AES key length error .. not adding
                            2011/11/08 10:07:48 300162A0 s 0 AES key(s) added on reader cardreader-tntsat for 0500:030b00
                            2011/11/08 10:07:48 300162A0 s userdb reloaded: 0 accounts freed, 2 accounts loaded, 0 expired, 0 disabled
                            2011/11/08 10:07:48 300162A0 s signal handling initialized (type=sysv)
                            2011/11/08 10:07:48 300162A0 s can't open file "/var/tuxbox/config/oscam.srvid" (err=2), no service-id's loaded
                            2011/11/08 10:07:48 300162A0 s can't open file "/var/tuxbox/config/oscam.tiers" (err=2), no tier-id's loaded
                            2011/11/08 10:07:48 300162A0 s can't open file "/var/tuxbox/config/oscam.provid" (err=2), no provids's loaded
                            2011/11/08 10:07:48 300162A0 s can't open file "/var/tuxbox/config/oscam.ird" (errno=2) irdeto guessing not loaded
                            2011/11/08 10:07:48 300162A0 s monitor: disabled
                            2011/11/08 10:07:48 300162A0 s camd33: disabled
                            2011/11/08 10:07:48 300162A0 s camd35: disabled
                            2011/11/08 10:07:48 300162A0 s cs378x: disabled
                            2011/11/08 10:07:48 300162A0 s newcamd: initialized (fd=6, port=34001, crypted)
                            2011/11/08 10:07:48 300162A0 s CAID: 0500
                            2011/11/08 10:07:48 300162A0 s provid #0: 030B00
                            2011/11/08 10:07:48 300162A0 s cccam: disabled
                            2011/11/08 10:07:48 300162A0 s radegast: disabled
                            2011/11/08 10:07:48 300162A0 s http thread started
                            2011/11/08 10:07:48 300162A0 s creating thread for device xabix...e.net slot 0
                            2011/11/08 10:07:48 300162A0 s creating thread for device /dev/sci0 slot 0
                            2011/11/08 10:07:48 300162A0 s waiting for local card init
                            2011/11/08 10:07:48 30859B50 h HTTP Server listening on port 8888
                            2011/11/08 10:07:48 31059B50 p proxy thread started (thread=31059B50, label=xabi....tme.net, server=xabix...e.net)
                            2011/11/08 10:07:48 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 10:07:48 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 10:07:48 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 10:07:48 31859B50 r reader thread started (thread=31859B50, label=cardreader-tntsat, device=/dev/sci0, detect=cd, mhz=357, cardmhz=357)
                            2011/11/08 10:07:51 300162A0 s init for all local cards done
                            2011/11/08 10:07:51 300162A0 s anti cascading disabled
                            2011/11/08 10:07:51 32059B50 c plain dvbapi-client granted (localuser, au=cardreader-tntsat)
                            2011/11/08 10:07:51 32059B50 c dvbapi: 8 entries read from oscam.dvbapi
                            2011/11/08 10:07:51 32059B50 c dvbapi: found pmt file /tmp/pmt.tmp
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1A74 PROVID: 030B00
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1A76 PROVID: 022610
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 168A PROVID: 023311
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 168B PROVID: 023315
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 168D PROVID: 023317
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A72 PROVID: 032920
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A75 PROVID: 032940
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A77 PROVID: 032830
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A78 PROVID: 043300
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A79 PROVID: 043330
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 168E PROVID: 023342
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A7A PROVID: 030B00
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 168D PROVID: 003317
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 168B PROVID: 003315
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 168A PROVID: 003311
                            2011/11/08 10:07:52 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 168C PROVID: 00A821
                            2011/11/08 10:07:52 32059B50 c dvbapi: new program number: 20AE (0500:20AE unknown)
                            2011/11/08 10:07:52 32059B50 c dvbapi: try pids again #1
                            2011/11/08 10:07:52 32059B50 c dvbapi: try pids again #2
                            2011/11/08 10:07:52 32059B50 c dvbapi: try pids again #3
                            2011/11/08 10:07:52 32059B50 c dvbapi: can't decode channel
                            2011/11/08 10:07:53 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 10:07:53 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 10:07:53 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 10:07:53 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 10:07:53 32059B50 c dvbapi: stoping demux for pmt file /tmp/pmt.tmp
                            2011/11/08 10:07:53 32059B50 c dvbapi: new program number: 1FDF (0000:1FDF unknown)
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1ABA PROVID: 030B00
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1ABC PROVID: 022610
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 16D0 PROVID: 023311
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 16D1 PROVID: 023315
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 16D3 PROVID: 023317
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1AB8 PROVID: 032920
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1ABB PROVID: 032940
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1ABD PROVID: 032830
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1ABE PROVID: 043300
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1ABF PROVID: 043330
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 16D4 PROVID: 023342
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1AC0 PROVID: 030B00
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 16D3 PROVID: 003317
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 16D1 PROVID: 003315
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 16D0 PROVID: 003311
                            2011/11/08 10:07:55 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 16D2 PROVID: 00A821
                            2011/11/08 10:07:55 32059B50 c dvbapi: new program number: 20AF (0500:20AF unknown)
                            2011/11/08 10:07:55 32059B50 c dvbapi: try pids again #1
                            2011/11/08 10:07:55 32059B50 c dvbapi: try pids again #2
                            2011/11/08 10:07:55 32059B50 c dvbapi: try pids again #3
                            2011/11/08 10:07:55 32059B50 c dvbapi: can't decode channel
                            2011/11/08 10:07:58 32059B50 c dvbapi: new program number: 1FDF (0000:1FDF unknown)
                            2011/11/08 10:07:58 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 10:07:58 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 10:07:58 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 10:07:58 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1A74 PROVID: 030B00
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1A76 PROVID: 022610
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 168A PROVID: 023311
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 168B PROVID: 023315
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 168D PROVID: 023317
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A72 PROVID: 032920
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A75 PROVID: 032940
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A77 PROVID: 032830
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A78 PROVID: 043300
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A79 PROVID: 043330
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 168E PROVID: 023342
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A7A PROVID: 030B00
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 168D PROVID: 003317
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 168B PROVID: 003315
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 168A PROVID: 003311
                            2011/11/08 10:07:59 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 168C PROVID: 00A821
                            2011/11/08 10:07:59 32059B50 c dvbapi: new program number: 20AE (0500:20AE unknown)
                            2011/11/08 10:07:59 32059B50 c dvbapi: try pids again #1
                            2011/11/08 10:07:59 32059B50 c dvbapi: try pids again #2
                            2011/11/08 10:07:59 32059B50 c dvbapi: try pids again #3
                            2011/11/08 10:07:59 32059B50 c dvbapi: can't decode channel
                            2011/11/08 10:08:03 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 10:08:03 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 10:08:03 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 10:08:03 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 10:08:08 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 10:08:08 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 10:08:08 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 10:08:08 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 10:08:13 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 10:08:13 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 10:08:13 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 10:08:13 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 10:08:18 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 10:08:18 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 10:08:18 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 10:08:18 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1ABA PROVID: 030B00
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1ABC PROVID: 022610
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 16D0 PROVID: 023311
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 16D1 PROVID: 023315
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 16D3 PROVID: 023317
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1AB8 PROVID: 032920
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1ABB PROVID: 032940
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1ABD PROVID: 032830
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1ABE PROVID: 043300
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1ABF PROVID: 043330
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 16D4 PROVID: 023342
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1AC0 PROVID: 030B00
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 16D3 PROVID: 003317
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 16D1 PROVID: 003315
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 16D0 PROVID: 003311
                            2011/11/08 10:08:22 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 16D2 PROVID: 00A821
                            2011/11/08 10:08:22 32059B50 c dvbapi: new program number: 20AF (0500:20AF unknown)
                            2011/11/08 10:08:22 32059B50 c dvbapi: try pids again #1
                            2011/11/08 10:08:22 32059B50 c dvbapi: try pids again #2
                            2011/11/08 10:08:22 32059B50 c dvbapi: try pids again #3
                            2011/11/08 10:08:22 32059B50 c dvbapi: can't decode channel
                            2011/11/08 10:08:23 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 10:08:23 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 10:08:23 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 10:08:23 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 10:08:28 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 10:08:28 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 10:08:28 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 10:08:28 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 10:08:33 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 10:08:33 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 10:08:33 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 10:08:33 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 10:08:33 300162A0 s exit with signal 15
                            2011/11/08 10:08:33 300162A0 s cardserver down
                            >> OSCam << cardserver started at Tue Nov 8 14:02:07 2011
                            2011/11/08 14:02:07 300162A0 s version=1.00-unstable_svn, build #4066, system=powerpc-tuxbox-linux, nice=-10
                            2011/11/08 14:02:07 300162A0 s client max. idle=120 sec, debug level=0
                            2011/11/08 14:02:07 300162A0 s max. logsize=unlimited
                            2011/11/08 14:02:07 300162A0 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=120 ms
                            2011/11/08 14:02:08 300162A0 s auth size=4800
                            2011/11/08 14:02:08 300162A0 s services reloaded: 0 services freed, 4 services loaded
                            2011/11/08 14:02:08 300162A0 s AES key length error .. not adding
                            2011/11/08 14:02:08 300162A0 s 0 AES key(s) added on reader cardreader-tntsat for 0500:030b00
                            2011/11/08 14:02:08 300162A0 s userdb reloaded: 0 accounts freed, 2 accounts loaded, 0 expired, 0 disabled
                            2011/11/08 14:02:08 300162A0 s signal handling initialized (type=sysv)
                            2011/11/08 14:02:08 300162A0 s can't open file "/var/tuxbox/config/oscam.srvid" (err=2), no service-id's loaded
                            2011/11/08 14:02:08 300162A0 s can't open file "/var/tuxbox/config/oscam.tiers" (err=2), no tier-id's loaded
                            2011/11/08 14:02:08 300162A0 s can't open file "/var/tuxbox/config/oscam.provid" (err=2), no provids's loaded
                            2011/11/08 14:02:08 300162A0 s can't open file "/var/tuxbox/config/oscam.ird" (errno=2) irdeto guessing not loaded
                            2011/11/08 14:02:08 300162A0 s monitor: disabled
                            2011/11/08 14:02:08 300162A0 s camd33: disabled
                            2011/11/08 14:02:08 300162A0 s camd35: disabled
                            2011/11/08 14:02:08 300162A0 s cs378x: disabled
                            2011/11/08 14:02:08 300162A0 s newcamd: initialized (fd=6, port=34001, crypted)
                            2011/11/08 14:02:08 300162A0 s CAID: 0500
                            2011/11/08 14:02:08 300162A0 s provid #0: 030B00
                            2011/11/08 14:02:08 300162A0 s cccam: disabled
                            2011/11/08 14:02:08 300162A0 s radegast: disabled
                            2011/11/08 14:02:08 300162A0 s http thread started
                            2011/11/08 14:02:08 300162A0 s creating thread for device xabix...e.net slot 0
                            2011/11/08 14:02:08 300162A0 s creating thread for device /dev/sci0 slot 0
                            2011/11/08 14:02:08 300162A0 s waiting for local card init
                            2011/11/08 14:02:08 30859B50 h HTTP Server listening on port 8888
                            2011/11/08 14:02:08 31059B50 p proxy thread started (thread=31059B50, label=xabi....tme.net, server=xabix...e.net)
                            2011/11/08 14:02:08 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:02:08 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:02:08 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:02:08 31859B50 r reader thread started (thread=31859B50, label=cardreader-tntsat, device=/dev/sci0, detect=cd, mhz=357, cardmhz=357)
                            2011/11/08 14:02:12 300162A0 s init for all local cards done
                            2011/11/08 14:02:12 300162A0 s anti cascading disabled
                            2011/11/08 14:02:12 32059B50 c plain dvbapi-client granted (localuser, au=cardreader-tntsat)
                            2011/11/08 14:02:12 32059B50 c dvbapi: 8 entries read from oscam.dvbapi
                            2011/11/08 14:02:13 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:02:13 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:02:13 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:02:13 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:02:18 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:02:18 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:02:18 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:02:18 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:02:21 32059B50 c dvbapi: found pmt file /tmp/pmt.tmp
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1ABA PROVID: 030B00
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1ABC PROVID: 022610
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 16D0 PROVID: 023311
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 16D1 PROVID: 023315
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 16D3 PROVID: 023317
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1AB8 PROVID: 032920
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1ABB PROVID: 032940
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1ABD PROVID: 032830
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1ABE PROVID: 043300
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1ABF PROVID: 043330
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 16D4 PROVID: 023342
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1AC0 PROVID: 030B00
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 16D3 PROVID: 003317
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 16D1 PROVID: 003315
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 16D0 PROVID: 003311
                            2011/11/08 14:02:21 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 16D2 PROVID: 00A821
                            2011/11/08 14:02:21 32059B50 c dvbapi: new program number: 20AF (0500:20AF unknown)
                            2011/11/08 14:02:21 32059B50 c dvbapi: try pids again #1
                            2011/11/08 14:02:21 32059B50 c dvbapi: try pids again #2
                            2011/11/08 14:02:21 32059B50 c dvbapi: try pids again #3
                            2011/11/08 14:02:21 32059B50 c dvbapi: can't decode channel
                            2011/11/08 14:02:23 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:02:23 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:02:23 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:02:23 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:02:28 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:02:28 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:02:28 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:02:28 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:02:33 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:02:33 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:02:33 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:02:33 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:02:36 300162A0 s exit with signal 15
                            2011/11/08 14:02:36 300162A0 s cardserver down
                            >> OSCam << cardserver started at Tue Nov 8 14:21:43 2011
                            2011/11/08 14:21:43 300162A0 s version=1.00-unstable_svn, build #4066, system=powerpc-tuxbox-linux, nice=-10
                            2011/11/08 14:21:43 300162A0 s client max. idle=120 sec, debug level=0
                            2011/11/08 14:21:43 300162A0 s max. logsize=unlimited
                            2011/11/08 14:21:43 300162A0 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=120 ms
                            2011/11/08 14:21:43 300162A0 s auth size=4800
                            2011/11/08 14:21:43 300162A0 s services reloaded: 0 services freed, 4 services loaded
                            2011/11/08 14:21:43 300162A0 s AES key length error .. not adding
                            2011/11/08 14:21:43 300162A0 s 0 AES key(s) added on reader cardreader-tntsat for 0500:030b00
                            2011/11/08 14:21:43 300162A0 s userdb reloaded: 0 accounts freed, 2 accounts loaded, 0 expired, 0 disabled
                            2011/11/08 14:21:43 300162A0 s signal handling initialized (type=sysv)
                            2011/11/08 14:21:43 300162A0 s can't open file "/var/tuxbox/config/oscam.srvid" (err=2), no service-id's loaded
                            2011/11/08 14:21:43 300162A0 s can't open file "/var/tuxbox/config/oscam.tiers" (err=2), no tier-id's loaded
                            2011/11/08 14:21:43 300162A0 s can't open file "/var/tuxbox/config/oscam.provid" (err=2), no provids's loaded
                            2011/11/08 14:21:43 300162A0 s can't open file "/var/tuxbox/config/oscam.ird" (errno=2) irdeto guessing not loaded
                            2011/11/08 14:21:43 300162A0 s monitor: disabled
                            2011/11/08 14:21:43 300162A0 s camd33: disabled
                            2011/11/08 14:21:43 300162A0 s camd35: disabled
                            2011/11/08 14:21:43 300162A0 s cs378x: disabled
                            2011/11/08 14:21:43 300162A0 s newcamd: initialized (fd=6, port=34001, crypted)
                            2011/11/08 14:21:43 300162A0 s CAID: 0500
                            2011/11/08 14:21:43 300162A0 s provid #0: 030B00
                            2011/11/08 14:21:43 300162A0 s cccam: disabled
                            2011/11/08 14:21:43 300162A0 s radegast: disabled
                            2011/11/08 14:21:43 300162A0 s http thread started
                            2011/11/08 14:21:43 300162A0 s creating thread for device xabix...e.net slot 0
                            2011/11/08 14:21:43 300162A0 s creating thread for device /dev/sci0 slot 0
                            2011/11/08 14:21:43 300162A0 s waiting for local card init
                            2011/11/08 14:21:43 30859B50 h HTTP Server listening on port 8888
                            2011/11/08 14:21:43 31059B50 p proxy thread started (thread=31059B50, label=xabi....tme.net, server=xabix...e.net)
                            2011/11/08 14:21:43 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:21:43 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:21:43 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:21:43 31859B50 r reader thread started (thread=31859B50, label=cardreader-tntsat, device=/dev/sci0, detect=cd, mhz=357, cardmhz=357)
                            2011/11/08 14:21:46 300162A0 s init for all local cards done
                            2011/11/08 14:21:46 300162A0 s anti cascading disabled
                            2011/11/08 14:21:46 32059B50 c plain dvbapi-client granted (localuser, au=cardreader-tntsat)
                            2011/11/08 14:21:46 32059B50 c dvbapi: 8 entries read from oscam.dvbapi
                            2011/11/08 14:21:46 32059B50 c dvbapi: found pmt file /tmp/pmt.tmp
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1A74 PROVID: 030B00
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1A76 PROVID: 022610
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 168A PROVID: 023311
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 168B PROVID: 023315
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 168D PROVID: 023317
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A72 PROVID: 032920
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A75 PROVID: 032940
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A77 PROVID: 032830
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A78 PROVID: 043300
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A79 PROVID: 043330
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 168E PROVID: 023342
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A7A PROVID: 030B00
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 168D PROVID: 003317
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 168B PROVID: 003315
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 168A PROVID: 003311
                            2011/11/08 14:21:46 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 168C PROVID: 00A821
                            2011/11/08 14:21:46 32059B50 c dvbapi: new program number: 20AE (0500:20AE unknown)
                            2011/11/08 14:21:46 32059B50 c dvbapi: try pids again #1
                            2011/11/08 14:21:46 32059B50 c dvbapi: try pids again #2
                            2011/11/08 14:21:46 32059B50 c dvbapi: try pids again #3
                            2011/11/08 14:21:46 32059B50 c dvbapi: can't decode channel
                            2011/11/08 14:21:48 32059B50 c dvbapi: stoping demux for pmt file /tmp/pmt.tmp
                            2011/11/08 14:21:48 32059B50 c dvbapi: new program number: 1FDF (0000:1FDF unknown)
                            2011/11/08 14:21:48 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:21:48 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:21:48 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:21:48 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1ABA PROVID: 030B00
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1ABC PROVID: 022610
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 16D0 PROVID: 023311
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 16D1 PROVID: 023315
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 16D3 PROVID: 023317
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1AB8 PROVID: 032920
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1ABB PROVID: 032940
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1ABD PROVID: 032830
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1ABE PROVID: 043300
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1ABF PROVID: 043330
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 16D4 PROVID: 023342
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1AC0 PROVID: 030B00
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 16D3 PROVID: 003317
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 16D1 PROVID: 003315
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 16D0 PROVID: 003311
                            2011/11/08 14:21:49 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 16D2 PROVID: 00A821
                            2011/11/08 14:21:49 32059B50 c dvbapi: new program number: 20AF (0500:20AF unknown)
                            2011/11/08 14:21:49 32059B50 c dvbapi: try pids again #1
                            2011/11/08 14:21:49 32059B50 c dvbapi: try pids again #2
                            2011/11/08 14:21:49 32059B50 c dvbapi: try pids again #3
                            2011/11/08 14:21:49 32059B50 c dvbapi: can't decode channel
                            2011/11/08 14:21:53 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:21:53 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:21:53 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:21:53 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 0] CAID: 1811 ECM_PID: 1630 PROVID: 023311
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 1] CAID: 1811 ECM_PID: 1631 PROVID: 023315
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 1632 PROVID: 023317
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 3] CAID: 0500 ECM_PID: 1A18 PROVID: 030B00
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 4] CAID: 0500 ECM_PID: 1A19 PROVID: 022610
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A1B PROVID: 032920
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A1C PROVID: 032940
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A1D PROVID: 032830
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A1E PROVID: 043300
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A1F PROVID: 043330
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 1635 PROVID: 023342
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A20 PROVID: 030B00
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 1633 PROVID: 00A821
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 1632 PROVID: 003317
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 1631 PROVID: 003315
                            2011/11/08 14:21:55 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 1630 PROVID: 003311
                            2011/11/08 14:21:55 32059B50 c dvbapi: new program number: 20A4 (1811:20A4 unknown)
                            2011/11/08 14:21:55 32059B50 c dvbapi: try pids again #1
                            2011/11/08 14:21:55 32059B50 c dvbapi: try pids again #2
                            2011/11/08 14:21:55 32059B50 c dvbapi: try pids again #3
                            2011/11/08 14:21:55 32059B50 c dvbapi: can't decode channel
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 19C0 PROVID: 030B00
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 19BD PROVID: 022610
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 15D8 PROVID: 023311
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 15DA PROVID: 023315
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 15DB PROVID: 023317
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 19BF PROVID: 032940
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 19C1 PROVID: 032920
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 19C4 PROVID: 032830
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 19C5 PROVID: 043330
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 19C3 PROVID: 043300
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 15DC PROVID: 023342
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 19C7 PROVID: 030B00
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 15DB PROVID: 003317
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 15DA PROVID: 003315
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 15D8 PROVID: 003311
                            2011/11/08 14:21:56 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 15D9 PROVID: 00A821
                            2011/11/08 14:21:56 32059B50 c dvbapi: new program number: 1FD8 (0500:1FD8 unknown)
                            2011/11/08 14:21:56 32059B50 c dvbapi: try pids again #1
                            2011/11/08 14:21:56 32059B50 c dvbapi: try pids again #2
                            2011/11/08 14:21:56 32059B50 c dvbapi: try pids again #3
                            2011/11/08 14:21:56 32059B50 c dvbapi: can't decode channel
                            2011/11/08 14:21:58 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:21:58 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:21:58 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:21:58 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:22:03 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:22:03 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:22:03 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:22:03 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 19C0 PROVID: 030B00
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 19BD PROVID: 022610
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 15D8 PROVID: 023311
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 15DA PROVID: 023315
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 15DB PROVID: 023317
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 19BF PROVID: 032940
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 19C1 PROVID: 032920
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 19C4 PROVID: 032830
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 19C5 PROVID: 043330
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 19C3 PROVID: 043300
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 15DC PROVID: 023342
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 19C7 PROVID: 030B00
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 15DB PROVID: 003317
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 15DA PROVID: 003315
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 15D8 PROVID: 003311
                            2011/11/08 14:22:06 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 15D9 PROVID: 00A821
                            2011/11/08 14:22:06 32059B50 c dvbapi: new program number: 1FD8 (0500:1FD8 unknown)
                            2011/11/08 14:22:06 32059B50 c dvbapi: try pids again #1
                            2011/11/08 14:22:06 32059B50 c dvbapi: try pids again #2
                            2011/11/08 14:22:06 32059B50 c dvbapi: try pids again #3
                            2011/11/08 14:22:06 32059B50 c dvbapi: can't decode channel
                            2011/11/08 14:22:08 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:22:08 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:22:08 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:22:08 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 19C0 PROVID: 030B00
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 19BD PROVID: 022610
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 15D8 PROVID: 023311
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 15DA PROVID: 023315
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 15DB PROVID: 023317
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 19BF PROVID: 032940
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 19C1 PROVID: 032920
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 19C4 PROVID: 032830
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 19C5 PROVID: 043330
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 19C3 PROVID: 043300
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 15DC PROVID: 023342
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 19C7 PROVID: 030B00
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 15DB PROVID: 003317
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 15DA PROVID: 003315
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 15D8 PROVID: 003311
                            2011/11/08 14:22:08 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 15D9 PROVID: 00A821
                            2011/11/08 14:22:08 32059B50 c dvbapi: new program number: 1FD8 (0500:1FD8 unknown)
                            2011/11/08 14:22:08 32059B50 c dvbapi: try pids again #1
                            2011/11/08 14:22:08 32059B50 c dvbapi: try pids again #2
                            2011/11/08 14:22:08 32059B50 c dvbapi: try pids again #3
                            2011/11/08 14:22:08 32059B50 c dvbapi: can't decode channel
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 19C0 PROVID: 030B00
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 19BD PROVID: 022610
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 15D8 PROVID: 023311
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 15DA PROVID: 023315
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 15DB PROVID: 023317
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 19BF PROVID: 032940
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 19C1 PROVID: 032920
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 19C4 PROVID: 032830
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 19C5 PROVID: 043330
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 19C3 PROVID: 043300
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 15DC PROVID: 023342
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 19C7 PROVID: 030B00
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 15DB PROVID: 003317
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 15DA PROVID: 003315
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 15D8 PROVID: 003311
                            2011/11/08 14:22:11 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 15D9 PROVID: 00A821
                            2011/11/08 14:22:11 32059B50 c dvbapi: new program number: 1FD8 (0500:1FD8 unknown)
                            2011/11/08 14:22:11 32059B50 c dvbapi: try pids again #1
                            2011/11/08 14:22:11 32059B50 c dvbapi: try pids again #2
                            2011/11/08 14:22:11 32059B50 c dvbapi: try pids again #3
                            2011/11/08 14:22:11 32059B50 c dvbapi: can't decode channel
                            2011/11/08 14:22:13 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:22:13 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:22:13 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:22:13 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 19C0 PROVID: 030B00
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 19BD PROVID: 022610
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 15D8 PROVID: 023311
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 15DA PROVID: 023315
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 15DB PROVID: 023317
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 19BF PROVID: 032940
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 19C1 PROVID: 032920
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 19C4 PROVID: 032830
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 19C5 PROVID: 043330
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 19C3 PROVID: 043300
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 15DC PROVID: 023342
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 19C7 PROVID: 030B00
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 15DB PROVID: 003317
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 15DA PROVID: 003315
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 15D8 PROVID: 003311
                            2011/11/08 14:22:13 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 15D9 PROVID: 00A821
                            2011/11/08 14:22:13 32059B50 c dvbapi: new program number: 1FD8 (0500:1FD8 unknown)
                            2011/11/08 14:22:13 32059B50 c dvbapi: try pids again #1
                            2011/11/08 14:22:13 32059B50 c dvbapi: try pids again #2
                            2011/11/08 14:22:13 32059B50 c dvbapi: try pids again #3
                            2011/11/08 14:22:13 32059B50 c dvbapi: can't decode channel
                            2011/11/08 14:22:18 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:22:18 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:22:18 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:22:18 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:22:23 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:22:23 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:22:23 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:22:23 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:22:25 300162A0 s exit with signal 15
                            2011/11/08 14:22:25 300162A0 s cardserver down
                            >> OSCam << cardserver started at Tue Nov 8 14:58:51 2011
                            2011/11/08 14:58:51 300162A0 s version=1.00-unstable_svn, build #4066, system=powerpc-tuxbox-linux, nice=-10
                            2011/11/08 14:58:52 300162A0 s client max. idle=120 sec, debug level=0
                            2011/11/08 14:58:52 300162A0 s max. logsize=unlimited
                            2011/11/08 14:58:52 300162A0 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=120 ms
                            2011/11/08 14:58:52 300162A0 s auth size=4800
                            2011/11/08 14:58:52 300162A0 s services reloaded: 0 services freed, 4 services loaded
                            2011/11/08 14:58:52 300162A0 s AES key length error .. not adding
                            2011/11/08 14:58:52 300162A0 s 0 AES key(s) added on reader cardreader-tntsat for 0500:030b00
                            2011/11/08 14:58:52 300162A0 s userdb reloaded: 0 accounts freed, 2 accounts loaded, 0 expired, 0 disabled
                            2011/11/08 14:58:52 300162A0 s signal handling initialized (type=sysv)
                            2011/11/08 14:58:52 300162A0 s can't open file "/var/tuxbox/config/oscam.srvid" (err=2), no service-id's loaded
                            2011/11/08 14:58:52 300162A0 s can't open file "/var/tuxbox/config/oscam.tiers" (err=2), no tier-id's loaded
                            2011/11/08 14:58:52 300162A0 s can't open file "/var/tuxbox/config/oscam.provid" (err=2), no provids's loaded
                            2011/11/08 14:58:52 300162A0 s can't open file "/var/tuxbox/config/oscam.ird" (errno=2) irdeto guessing not loaded
                            2011/11/08 14:58:52 300162A0 s monitor: disabled
                            2011/11/08 14:58:52 300162A0 s camd33: disabled
                            2011/11/08 14:58:52 300162A0 s camd35: disabled
                            2011/11/08 14:58:52 300162A0 s cs378x: disabled
                            2011/11/08 14:58:52 300162A0 s newcamd: initialized (fd=6, port=34001, crypted)
                            2011/11/08 14:58:52 300162A0 s CAID: 0500
                            2011/11/08 14:58:52 300162A0 s provid #0: 030B00
                            2011/11/08 14:58:52 300162A0 s cccam: disabled
                            2011/11/08 14:58:52 300162A0 s radegast: disabled
                            2011/11/08 14:58:52 300162A0 s http thread started
                            2011/11/08 14:58:52 300162A0 s creating thread for device xabix...e.net slot 0
                            2011/11/08 14:58:52 300162A0 s creating thread for device /dev/sci0 slot 0
                            2011/11/08 14:58:52 300162A0 s waiting for local card init
                            2011/11/08 14:58:52 30859B50 h HTTP Server listening on port 8888
                            2011/11/08 14:58:52 31059B50 p proxy thread started (thread=31059B50, label=xabi....tme.net, server=xabix...e.net)
                            2011/11/08 14:58:52 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:58:52 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:58:52 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:58:52 31859B50 r reader thread started (thread=31859B50, label=cardreader-tntsat, device=/dev/sci0, detect=cd, mhz=357, cardmhz=357)
                            2011/11/08 14:58:56 300162A0 s init for all local cards done
                            2011/11/08 14:58:56 300162A0 s anti cascading disabled
                            2011/11/08 14:58:56 32059B50 c plain dvbapi-client granted (localuser, au=cardreader-tntsat)
                            2011/11/08 14:58:56 32059B50 c dvbapi: 8 entries read from oscam.dvbapi
                            2011/11/08 14:58:57 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:58:57 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:58:57 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:58:57 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 14:59:02 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 14:59:02 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 14:59:02 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 14:59:02 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:00:16 32059B50 c dvbapi: found pmt file /tmp/pmt.tmp
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 19C0 PROVID: 030B00
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 19BD PROVID: 022610
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 15D8 PROVID: 023311
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 15DA PROVID: 023315
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 15DB PROVID: 023317
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 19BF PROVID: 032940
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 19C1 PROVID: 032920
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 19C4 PROVID: 032830
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 19C5 PROVID: 043330
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 19C3 PROVID: 043300
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 15DC PROVID: 023342
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 19C7 PROVID: 030B00
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 15DB PROVID: 003317
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 15DA PROVID: 003315
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 15D8 PROVID: 003311
                            2011/11/08 15:00:16 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 15D9 PROVID: 00A821
                            2011/11/08 15:00:16 32059B50 c dvbapi: new program number: 1FD8 (0500:1FD8 unknown)
                            2011/11/08 15:00:16 32059B50 c dvbapi: try pids again #1
                            2011/11/08 15:00:16 32059B50 c dvbapi: try pids again #2
                            2011/11/08 15:00:16 32059B50 c dvbapi: try pids again #3
                            2011/11/08 15:00:16 32059B50 c dvbapi: can't decode channel
                            2011/11/08 15:00:19 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:00:19 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:00:19 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:00:19 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:00:24 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:00:24 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:00:24 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:00:24 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:00:29 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:00:29 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:00:29 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:00:29 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:00:34 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:00:34 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:00:34 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:00:34 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:00:39 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:00:39 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:00:39 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:00:39 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:00:44 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:00:44 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:00:44 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:00:44 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:00:49 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:00:49 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:00:49 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:00:49 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:00:54 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:00:54 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:00:54 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:00:54 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:00:59 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:00:59 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:00:59 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:00:59 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:01:04 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:01:04 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:01:04 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:01:04 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:01:09 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:01:09 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:01:09 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:01:09 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:01:14 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:01:14 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:01:14 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:01:14 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:01:19 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:01:20 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:01:20 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:01:20 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:01:25 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:01:25 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:01:25 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:01:25 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:01:30 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:01:30 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:01:30 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:01:30 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:01:35 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:01:35 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:01:35 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:01:35 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:01:40 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:01:40 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:01:40 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:01:40 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:01:45 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:01:45 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:01:45 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:01:45 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:01:50 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:01:50 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:01:50 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:01:50 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:01:55 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:01:55 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:01:55 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:01:55 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:02:00 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:02:00 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:02:00 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:02:00 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:02:05 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:02:05 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:02:05 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:02:05 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:02:10 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:02:10 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:02:10 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:02:10 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:02:15 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:02:15 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:02:15 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:02:15 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:02:20 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:02:20 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:02:20 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:02:20 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:02:25 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:02:25 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:02:25 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:02:25 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:02:30 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:02:30 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:02:30 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:02:30 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:02:35 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:02:35 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:02:35 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:02:35 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:02:40 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:02:40 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:02:40 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:02:40 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:02:45 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:02:45 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:02:45 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:02:45 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:02:50 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:02:50 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:02:50 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:02:50 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:02:55 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:02:55 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:02:55 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:02:55 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:03:00 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:03:00 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:03:00 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:03:00 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:03:05 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:03:05 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:03:05 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:03:05 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:03:10 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:03:10 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:03:10 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:03:10 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:03:15 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:03:15 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:03:15 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:03:15 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:03:20 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:03:20 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:03:20 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:03:20 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:03:25 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:03:25 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:03:25 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:03:25 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:03:30 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:03:30 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:03:30 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:03:30 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:03:35 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:03:35 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:03:35 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:03:35 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:03:40 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:03:40 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:03:40 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:03:40 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:03:45 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:03:45 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:03:45 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:03:45 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:03:50 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:03:50 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:03:50 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:03:50 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:03:55 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:03:55 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:03:55 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:03:55 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:04:00 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:04:00 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:04:00 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:04:00 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:04:05 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:04:05 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:04:05 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:04:05 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:04:10 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:04:10 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:04:10 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:04:10 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:04:15 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:04:15 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:04:15 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:04:15 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:04:20 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:04:20 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:04:20 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:04:20 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:04:25 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:04:25 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:04:25 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:04:25 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:04:30 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:04:30 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:04:30 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:04:30 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:04:35 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:04:35 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:04:35 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:04:35 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:04:40 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:04:40 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:04:40 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:04:40 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:04:45 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:04:45 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:04:45 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:04:45 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:04:50 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:04:50 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:04:50 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:04:50 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:04:55 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:04:55 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:04:55 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:04:55 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:05:00 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:05:00 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:05:00 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:05:00 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:05:05 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:05:05 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:05:05 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:05:05 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:05:10 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:05:10 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:05:10 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:05:10 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:05:15 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:05:15 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:05:15 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:05:15 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:05:20 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:05:20 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:05:20 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:05:20 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:05:25 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:05:25 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:05:25 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:05:25 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:05:30 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:05:30 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:05:30 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:05:30 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:05:35 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:05:35 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:05:35 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:05:35 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:05:40 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:05:40 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:05:40 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:05:40 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:05:44 32059B50 c dvbapi: stoping demux for pmt file /tmp/pmt.tmp
                            2011/11/08 15:05:44 32059B50 c dvbapi: [ADD PID 0] CAID: 090F ECM_PID: 0486 PROVID: 000000
                            2011/11/08 15:05:44 32059B50 c dvbapi: [ADD PID 1] CAID: 093E ECM_PID: 0097 PROVID: 000000
                            2011/11/08 15:05:44 32059B50 c dvbapi: new program number: 047E (090F:047E unknown)
                            2011/11/08 15:05:44 32059B50 c dvbapi: try pids again #1
                            2011/11/08 15:05:44 32059B50 c dvbapi: try pids again #2
                            2011/11/08 15:05:44 32059B50 c dvbapi: try pids again #3
                            2011/11/08 15:05:44 32059B50 c dvbapi: can't decode channel
                            2011/11/08 15:05:45 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:05:45 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:05:45 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:05:45 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:05:50 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 15:05:50 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 15:05:50 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 15:05:50 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 15:05:53 300162A0 s exit with signal 15
                            2011/11/08 15:05:53 300162A0 s cardserver down
                            >> OSCam << cardserver started at Tue Nov 8 20:28:51 2011
                            2011/11/08 20:28:51 300162A0 s version=1.00-unstable_svn, build #4066, system=powerpc-tuxbox-linux, nice=-10
                            2011/11/08 20:28:51 300162A0 s client max. idle=120 sec, debug level=0
                            2011/11/08 20:28:51 300162A0 s max. logsize=unlimited
                            2011/11/08 20:28:51 300162A0 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=120 ms
                            2011/11/08 20:28:51 300162A0 s auth size=4800
                            2011/11/08 20:28:51 300162A0 s services reloaded: 0 services freed, 4 services loaded
                            2011/11/08 20:28:51 300162A0 s AES key length error .. not adding
                            2011/11/08 20:28:51 300162A0 s 0 AES key(s) added on reader cardreader-tntsat for 0500:030b00
                            2011/11/08 20:28:51 300162A0 s userdb reloaded: 0 accounts freed, 2 accounts loaded, 0 expired, 0 disabled
                            2011/11/08 20:28:51 300162A0 s signal handling initialized (type=sysv)
                            2011/11/08 20:28:51 300162A0 s can't open file "/var/tuxbox/config/oscam.srvid" (err=2), no service-id's loaded
                            2011/11/08 20:28:51 300162A0 s can't open file "/var/tuxbox/config/oscam.tiers" (err=2), no tier-id's loaded
                            2011/11/08 20:28:51 300162A0 s can't open file "/var/tuxbox/config/oscam.provid" (err=2), no provids's loaded
                            2011/11/08 20:28:51 300162A0 s can't open file "/var/tuxbox/config/oscam.ird" (errno=2) irdeto guessing not loaded
                            2011/11/08 20:28:51 300162A0 s monitor: disabled
                            2011/11/08 20:28:51 300162A0 s camd33: disabled
                            2011/11/08 20:28:51 300162A0 s camd35: disabled
                            2011/11/08 20:28:51 300162A0 s cs378x: disabled
                            2011/11/08 20:28:51 300162A0 s newcamd: initialized (fd=6, port=34001, crypted)
                            2011/11/08 20:28:51 300162A0 s CAID: 0500
                            2011/11/08 20:28:51 300162A0 s provid #0: 030B00
                            2011/11/08 20:28:51 300162A0 s cccam: disabled
                            2011/11/08 20:28:51 300162A0 s radegast: disabled
                            2011/11/08 20:28:51 300162A0 s http thread started
                            2011/11/08 20:28:51 300162A0 s creating thread for device xabix...e.net slot 0
                            2011/11/08 20:28:51 300162A0 s creating thread for device /dev/sci0 slot 0
                            2011/11/08 20:28:51 300162A0 s waiting for local card init
                            2011/11/08 20:28:51 30859B50 h HTTP Server listening on port 8888
                            2011/11/08 20:28:51 31059B50 p proxy thread started (thread=31059B50, label=xabi....tme.net, server=xabix...e.net)
                            2011/11/08 20:28:51 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 20:28:51 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 20:28:51 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 20:28:51 31859B50 r reader thread started (thread=31859B50, label=cardreader-tntsat, device=/dev/sci0, detect=cd, mhz=357, cardmhz=357)
                            2011/11/08 20:28:54 300162A0 s init for all local cards done
                            2011/11/08 20:28:54 300162A0 s anti cascading disabled
                            2011/11/08 20:28:54 32059B50 c plain dvbapi-client granted (localuser, au=cardreader-tntsat)
                            2011/11/08 20:28:54 32059B50 c dvbapi: 8 entries read from oscam.dvbapi
                            2011/11/08 20:28:54 32059B50 c dvbapi: found pmt file /tmp/pmt.tmp
                            2011/11/08 20:28:54 32059B50 c dvbapi: [ADD PID 0] CAID: 090F ECM_PID: 0743 PROVID: 000000
                            2011/11/08 20:28:54 32059B50 c dvbapi: [ADD PID 1] CAID: 093E ECM_PID: 0195 PROVID: 000000
                            2011/11/08 20:28:54 32059B50 c dvbapi: new program number: 073A (090F:073A unknown)
                            2011/11/08 20:28:54 32059B50 c dvbapi: try pids again #1
                            2011/11/08 20:28:54 32059B50 c dvbapi: try pids again #2
                            2011/11/08 20:28:54 32059B50 c dvbapi: try pids again #3
                            2011/11/08 20:28:54 32059B50 c dvbapi: can't decode channel
                            2011/11/08 20:28:56 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 20:28:56 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 20:28:56 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 20:28:56 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 20:28:57 32059B50 c dvbapi: [ADD PID 0] CAID: 090F ECM_PID: 0743 PROVID: 000000
                            2011/11/08 20:28:57 32059B50 c dvbapi: [ADD PID 1] CAID: 093E ECM_PID: 0195 PROVID: 000000
                            2011/11/08 20:28:57 32059B50 c dvbapi: new program number: 073A (090F:073A unknown)
                            2011/11/08 20:28:57 32059B50 c dvbapi: try pids again #1
                            2011/11/08 20:28:57 32059B50 c dvbapi: try pids again #2
                            2011/11/08 20:28:57 32059B50 c dvbapi: try pids again #3
                            2011/11/08 20:28:57 32059B50 c dvbapi: can't decode channel
                            2011/11/08 20:29:01 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 20:29:01 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 20:29:01 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 20:29:01 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 20:29:06 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 20:29:06 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 20:29:06 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 20:29:06 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 20:29:10 32059B50 c dvbapi: stoping demux for pmt file /tmp/pmt.tmp
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1A74 PROVID: 030B00
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1A76 PROVID: 022610
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 168A PROVID: 023311
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 168B PROVID: 023315
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 168D PROVID: 023317
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A72 PROVID: 032920
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A75 PROVID: 032940
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A77 PROVID: 032830
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A78 PROVID: 043300
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A79 PROVID: 043330
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 168E PROVID: 023342
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A7A PROVID: 030B00
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 168D PROVID: 003317
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 168B PROVID: 003315
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 168A PROVID: 003311
                            2011/11/08 20:29:10 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 168C PROVID: 00A821
                            2011/11/08 20:29:10 32059B50 c dvbapi: new program number: 20AE (0500:20AE unknown)
                            2011/11/08 20:29:10 32059B50 c dvbapi: try pids again #1
                            2011/11/08 20:29:10 32059B50 c dvbapi: try pids again #2
                            2011/11/08 20:29:10 32059B50 c dvbapi: try pids again #3
                            2011/11/08 20:29:10 32059B50 c dvbapi: can't decode channel
                            2011/11/08 20:29:11 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 20:29:11 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 20:29:11 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 20:29:11 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 20:29:16 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 20:29:16 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 20:29:16 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 20:29:16 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 20:29:20 32059B50 c dvbapi: new program number: 1FDF (0000:1FDF unknown)
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1A74 PROVID: 030B00
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1A76 PROVID: 022610
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 168A PROVID: 023311
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 168B PROVID: 023315
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 168D PROVID: 023317
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A72 PROVID: 032920
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A75 PROVID: 032940
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A77 PROVID: 032830
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A78 PROVID: 043300
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A79 PROVID: 043330
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 168E PROVID: 023342
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A7A PROVID: 030B00
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 168D PROVID: 003317
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 168B PROVID: 003315
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 168A PROVID: 003311
                            2011/11/08 20:29:21 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 168C PROVID: 00A821
                            2011/11/08 20:29:21 32059B50 c dvbapi: new program number: 20AE (0500:20AE unknown)
                            2011/11/08 20:29:21 32059B50 c dvbapi: try pids again #1
                            2011/11/08 20:29:21 32059B50 c dvbapi: try pids again #2
                            2011/11/08 20:29:21 32059B50 c dvbapi: try pids again #3
                            2011/11/08 20:29:21 32059B50 c dvbapi: can't decode channel
                            2011/11/08 20:29:21 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 20:29:21 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 20:29:21 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 20:29:21 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 20:29:24 32059B50 c dvbapi: new program number: 1FDF (0000:1FDF unknown)
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1A74 PROVID: 030B00
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1A76 PROVID: 022610
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 168A PROVID: 023311
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 168B PROVID: 023315
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 168D PROVID: 023317
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A72 PROVID: 032920
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A75 PROVID: 032940
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A77 PROVID: 032830
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A78 PROVID: 043300
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A79 PROVID: 043330
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 168E PROVID: 023342
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A7A PROVID: 030B00
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 168D PROVID: 003317
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 168B PROVID: 003315
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 168A PROVID: 003311
                            2011/11/08 20:29:25 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 168C PROVID: 00A821
                            2011/11/08 20:29:25 32059B50 c dvbapi: new program number: 20AE (0500:20AE unknown)
                            2011/11/08 20:29:25 32059B50 c dvbapi: try pids again #1
                            2011/11/08 20:29:25 32059B50 c dvbapi: try pids again #2
                            2011/11/08 20:29:25 32059B50 c dvbapi: try pids again #3
                            2011/11/08 20:29:25 32059B50 c dvbapi: can't decode channel
                            2011/11/08 20:29:26 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 20:29:26 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 20:29:26 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 20:29:26 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 20:29:31 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 20:29:31 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 20:29:31 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 20:29:31 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 20:29:36 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 20:29:36 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 20:29:36 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 20:29:36 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 20:29:38 300162A0 s exit with signal 15
                            2011/11/08 20:29:38 300162A0 s cardserver down
                            >> OSCam << cardserver started at Tue Nov 8 21:01:53 2011
                            2011/11/08 21:01:53 300162A0 s version=1.00-unstable_svn, build #4066, system=powerpc-tuxbox-linux, nice=-10
                            2011/11/08 21:01:53 300162A0 s client max. idle=120 sec, debug level=0
                            2011/11/08 21:01:53 300162A0 s max. logsize=unlimited
                            2011/11/08 21:01:53 300162A0 s client timeout=5000 ms, fallback timeout=2500 ms, cache delay=120 ms
                            2011/11/08 21:01:54 300162A0 s auth size=4800
                            2011/11/08 21:01:54 300162A0 s services reloaded: 0 services freed, 4 services loaded
                            2011/11/08 21:01:54 300162A0 s AES key length error .. not adding
                            2011/11/08 21:01:54 300162A0 s 0 AES key(s) added on reader cardreader-tntsat for 0500:030b00
                            2011/11/08 21:01:54 300162A0 s userdb reloaded: 0 accounts freed, 2 accounts loaded, 0 expired, 0 disabled
                            2011/11/08 21:01:54 300162A0 s signal handling initialized (type=sysv)
                            2011/11/08 21:01:54 300162A0 s can't open file "/var/tuxbox/config/oscam.srvid" (err=2), no service-id's loaded
                            2011/11/08 21:01:54 300162A0 s can't open file "/var/tuxbox/config/oscam.tiers" (err=2), no tier-id's loaded
                            2011/11/08 21:01:54 300162A0 s can't open file "/var/tuxbox/config/oscam.provid" (err=2), no provids's loaded
                            2011/11/08 21:01:54 300162A0 s can't open file "/var/tuxbox/config/oscam.ird" (errno=2) irdeto guessing not loaded
                            2011/11/08 21:01:54 300162A0 s monitor: disabled
                            2011/11/08 21:01:54 300162A0 s camd33: disabled
                            2011/11/08 21:01:54 300162A0 s camd35: disabled
                            2011/11/08 21:01:54 300162A0 s cs378x: disabled
                            2011/11/08 21:01:54 300162A0 s newcamd: initialized (fd=6, port=34001, crypted)
                            2011/11/08 21:01:54 300162A0 s CAID: 0500
                            2011/11/08 21:01:54 300162A0 s provid #0: 030B00
                            2011/11/08 21:01:54 300162A0 s cccam: disabled
                            2011/11/08 21:01:54 300162A0 s radegast: disabled
                            2011/11/08 21:01:54 300162A0 s http thread started
                            2011/11/08 21:01:54 300162A0 s creating thread for device xabix...e.net slot 0
                            2011/11/08 21:01:54 300162A0 s creating thread for device /dev/sci0 slot 0
                            2011/11/08 21:01:54 300162A0 s waiting for local card init
                            2011/11/08 21:01:54 30859B50 h HTTP Server listening on port 8888
                            2011/11/08 21:01:54 31059B50 p proxy thread started (thread=31059B50, label=xabi....tme.net, server=xabix...e.net)
                            2011/11/08 21:01:54 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:01:54 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:01:54 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:01:54 31859B50 r reader thread started (thread=31859B50, label=cardreader-tntsat, device=/dev/sci0, detect=cd, mhz=357, cardmhz=357)
                            2011/11/08 21:01:57 300162A0 s init for all local cards done
                            2011/11/08 21:01:57 300162A0 s anti cascading disabled
                            2011/11/08 21:01:57 32059B50 c plain dvbapi-client granted (localuser, au=cardreader-tntsat)
                            2011/11/08 21:01:57 32059B50 c dvbapi: 8 entries read from oscam.dvbapi
                            2011/11/08 21:01:59 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:01:59 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:01:59 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:01:59 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:02:04 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:02:04 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:02:04 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:02:04 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:02:06 32059B50 c dvbapi: found pmt file /tmp/pmt.tmp
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1A74 PROVID: 030B00
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1A76 PROVID: 022610
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 168A PROVID: 023311
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 168B PROVID: 023315
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 168D PROVID: 023317
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A72 PROVID: 032920
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A75 PROVID: 032940
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A77 PROVID: 032830
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A78 PROVID: 043300
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A79 PROVID: 043330
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 168E PROVID: 023342
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A7A PROVID: 030B00
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 168D PROVID: 003317
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 168B PROVID: 003315
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 168A PROVID: 003311
                            2011/11/08 21:02:06 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 168C PROVID: 00A821
                            2011/11/08 21:02:06 32059B50 c dvbapi: new program number: 20AE (0500:20AE unknown)
                            2011/11/08 21:02:06 32059B50 c dvbapi: try pids again #1
                            2011/11/08 21:02:06 32059B50 c dvbapi: try pids again #2
                            2011/11/08 21:02:06 32059B50 c dvbapi: try pids again #3
                            2011/11/08 21:02:06 32059B50 c dvbapi: can't decode channel
                            2011/11/08 21:02:09 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:02:09 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:02:09 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:02:09 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:02:14 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:02:14 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:02:14 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:02:14 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:02:19 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:02:19 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:02:19 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:02:19 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:02:24 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:02:24 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:02:24 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:02:24 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:02:29 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:02:29 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:02:29 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:02:29 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:02:34 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:02:34 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:02:34 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:02:34 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:02:39 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:02:39 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:02:39 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:02:39 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:02:44 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:02:44 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:02:44 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:02:44 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:02:49 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:02:49 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:02:49 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:02:49 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:02:54 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:02:54 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:02:54 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:02:54 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:02:59 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:02:59 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:02:59 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:02:59 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:03:04 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:03:04 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:03:04 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:03:04 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:03:09 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:03:09 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:03:09 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:03:09 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:03:14 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:03:14 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:03:14 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:03:14 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:03:19 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:03:19 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:03:19 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:03:19 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:03:24 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:03:24 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:03:24 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:03:24 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:03:29 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:03:29 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:03:29 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:03:29 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:03:34 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:03:34 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:03:34 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:03:34 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:03:39 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:03:39 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:03:39 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:03:39 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:03:44 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:03:44 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:03:44 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:03:44 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:03:49 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:03:49 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:03:49 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:03:49 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:03:54 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:03:54 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:03:54 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:03:54 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:03:59 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:03:59 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:03:59 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:03:59 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:04:04 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:04:04 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:04:04 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:04:04 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:04:09 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:04:09 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:04:09 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:04:09 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:04:14 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:04:14 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:04:14 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:04:14 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:04:17 32059B50 c dvbapi: stoping demux for pmt file /tmp/pmt.tmp
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 0] CAID: 0500 ECM_PID: 1A74 PROVID: 030B00
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 1] CAID: 0500 ECM_PID: 1A76 PROVID: 022610
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 2] CAID: 1811 ECM_PID: 168A PROVID: 023311
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 3] CAID: 1811 ECM_PID: 168B PROVID: 023315
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 4] CAID: 1811 ECM_PID: 168D PROVID: 023317
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 5] CAID: 0500 ECM_PID: 1A72 PROVID: 032920
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 6] CAID: 0500 ECM_PID: 1A75 PROVID: 032940
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 7] CAID: 0500 ECM_PID: 1A77 PROVID: 032830
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 8] CAID: 0500 ECM_PID: 1A78 PROVID: 043300
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 9] CAID: 0500 ECM_PID: 1A79 PROVID: 043330
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 10] CAID: 1863 ECM_PID: 168E PROVID: 023342
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 11] CAID: 0500 ECM_PID: 1A7A PROVID: 030B00
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 12] CAID: 0100 ECM_PID: 168D PROVID: 003317
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 13] CAID: 0100 ECM_PID: 168B PROVID: 003315
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 14] CAID: 0100 ECM_PID: 168A PROVID: 003311
                            2011/11/08 21:04:17 32059B50 c dvbapi: [ADD PID 15] CAID: 0100 ECM_PID: 168C PROVID: 00A821
                            2011/11/08 21:04:17 32059B50 c dvbapi: new program number: 20AE (0500:20AE unknown)
                            2011/11/08 21:04:17 32059B50 c dvbapi: try pids again #1
                            2011/11/08 21:04:17 32059B50 c dvbapi: try pids again #2
                            2011/11/08 21:04:17 32059B50 c dvbapi: try pids again #3
                            2011/11/08 21:04:17 32059B50 c dvbapi: can't decode channel
                            2011/11/08 21:04:19 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:04:19 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:04:19 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:04:19 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:04:24 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:04:24 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:04:24 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:04:24 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:04:29 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:04:29 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:04:29 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:04:29 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:04:34 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:04:34 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:04:34 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:04:34 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:04:39 31059B50 p xabi....tme.net restarting reader...
                            2011/11/08 21:04:39 31059B50 p xabi....tme.net configuration error!
                            2011/11/08 21:04:39 31059B50 p proxy reader: xabi....tme.net (xabix...e.net:12) cccam v2.1.4 build 3191, maxhop: 4
                            2011/11/08 21:04:39 31059B50 p xabi....tme.net restarting reader in 5 seconds
                            2011/11/08 21:04:42 300162A0 s exit with signal 15
                            2011/11/08 21:04:42 300162A0 s cardserver down
                            maybe you guys you can see where the problem is
                            thanks lots
                            • faridbou
                              • Nov 2011
                              • 24
                              #359
                              Guys Iam the happy man today it work my TNT card ,after one week 6 hours juste trayint but in the end it work , and i am sure wth out you guys all here DAVVO,Roodbuy,Satmos i could not do it self ,so thank you so much ,and i will let you now guys what whos the problem to help other ho needs helps. waw waw waw thanks this i the best forum ever
                              • garry1312
                                • Oct 2010
                                • 2178
                                #360
                                Glad to hear you got sorted mate.
                                Totally right about it being best forum ever great bunch on here and always willing to lend a hand
                                Rest In Peace Michael Mcharg, A true friend and although gone never forgotten. 11-10-08.
