Im just about to set up my DM800 by installing a new Motherboard.
My last one got fried. The thing is I don't want to make the same mistake so I'm trying to understand what caused my last board to die. Whatever the cause I believe the damage occurred to the power connector which was a bit darkish on the underneath of the board and the black plastic where the power cable is inserted had slightly melted. My box is a clone and I've included some pics.
Here are some of the things I did prior to it crashing.
Has anyone got any thoughts on this?
- I was trying out a variety of new images and because of this I had to turn the box on and off. I did this numerous times. I did it by taking out and reinserting the power lead.
- I put a very very small bit of vaseline in the centre of the noisy fan. I know others do this and previously I have used WD40.
- I added a plugin which did not install correctly. It was an auto-timeshift plugin called permanenttimeshift. This gave me an error when I would enter the plugins menu. My thinking is that this would somehow call on the HDD to spin up and cause the cpu and board to overheat. The box was very hot.
