I personally use CrossEPG, tried a few others but this 1 works the best for me. As an add-on it should hopefully work with quite a few images but I use it with NewNigma2 v3.2 (clone image that is)
Do you think it would work with the blackhole image?
Use DCC to ftp the IPK file to the /tmp folder then from the box select addons/plugins then Manual install, hopefully it should display crossepg so do an install.
The other thing is that I would recommend that you either install a HDD or a USB pen drive onto which CrossEPG can download EPG data, it should work without these but it helps keep that temp data off the main SIM which doesn't have a lot of space to spare anyway.
