hi experts, i need a solution on this prob.my dm 800hd clone suddenly not getting any signal snr 0% and not able to power my motor to turn to other sats. i've been using it for almost a year now with no problem. i even tried to connect the cable to my dedicated British sky disk 28.2, but still no signal.Please help.
confused if it's a tuner problem?
rev L, also tried reseating but to no avail.how to check if power supply is not enough?Comment
Its gotta be a tuner problem mate, I personally cant see it being anything to do with the power supply.. Hmm another option - I recently lost a couple of transponders, had 0% signal on them. I reflashed my box and bingo everything was back on.. Thats your next step kid.Comment
might as well try to re flash,let's see what will happen.Thanks mate.Its gotta be a tuner problem mate, I personally cant see it being anything to do with the power supply.. Hmm another option - I recently lost a couple of transponders, had 0% signal on them. I reflashed my box and bingo everything was back on.. Thats your next step kid.Comment
The power pack is your power supply.
I bought a dm800 and had the same problems you had, plugged it in to my dm500 power supply and worked fine.
I have also had problems when the power pack caused problems with my 500, with certain menus not displaying like sat find or motor setup.
People will automatically blame the tuner as the box is powering up but is the box aint getting the correct power then you will get problems.
Always eliminate the easiest things 1st and work back.Comment
Your router pay supply might be the same just to check . When l flash a box l just put the router power in , check the out put on your power pack and see if u have another one around about the same most modem as router r about the same out put
Sent from my iPhone using Tapatalkany information provided is for educational/experimental purposes only.Comment
Half Sorted!!! Thank you very much for sharing your experience mate. Followed your advice regarding the power pack. Tried my dm500 power pack to my dm800 and it worked rightaway on my British sky dishThe power pack is your power supply.
but when I tried to connect the cable into my motor dish the light of the motor stays off, thus that means no supply of power going to the motor or I am missing something?
Do they have the same power output ?Half Sorted!!! Thank you very much for sharing your experience mate. Followed your advice regarding the power pack. Tried my dm500 power pack to my dm800 and it worked rightaway on my British sky dish
Least we getting there.Comment
