dreambox 800 se ERR01 NO CA FOUND hellp
  • riadh2010
    • Apr 2011
    • 30
    Help : Err01 No CA Found (dreambox newb)
    Hi,
    I just got a DM800 se and after reading " Flash Your DM800 se- The Easy Way" guide I proceed to connect to the box, follow the instructions and try and put on the "OpenPLi-2.0-beta-dm800se-20110630.nfi
    Unfortunately something has gone wrong, now I'm getting the error "ERR01 NO CA FOUND"
    I tried to get back into it to via the ipaddress, but it wont connect now?
    How can I get it back?
    Can I flash it via a USB?
    please help me i dont kno what to do
    thanks all
  • andy91
    • 3583
    Hi,
    thanks all
    You will have to do it through Dreamup with a null modem cable,the are loads of threads covering this on the forum if you search No Ca Found.
    Andy.
    • andy91
      • 3583
      Read these two threads below mate,not easy but you should get it back.
      You certain that you flashed with correct image?
      Andy.
      • raeeszain1
        • Jun 2011
        • 43
        On the DM800 se clone u can only flash original images prior to 15-02-2011. To recover the box you need to download sunray flashup tool & use usb to service port lead.
        • riadh2010
          • Apr 2011
          • 30
          from were do i get sunray flashup tool please
          • andy91
            • 3583
            Have you tried the official Dreambox website?
            Pretty sure you can get it back with null cable and Dreamup.
            Andy.
            • riadh2010
              • Apr 2011
              • 30
              i got one but didnt work for me
              i tried 2nd_stage_pack and keep telling me file to big
              • riadh2010
                • Apr 2011
                • 30
                wan i use sunray flashup tool i cant find the port any help with that
                • andy91
                  • 3583
                  Try this,,,,
                  what you have to do
                  1-run dreamup , connect DM800 with cable
                  2- under dreamop select network and in the remote ip (box) put the ip you want for your box
                  3-now switch on the dreambox, dreamup will prepared the box for flash
                  when ready for flash
                  4 take the remote ip (box) then follow the procedure through the web now
                  192,168.xxxx.xxx
                  will get to the upgrade firmware page
                  This will force the box on bootloader mode
                  I hope this will help
                  Courtesy of Kevin24 look in post 2 it mentions file to big.
                  Andy.
                  • riadh2010
                    • Apr 2011
                    • 30
                    1-run dreamup , connect DM800 with cable with witch cabel
                    *USB*
                    • riadh2010
                      • Apr 2011
                      • 30
                      didnt work for me
                      • andy91
                        • 3583
                        didnt work for me
                        Check them other posts mate theres a tool called Enforcer in it. Everyone has problems at first sometimes a different version of Dreamup theres several so keep trying.
                        Andy.
                        • riadh2010
                          • Apr 2011
                          • 30
                          thanks lot m8
                          is working now i hat to change to small cabal about 5cm long he work with that
                          i am happy now got my box back all thanks to you m8
                          • andy91
                            • 3583
                            thanks lot m8
                            Glad your sorted mate a little patience goes a long way.
                            Andy.
                            • riadh2010
                              • Apr 2011
                              • 30
                              yeah
                              i am just looking for good image for it now i tried lot of them didnt work
