dreambox 800 se ERR01 NO CA FOUND hellp
  • dantheman06
    • Jun 2009
    • 9
    #31
    The DM800SE No CA Fix:
    1. Download Sunray Flasher here (for DM800SE and DM500HD with Sim 2.1)
    2. Download the Second Stage Bootloader Here Hotfile.com: One click file hosting: sim2SE_SSL82_110620.nfi It will fix the no Ca found message.
    3. Open Sunray flasher and connect via USB Mini (and use network mode for faster flashing) to your dm800se. Flash the .nfi SSL 82 bootloader file.
    4. Turn off box. Now hold the front standby button and power on. Open the DHCP IP in your browser and flash any image of your choice.
    5. IMPORTANT: Repeat Step 3. Now your done!
    Note 1. I find i cant flash an image using sunray flasher, so thats why i used the browser method.
    Note 2. If you don't get a DHCP IP, put your router IP to 192.168.0.1
    Note 3. Use Internet Explorer to flash. FF4 wont work
    • rudy691
      • Oct 2010
      • 77
      #32
      most of the cases are fine with just connecting through dreamup. this should get you your IP staright away. thats how i fixed mine, connect with null mode cable (full null, not serial), turn patched dreamup on, click connect, power on dreambox - it should give you the IP on the OSD now. then use the ip to flash it with the browser.
      and ff 4/5 works fine mate, so is google chrome
      • dantheman06
        • Jun 2009
        • 9
        #33
        Rubbish DreamUp does not work with the Sim 2.1 Dreamboxs: DM800SE and DM500HD. With DM800SE FF4 won't work either.
        • raeeszain1
          • Jun 2011
          • 43
          #34
          The dm800se has usb to serial port connection. Can't connect with null mode cable.
          • dantheman06
            • Jun 2009
            • 9
            #35
            ACtually all it has is a mini usb cable and if you install these drivers on your pc you don't need USB to Serial Converter
            • rudy691
              • Oct 2010
              • 77
              #36
              ive just noticed its about SE...
              LOL
              • CHERCHELOI
                • Jul 2011
                hi am sorry but my DM800 SE no com only 2 USB how to connect it for flash thanks
                • Decoder
                  • 46
                  #38
                  Hi all But what happens when Sunray gets to the "waiting for acknowledgement" stage and hangs please? Full story here if anybody can help please: Hi guys/girls Please help only I'm fkuc'd. Got 800HD se and loaded Sat4fun SSL84 as read on this forum - was "playing around!!" yesterday and downloading items via the TSpanel, when I got the message I pushed the blue button and everything seemed to be working as it had when I'd done this previously!! When the orange "loading bar" on the front of the DB got about halfway there was a click (fan switching off?) and the box switched off with just the blue LED on front showing. The problem is now because I can't switch it to deep standby the Sunray dreamup loads (and tells me the dreambox is there) but hangs on the "waiting for acknowledge" and won't let me reflash. (Also when I switch on the box with front button held in it comes on with the stop and ip address but when I put this into browser it can't find it - don't know if this helps or confuses things!!!) How can I overcome this please? Many many thanks for all help and suggestions - not too technical please as I'm no expert - as you can tell!!!
                  • southpaw
                    • 2233
                    #39
                    on the waiting for acknowledgement error , does the dreambox lcd display say "stop http mode " and display an i-p address , if so , enter the i-p address in a web browser and flash as per normal method
                    • Decoder
                      • 46
                      #40
                      Hi Southpaw Well you are not going to believe this but I just got 5 mins to look at replies and when I "hooked it all up" to get the info you asked it all started working as should be so I've quickly flashed it with the same software but think I'll stay away from the Tspanel for a while!!!!! (The only thing I did different was to actually unplug the power and leave it till I got home tonight!!?) Just out of interest when you do a restart and get the "do you want to update......" message do you say yes or no please? (I haven't had the guts to say yes!!!)
                      Thanks for all your help and when it goes wrong again I'll be back!!!!!!!! Cheers mate
                      • southpaw
                        • 2233
                        #41
                        Don't do any online updating on clones mate, it will give you "no CA error "
                        Best to turn off the feature altogether, sorry can't remember which buttons, but its in there somewhere
                        • Decoder
                          • 46
                          #42
                          Thanks mate your a star. Best wishes
                          • Decoder
                            • 46
                            #43
                            Don't know if this is the right place to discuss this but here goes!!! When I put my ip address into my browser why is it I can't flash a new image? The box is "speaking" to the computer as I can watch whatever is on the DB and I can change channel etc. The heading says "Dreambox WebControl" is this correct and do I need to change any settings on the box or computer please?
                            Thanks for all help/replies
                              You get that message when your connected to the internet. You need to make sure you have connected your leads from the Dreambox to your pc and are running Dreamup.
                              • southpaw
                                • 2233
                                #45
                                to flash via web browser you need to put your unit in "flash mode"
                                remove all power , leave for couple of mins ,
                                apply power lead whilst holding the on/off button in (keep pressed until display reads stop ,http mode , and ip address is displayed)
                                then enter this ip address to browser , it will load up a 2nd web browser type page , with function to "update firmware"
