Hi guys,
Update 1:
Finally received my DM800SE from Tony (yaoxin), and after attempting the ICVS Image and DreamElite image i am getting Tuner failed using both images on all HD Channels.
Now from the look of things, it might be worth waiting prior to ordering, seems the tuners are not as stable as i had hoped.
If there are any recommendations in terms of a fix or what can be tried or if you have ordered from yaoxin and its working please let me know?
Update:
Manual Scan did the Trick!
Tuner Failed issue is Gone! And All HD Channels are working solid now!!!
So if you are having the same issue then thanks to alom5 simply run a manual scan and good luck
Update 1:
Update:
