i had a dm500 that would not move my dish.now have tm500 super that works fine.looking at the dm800 clone and was wondering if members had any problems using this box with diseqc 1.2.be kind its my first post.
dm800 and diseqc 1.2
Most use usals mate but a few on here use diseqc 1.2 with no problems mate, i think Rodbuoy uses diseqc 1.2
Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
You could try usals it aint hard and just tweak your long and lat but both work fine.
The Dm500 should have worked fine mate, usals are a hit and a miss on the 500 tho. Must have been a faulty power supply.
The 800 will work fine on diseqc 1.2 Its my preferred choice. Usals fine too, its just down to what you feel works best for your setup.
I would agree to get a better mount if possible. If its mounted correctly it will save you having to tweak.
I installed my own dish with some help from my mate and some reading and since I installed it over 2 1/2 years ago, I have never had to go near it.Comment
I could never get it right using Diseqe 1.2 are there any good guides out there Rodbouy for this?The Dm500 should have worked fine mate, usals are a hit and a miss on the 500 tho. Must have been a faulty power supply.
Do you do it differently,when i get some time wanna give it another go cheers,
All I do, Is goto tuner config, Set it to advanced.
Pic the sat I was furthest east to start. Mine being 28.2
Set Diesqc mode to 1.2
Scroll down till you see use usals and set to no.
Store Pos to sat 1
Save then come out go to sat positioner.
Press red to tune
Pick a pre defined TP from the list or add your own.
Now pick positioner movement Green to search west (i moved the dish as far east to start)
Get the desired lock and store to the number you set above.
Now repeat this for the sats you wants
Ie I have
1) 28.2
2) 23.5
3) 19.2
4) 16
5) 13
6) 9
Suppose you just find a way that works then you stick with it.
It was more trickery to use going from the 500 to the 800 to start with, but easy once you get the hang of it.
Usals on the spider was even ok but still had to fine tune it.Comment
Cheers mate,think i tried it that way but must have done something wrong cos they never stored right.All I do, Is goto tuner config, Set it to advanced.
Store Pos to sat 1
Press red to tune
Ie I have
1) 28.2
2) 23.5
3) 19.2
4) 16
5) 13
6) 9
Will give it another go and follow this guide.
Think thats where i was going wrong so you have to put the stored number in the tuner config page for each sat then?
Not just positioner set up?
