Dm800 wrong image
  • iceman
    • 52
    Dm800 wrong image
    Like a nerd I flashed a bt82 pro version with an image for a previous version of dm800 (bt76). Now I get error when boot saying sim not found . Any ideas or is it bin time
  • andy91
    • 3583
    If you cant get ip address on box when powering up and holding in power button let go and it will say stop,if this aint possible try flashing with dreamup and correct image.
    Andy.
    • 00360362878
      • Mar 2010
      • 488
      as Andy say's you will have to reflash the box. No need to be concerned with the ssl, just make sure that the image is compatible with your sim type, you say you have the dm800 pro, then that will be sim201.
      good luck
      • iceman
        • 52
        I can't communicate with the box
        • andy91
          • 3583
          If you cant get an ip address then your stuck with dreamup,null modem cable and lots of patience.
          Andy.
          • freck
            • 1076
            Takes about 65 mins to do but will get you out of trouble,connect serial cable then open dreamup and hit connect,it'll say dreambox 800 connectedplease power up.
            Press flash and select your image press ok and wait.
            Freck
